Cisco 2951 QOS HQF
tiagogarcia
Hi guys,
I've researched but did not find a clear document about Cisco 2951 QOS HQF support. Does this platform supports HQF? Is it need a special license and/or IOS specific version.
Thanks in advanced
T
willwetherman
Yes, HQF is supported on the Cisco 2951 as of version 15.1(1)T1 and above using the Universal IP Base license. You check this yourself by using the Cisco Feature Navigator
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
I hope that this helps
Will
willwetherman
Will
