Cisco 3550 continuously Rebooted
kumarpmt83
   Hi .
  I my office cisco 3550 switch was installed.
  Switch was contionously rebooted and after some interval(5Min,30min,2hrs) it is working fine.
  Why the switch was rebooted Continously??
  Give me some solution to troubleshoot.
kcnajaf
Level 7
Level 7
Hi Dhinesh,
You may get "show tech-support" from the switch upload it here as a attachment. I'm sure that we will have experts in here who can verfying show tech information to nail this down.
Najaf
Please Find the attachment.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.12.03 18:33:05 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
Password:
sw047a#show tech-support
------------------ show version ------------------
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(14)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 02-Sep-03 03:55 by antonino
Image text-base: 0x00003000, data-base: 0x006760F4
ROM: Bootstrap program is C3550 boot loader
sw047a uptime is 9 minutes
System restarted at 06:53:36 cst Mon Dec 3 2012
System image file is "flash:c3550-i9q3l2-mz.121-14.EA1a/c3550-i9q3l2-mz.121-14.EA1a.bin"
cisco WS-C3550-24 (PowerPC) processor (revision L0) with 65526K/8192K bytes of memory.
Processor board ID CAT0809N06D
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0F:34:B3:36:00
Motherboard assembly number: 73-5700-11
Power supply part number: 34-0966-04
Motherboard serial number: CAT0809062K
Power supply serial number: LIT08020143
Model revision number: L0
Motherboard revision number: A0
Model number: WS-C3550-24-SMI
System serial number: CAT0809N06D
Configuration register is 0x10F
------------------ show running-config ------------------
Building configuration...
Current configuration : 4322 bytes
! No configuration change since last restart
version 12.1
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname sw047a
username tech privilege 15 password 7
clock timezone cst -6
clock summer-time cdt recurring
ip subnet-zero
no ip igmp snooping vlan 32
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 32
switchport mode access
duplex full
speed 100
interface FastEthernet0/2
duplex full
speed 100
interface FastEthernet0/3
duplex full
speed 100
spanning-tree portfast
interface FastEthernet0/4
duplex full
speed 100
interface FastEthernet0/5
description Connection to EIS
duplex full
speed 100
interface FastEthernet0/6
description Connection to Solimar Primary
duplex full
speed 100
interface FastEthernet0/7
description Freezer
duplex full
speed 100
interface FastEthernet0/8
duplex full
speed 100
interface FastEthernet0/9
duplex full
speed 100
interface FastEthernet0/10
description Satellite
switchport block multicast
duplex full
speed 100
interface FastEthernet0/11
duplex full
speed 100
interface FastEthernet0/12
duplex full
speed 100
interface FastEthernet0/13
duplex full
speed 100
interface FastEthernet0/14
duplex full
speed 100
interface FastEthernet0/15
duplex full
speed 100
interface FastEthernet0/16
duplex full
speed 100
interface FastEthernet0/17
description Garage
duplex full
speed 100
interface FastEthernet0/18
duplex full
speed 100
interface FastEthernet0/19
duplex full
speed 100
interface FastEthernet0/20
duplex full
speed 100
interface FastEthernet0/21
duplex full
speed 100
interface FastEthernet0/22
duplex full
speed 100
interface FastEthernet0/23
duplex full
speed 100
interface FastEthernet0/24
duplex full
speed 100
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
switchport mode dynamic desirable
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan32
ip address 10.47.32.225 255.255.240.0
no ip route-cache
interface Vlan48
ip address 10.47.48.225 255.255.240.0
no ip route-cache
ip classless
no ip http server
logging 10.240.82.0
snmp-server community RO
snmp-server community RW
tacacs-server host 10.240.32.242
tacacs-server key
line con 0
password 7
line vty 0 4
password 7
login
line vty 5 15
password 7
login
ntp clock-period 17180336
ntp server 10.47.48.245
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size   Name
4872/6000   vegas_flash init
5648/6000   vqpc_shim_create_addr_tbl
5632/6000   SPAN Subsystem
9148/12000  Init
5364/6000   RADIUS INITCONFIG
7524/9000   DHCP Client
9880/12000  Virtual Exec
Interrupt level stacks:
Level    Called Unused/Size  Name
  4       18909   8532/9000  CPU NETWORK INTERFACE CHIP
  5        1082   8904/9000  Vegas miami tty xmit hack timer
  6      147404   8932/9000  Clock Timer Vector
Spurious interrupts: 29
------------------ show interfaces ------------------
Vlan1 is administratively down, line protocol is down
  Hardware is EtherSVI, address is 000f.34b3.3600 (bia 000f.34b3.3600)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicast)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 1 interface resets
Vlan32 is up, line protocol is up
  Internet address is 10.47.32.225/20
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 10/75/0/0 (size/max/drops/flushes); Total output drops: 3
  5 minute input rate 26000 bits/sec, 31 packets/sec
  5 minute output rate 1000 bits/sec, 3 packets/sec
     8995 packets input, 877645 bytes, 0 no buffer
     737 packets output, 64694 bytes, 0 underruns
     0 output errors, 0 interface resets
Vlan48 is up, line protocol is up
  Internet address is 10.47.48.225/20
  Last input 00:00:00, output 00:00:16, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3
     615 packets input, 41896 bytes, 0 no buffer
     11 packets output, 2016 bytes, 0 underruns
FastEthernet0/1 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3601 (bia 000f.34b3.3601)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  input flow-control is off, output flow-control is off
     Received 0 broadcasts (0 multicast)
     0 watchdog, 0 multicast, 0 pause input
     0 output errors, 0 collisions, 1 interface resets
FastEthernet0/2 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3602 (bia 000f.34b3.3602)
FastEthernet0/3 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3603 (bia 000f.34b3.3603)
FastEthernet0/4 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3604 (bia 000f.34b3.3604)
FastEthernet0/5 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3605 (bia 000f.34b3.3605)
  Description: Connection to EIS
FastEthernet0/6 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3606 (bia 000f.34b3.3606)
  Description: Connection to Solimar Primary
FastEthernet0/7 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3607 (bia 000f.34b3.3607)
  Description: Freezer
FastEthernet0/8 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3608 (bia 000f.34b3.3608)
FastEthernet0/9 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3609 (bia 000f.34b3.3609)
FastEthernet0/10 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.360a (bia 000f.34b3.360a)
  Description: Satellite
FastEthernet0/11 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.360b (bia 000f.34b3.360b)
FastEthernet0/12 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.360c (bia 000f.34b3.360c)
FastEthernet0/13 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.360d (bia 000f.34b3.360d)
FastEthernet0/14 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.360e (bia 000f.34b3.360e)
FastEthernet0/15 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.360f (bia 000f.34b3.360f)
FastEthernet0/16 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3610 (bia 000f.34b3.3610)
FastEthernet0/17 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3611 (bia 000f.34b3.3611)
  Description: Garage
FastEthernet0/18 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3612 (bia 000f.34b3.3612)
FastEthernet0/19 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3613 (bia 000f.34b3.3613)
FastEthernet0/20 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3614 (bia 000f.34b3.3614)
FastEthernet0/21 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3615 (bia 000f.34b3.3615)
FastEthernet0/22 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3616 (bia 000f.34b3.3616)
FastEthernet0/23 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3617 (bia 000f.34b3.3617)
FastEthernet0/24 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 000f.34b3.3618 (bia 000f.34b3.3618)
GigabitEthernet0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 000f.34b3.3619 (bia 000f.34b3.3619)
  Full-duplex, 1000Mb/s, link type is auto, media type is SX
  output flow-control is off, input flow-control is off
  Last input 00:00:01, output 00:00:05, output hang never
  5 minute input rate 45000 bits/sec, 44 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     16078 packets input, 2269224 bytes, 0 no buffer
     Received 14606 broadcasts (0 multicast)
     0 watchdog, 6037 multicast, 0 pause input
     823 packets output, 74576 bytes, 0 underruns
GigabitEthernet0/2 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 000f.34b3.361a (bia 000f.34b3.361a)
  Auto-duplex, Auto-speed
------------------ show controllers ------------------
  Transmit FastEthernet0/1           Receive
         0 Bytes                        0 Bytes
         0 Unicast frames               0 Unicast frames
         0 Multicast frames             0 Multicast frames
         0 Broadcast frames             0 Broadcast frames
         0 Discarded frames             0 No dest, unicast
         0 Too old frames               0 No dest, multicast
         0 Deferred frames              0 No dest, broadcast
         0  1 collision frames
         0  2 collision frames          0 FCS errors
         0  3 collision frames          0 Oversize frames
         0  4 collision frames          0 Undersize frames
         0  5 collision frames          0 Collision fragments
         0  6 collision frames
         0  7 collision frames          0 Minimum size frames
         0  8 collision frames          0 65 to 127 byte frames
         0  9 collision frames          0 128 to 255 byte frames
         0 10 collision frames          0 256 to 511 byte frames
         0 11 collision frames          0 512 to 1023 byte frames
         0 12 collision frames          0 1024 to 1518 byte frames
         0 13 collision frames
         0 14 collision frames          0 Flooded frames
         0 15 collision frames          0 Overrun frames
         0 Excessive collisions         0 VLAN filtered frames
         0 Late collisions              0 Source routed frames
         0 Good (1 coll) frames         0 Valid oversize frames
         0 Good(>1 coll) frames         0 Pause frames
         0 Pause frames                 0 Symbol error frames
         0 VLAN discard frames          0 Invalid frames, too large
         0 Excess defer frames          0 Valid frames, too large
         0 Too large frames             0 Invalid frames, too small
         0 64 byte frames               0 Valid frames, too small
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/2           Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/3           Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/4           Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/5           Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/6           Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/7           Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/8           Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/9           Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/10          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/11          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/12          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/13          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/14          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/15          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/16          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/17          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/18          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/19          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/20          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/21          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/22          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/23          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit FastEthernet0/24          Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
  Transmit GigabitEthernet0/1        Receive
     74576 Bytes                  2269224 Bytes
       781 Unicast frames             764 Unicast frames
        33 Multicast frames          3962 Multicast frames
         9 Broadcast frames          8448 Broadcast frames
         0 Discarded frames           708 No dest, unicast
         0 Too old frames            2075 No dest, multicast
         0 Deferred frames            121 No dest, broadcast
         0  7 collision frames       3927 Minimum size frames
         0  8 collision frames       9756 65 to 127 byte frames
         0  9 collision frames       1360 128 to 255 byte frames
         0 10 collision frames        260 256 to 511 byte frames
         0 11 collision frames        213 512 to 1023 byte frames
         0 12 collision frames        562 1024 to 1518 byte frames
       216 64 byte frames               0 Valid frames, too small
       572 127 byte frames
        12 255 byte frames
        13 511 byte frames
        10 1023 byte frames
         0 1518 byte frames
  Transmit GigabitEthernet0/2        Receive
         0 Bytes                        0 Bytes
         0 127 byte frames
         0 255 byte frames
         0 511 byte frames
         0 1023 byte frames
         0 1518 byte frames
stp packets : 1662 retrieved, 0 dropped
ram access packets : 4612 retrieved, 0 dropped
routing protocol packets : 4117 retrieved, 0 dropped
forwarding packets : 0 retrieved, 0 dropped
routing packets : 6348 retrieved, 0 dropped
L2 protocol packets : 34 retrieved, 0 dropped
igmp snooping protocol packets : 2277 retrieved, 0 dropped
addr learning packets : 0 retrieved, 0 dropped
icmp redirect packets : 0 retrieved, 0 dropped
icmp unreachable packets : 0 retrieved, 0 dropped
logging packets : 0 retrieved, 0 dropped
rpffail packets : 0 retrieved, 0 dropped
queue13 : 50 retrieved, 0 dropped
queue14 : 0 retrieved, 0 dropped
queue15 : 0 retrieved, 0 dropped
RAM Access:
       5103 sends       4612 read replies       2724 write replies
       5100 completed          0 retries          0 failures
          0 nomem          0 nobuffers          0 errors
          0 expedite toggles          0 fa-lost          0 fa-passives
SCInstance = 0xB58BD0
SCInstance fields: fs_notify_failed = 0, no_fsd_space = 0
           invalid_frames = 0, unexpected_valid_frames = 0
           too_large_frames = 0
           Aged frames from notify queues and unexpected retrieves:
               aged_frames[0] = 0, unexpected_retrieves[0] = 0
               aged_frames[1] = 0, unexpected_retrieves[1] = 0
               aged_frames[2] = 0, unexpected_retrieves[2] = 0
               aged_frames[3] = 0, unexpected_retrieves[3] = 0
               aged_frames[4] = 0, unexpected_retrieves[4] = 0
               aged_frames[5] = 0, unexpected_retrieves[5] = 0
               aged_frames[6] = 0, unexpected_retrieves[6] = 0
               aged_frames[7] = 0, unexpected_retrieves[7] = 0
               aged_frames[8] = 0, unexpected_retrieves[8] = 0
               aged_frames[9] = 0, unexpected_retrieves[9] = 0
               aged_frames[10] = 0, unexpected_retrieves[10] = 0
               aged_frames[11] = 0, unexpected_retrieves[11] = 0
               aged_frames[12] = 0, unexpected_retrieves[12] = 0
               aged_frames[13] = 0, unexpected_retrieves[13] = 0
               aged_frames[14] = 0, unexpected_retrieves[14] = 0
               aged_frames[15] = 0, unexpected_retrieves[15] = 0
           sc_cpu_buffer = 0x80000000, sc_regs = 0x81000000
           sc_notify_ram = 0x81010000
CPU Interface registers:
    0x810004A4:storage_congestion_time = 0x10
    0x810004A8:channel_number = 0x102
    0x810004AC:cpu_buffer_control = 0x1
    0x810004B0:current_time = 0x1
    0x810004B4:device_type = 0x2016A
    0x810004B8:global_interrupt_mask = 0x80000002
    0x810004BC:global_interrupt_status = 0x0
    0x810004C0:global_status = 0x80000000
    0x810004C4:hash_coefficient_select = 0x1
    0x810004D0:interrupt_mask_timer = 0x6AB
    0x810004D4:molecule_receive_attention_mask = 0x3
    0x810004D8:molecule_receive_attention_status = 0x0
    0x810004DC:molecule_receive_interrupt_mask = 0x0
    0x810004E0:molecule_receive_interrupt_status = 0x0
    0x810004E4:molecule_receive_status = 0x0
    0x810004E8:molecule_send_attention_mask = 0x0
    0x810004EC:molecule_send_attention_status = 0x0
    0x810004F0:molecule_send_interrupt_mask = 0xF
    0x810004F4:molecule_send_interrupt_status = 0x0
    0x810004F8:molecule_send_status = 0x0
    0x810004FC:notify_overrun_count = 0x0
    0x81000500:notify_ring_control = 0x85
    0x81000504:pci_control = 0x2A00002
    0x81000508:pci_cpu_buffer_base = 0x80000000
    0x8100050C:pci_cpu_notify_ram_base = 0x81010000
    0x81000510:pci_id = 0x16A1137
    0x81000514:pci_santa_cruz_base = 0x81000000
    0x81000518:thread_number = 0x1
    0x81000520:retrieval_attention_mask = 0xFFFF
    0x81000524:retrieval_attention_status = 0x0
    0x81000528:retrieval_interrupt_mask = 0x0
    0x8100052C:retrieval_interrupt_status = 0x0
    0x81000530:retrieval_status = 0x0
    0x81000534:storage_attention_mask = 0xF
    0x81000538:storage_attention_status = 0x0
    0x8100053C:storage_interrupt_mask = 0x0
    0x81000540:storage_interrupt_status = 0x0
    0x81000544:storage_status = 0x0
    0x81000548:storage_pause_time = 0x0
    0x81000550:frame_notify_format = 0x11111111
    0x81000554:interval_timer = 0xDCB
    0x81000558:interval_timer_status = 0x80000FA0
    0x8100055C:cache_info = 0x0
    0x81000560:module_code_base_address = 0x0
    0x81000564:retrieval_pause_time = 0x0
    0x8100056C:cpu_buffer_diagnostics[0] = 0x0
    0x81000570:cpu_buffer_diagnostics[1] = 0x0
    0x81000574:cpu_buffer_diagnostics[2] = 0x0
    0x81000578:cpu_buffer_diagnostics[3] = 0x0
    0x81000000:retrieval_info[0]:
        start_ptr = 0x800ADB40, end_ptr = 0x800ADC3F, read_ptr = 0x800ADC20, write_ptr = 0x800ADC20
        requested_bytes 0x5F4, flags 0x40000007
    0x81000020:retrieval_info[1]:
        start_ptr = 0x80069660, end_ptr = 0x8006969F, read_ptr = 0x80069660, write_ptr = 0x80069660
    0x81000040:retrieval_info[2]:
        start_ptr = 0x80105D80, end_ptr = 0x80105E1F, read_ptr = 0x80105DF0, write_ptr = 0x80105DF0
        requested_bytes 0x5F4, flags 0x40000017
    0x81000060:retrieval_info[3]:
        start_ptr = 0x800A6E70, end_ptr = 0x800A6F0F, read_ptr = 0x800A6E70, write_ptr = 0x800A6E70
    0x81000080:retrieval_info[4]:
        start_ptr = 0x80101500, end_ptr = 0x801019AF, read_ptr = 0x80101800, write_ptr = 0x80101800
    0x810000A0:retrieval_info[5]:
        start_ptr = 0x800B4870, end_ptr = 0x800B496F, read_ptr = 0x800B4890, write_ptr = 0x800B4890
    0x810000C0:retrieval_info[6]:
        start_ptr = 0x8009E6B0, end_ptr = 0x8009E74F, read_ptr = 0x8009E720, write_ptr = 0x8009E720
    0x810000E0:retrieval_info[7]:
        start_ptr = 0x80AAAAA0, end_ptr = 0x80AAAAAF, read_ptr = 0x80AAAAA0, write_ptr = 0x80AAAAA0
        requested_bytes 0x8000AAAA, flags 0x40000006
    0x81000100:retrieval_info[8]:
        start_ptr = 0x800C2160, end_ptr = 0x800C225F, read_ptr = 0x800C2160, write_ptr = 0x800C2160
    0x81000120:retrieval_info[9]:
        start_ptr = 0x8011A9D0, end_ptr = 0x8011AACF, read_ptr = 0x8011A9D0, write_ptr = 0x8011A9D0
    0x81000140:retrieval_info[10]:
        start_ptr = 0x8010D160, end_ptr = 0x8010D1DF, read_ptr = 0x8010D160, write_ptr = 0x8010D160
    0x81000160:retrieval_info[11]:
        start_ptr = 0x8009A1E0, end_ptr = 0x8009A2DF, read_ptr = 0x8009A1E0, write_ptr = 0x8009A1E0
    0x81000180:retrieval_info[12]:
        start_ptr = 0x80555550, end_ptr = 0x8055555F, read_ptr = 0x80555550, write_ptr = 0x80555550
        requested_bytes 0x5555, flags 0x40000006
    0x810001A0:retrieval_info[13]:
        start_ptr = 0x8006A5A0, end_ptr = 0x8006A79F, read_ptr = 0x8006A6C0, write_ptr = 0x8006A6C0
    0x810001C0:retrieval_info[14]:
    0x810001E0:retrieval_info[15]:
    0x81000200:notify_info[0]:
        start_ptr = 0x81010000, end_ptr = 0x81010FFF, read_ptr = 0x810103F0, write_ptr = 0x810103F0
        queue_depth = 0x200, queue_select = 0x60, flags = 0x40000001
    0x81000220:notify_info[1]:
        start_ptr = 0x81011000, end_ptr = 0x810110FF, read_ptr = 0x81011020, write_ptr = 0x81011020
        queue_depth = 0x20, queue_select = 0x61, flags = 0x40000001
    0x81000240:notify_info[2]:
        start_ptr = 0x81012000, end_ptr = 0x8101231F, read_ptr = 0x81012088, write_ptr = 0x81012088
        queue_depth = 0x64, queue_select = 0x62, flags = 0x40000001
    0x81000260:notify_info[3]:
        start_ptr = 0x81013000, end_ptr = 0x8101331F, read_ptr = 0x81013000, write_ptr = 0x81013000
        queue_depth = 0x64, queue_select = 0x63, flags = 0x40000001
    0x81000280:notify_info[4]:
        start_ptr = 0x81014000, end_ptr = 0x8101431F, read_ptr = 0x81014180, write_ptr = 0x81014180
        queue_depth = 0x64, queue_select = 0x64, flags = 0x40000001
    0x810002A0:notify_info[5]:
        start_ptr = 0x81015000, end_ptr = 0x81015FFF, read_ptr = 0x81015110, write_ptr = 0x81015110
        queue_depth = 0x200, queue_select = 0x65, flags = 0x40000001
    0x810002C0:notify_info[6]:
        start_ptr = 0x81016000, end_ptr = 0x8101631F, read_ptr = 0x81016268, write_ptr = 0x81016268
        queue_depth = 0x64, queue_select = 0x66, flags = 0x40000001
    0x810002E0:notify_info[7]:
        start_ptr = 0x81015550, end_ptr = 0x81015557, read_ptr = 0x81015550, write_ptr = 0x81015550
        queue_depth = 0x0, queue_select = 0x0, flags = 0xC0000000
    0x81000300:notify_info[8]:
        start_ptr = 0x81018000, end_ptr = 0x81018FFF, read_ptr = 0x81018000, write_ptr = 0x81018000
        queue_depth = 0x200, queue_select = 0x68, flags = 0x40000001
    0x81000320:notify_info[9]:
        start_ptr = 0x81019000, end_ptr = 0x81019FFF, read_ptr = 0x81019000, write_ptr = 0x81019000
        queue_depth = 0x200, queue_select = 0x69, flags = 0x40000001
    0x81000340:notify_info[10]:
        start_ptr = 0x8101A000, end_ptr = 0x8101AFFF, read_ptr = 0x8101A000, write_ptr = 0x8101A000
        queue_depth = 0x200, queue_select = 0x6A, flags = 0x40000001
    0x81000360:notify_info[11]:
        start_ptr = 0x8101B000, end_ptr = 0x8101B1FF, read_ptr = 0x8101B000, write_ptr = 0x8101B000
        queue_depth = 0x40, queue_select = 0x6B, flags = 0x40000001
    0x81000380:notify_info[12]:
        start_ptr = 0x8101AAA8, end_ptr = 0x8101AAAF, read_ptr = 0x8101AAA8, write_ptr = 0x8101AAA8
    0x810003A0:notify_info[13]:
        start_ptr = 0x8101D000, end_ptr = 0x8101DFFF, read_ptr = 0x8101D190, write_ptr = 0x8101D190
        queue_depth = 0x200, queue_select = 0x6D, flags = 0x40000001
    0x810003C0:notify_info[14]:
    0x810003E0:notify_info[15]:
    0x81000400:molecule_send_info[0]
        start_ptr = 0x8003CAE0, end_ptr = 0x8003CDFF, read_ptr = 0x8003CDC0, write_ptr = 0x8003CDC0
        process_ptr = 0x8003D598, flags = 0x40000001
    0x81000420:molecule_send_info[1]
        start_ptr = 0x8003CE70, end_ptr = 0x8003D18F, read_ptr = 0x8003CFE0, write_ptr = 0x8003CFE0
        process_ptr = 0x8006AAA8, flags = 0x40000001
    0x81000440:storage_info[0]
        start_ptr = 0x8003AAB8, end_ptr = 0x8003BA57, read_ptr = 0x8003B7E8, write_ptr = 0x8003B7E8
        stored_ptr = 0x8003B7E8, flags = 0xC0000001
    0x81000460:storage_info[1]
        start_ptr = 0x8003BAC8, end_ptr = 0x8003CA67, read_ptr = 0x8003BCE8, write_ptr = 0x8003BCE8
        stored_ptr = 0x8003BCE8, flags = 0xC0000001
    0x81000480:molecule_receive_info
        start_ptr = 0x8003D200, end_ptr = 0x8003D51F, read_ptr = 0x8003D2C0, write_ptr = 0x8003D2C0
        overrun_count = 0x0, flags = 0x40000001
------------------ show file systems ------------------
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
*   15998976    10242560     flash     rw   flash:
           -           -    opaque     ro   bs:
           -           -    opaque     rw   vb:
    15998976    10242560   unknown     rw   zflash:
      393216      388688     nvram     rw   nvram:
           -           -    opaque     rw   null:
           -           -    opaque     rw   system:
           -           -   network     rw   tftp:
           -           -    opaque     ro   xmodem:
           -           -    opaque     ro   ymodem:
           -           -   network     rw   rcp:
           -           -   network     rw   ftp:
------------------ show flash: all ------------------
------------------ dir nvram: ------------------
Directory of nvram:/
  378  -rw-        4429                startup-config
  379  ----          47                private-config
393216 bytes total (388688 bytes free)
------------------ show process memory ------------------
Total: 56380324, Used: 4205772, Free: 52174552
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0     121668       5044    3159712          0          0 *Init*
   0   0        568      63248        568          0          0 *Sched*
   0   0    9700804    4593972     215152    1118440          0 *Dead*
   1   0          0          0       6848          0          0 Chunk Manager
   2   0        184        184       3848          0          0 Load Meter
   3   0       8080       8608       6848          0          0 SpanTree Helper
   4   0          0          0       6848          0          0 Check heaps
   5   0      40936      30780      18476      28560     164464 Pool Manager
   6   0        184        184       6848          0          0 Timers
   7   0      65936      32652      40352          0          0 Entity MIB API
   8   0          0          0       6848          0          0 HC Counter Timer
   9   0        368        368       7032          0          0 ARP Input
  10   0          0          0       6848          0          0 Net Input
  11   0          0          0       6848          0          0 Critical Bkgnd
  12   0      28032          0      15164       5040          0 Net Background
  13   0        320        184      12984          0          0 Logger
  14   0        184        184       6848          0          0 TTY Background
  15   0          0          0       9848          0          0 Per-Second Jobs
  16   0        184        184       6848          0          0 Compute load avg
  17   0          0          0       6848          0          0 Per-minute Jobs
  18   0          0          0       6848          0          0 AggMgr Process
  19   0        184        184       3848          0          0 Vegas Storm Cont
  20   0        492          0       6848          0          0 Vegas LED Proces
  21   0          0          0       3848          0          0 SCQ_PROCESS
  22   0          0          0       6848          0          0 RAM Access
  23   0        184        184       3848          0          0 SW Frame Ager
  24   0          0          0       6848          0          0 VLAN Info Update
  25   0        184        184       3848          0          0 L2TM Process
  26   0     243788     243788       3848          0          0 Vegas Statistics
  27   0        184        184       3848          0          0 L3TM
  28   0      27664        184      34328          0          0 HMATM Learn proc
  29   0        232        232       6848          0          0 HMATM Age proces
  30   0       1472       1472       6848          0          0 VL2MM
  31   0          0          0       6848          0          0 Vegas Bridging
  32   0       2616        184       9076          0          0 VegasPM
  33   0          0          0       6848          0          0 VUR_MGR bg proce
  34   0       6752       3112      10488          0          0 CDP Protocol
  35   0       2616          0      15464          0          0 IP Input
  36   0      32768       1072      28292          0          0 DTP Protocol
  37   0        184        184       6848          0          0 Ethchnl
  38   0      76252      65456      16944          0          0 VLAN Manager
  39   0        184        184       6848          0          0 PI MATM Aging Pr
  40   0          0       2788       6848          0          0 VMATM Callback
  41   0       4432        656       7000          0          0 Spanning Tree
  42   0        152          0       7000          0          0 Port-Security
  43   0        260        184       6924          0          0 UDLD
  44   0      32232       2976      22408          0          0 DHCPD Receive
  45   0        152          0      10000          0          0 IP RIB Update
  46   0          0          0       6848          0          0 HTTP Timer
  47   0          0          0       6848          0          0 RARP Input
  48   0          0          0      12848          0          0 TCP Timer
  49   0      29256          0      14548          0          0 TCP Protocols
  50   0          0          0       6848          0          0 Socket Timers
  51   0       2756       1980       9604          0          0 L2MM
  52   0          0          0       6848          0          0 MRD
  53   0          0          0       6848          0          0 IGMPSN
  54   0       2764        184       9428          0          0 L2TRACE SERVER
  55   0        184        184       6848          0          0 Cluster L2
  56   0          0          0       6848          0          0 Cluster RARP
  57   0       3372       3028       7192          0          0 Cluster Base
  58   0        184        184       6848          0          0 Adj Manager
  59   0          0          0       6848          0          0 IP Cache Ager
  60   1    1890116    1886564      16448          0          0 Virtual Exec
  62   0          0        136       9848          0          0 Router Autoconf
  63   0        184        184       6848          0          0 VTPMIB EDIT BUFF
  64   0       4684       2636      11532          0          0 PM Callback
  65   0          0          0       6848          0          0 VFM Queue Proces
  66   0      13668      12428      62088          0          0 VFM/VQM Merge Pr
  67   0          0          0       6848          0          0 VFM Deferred Upd
  68   0          0          0       6848          0          0 DHCPD Timer
  69   0       5228        184      11892          0          0 VTP Trap Process
  70   0          0          0      12848          0          0 l2vlanifmib
  71   0        184        184       3848          0          0 Vegas EnvMon Pro
  72   0          0          0       6848          0          0 Syslog Traps
  73   0        184        184       3848          0          0 STP STACK TOPOLO
  74   0        184        184       3848          0          0 STP FAST TRANSIT
  75   0        184        184       3848          0          0 STP STACK TOPOLO
  76   0        184        184       3848          0          0 CSRT RAPID TRANS
  77   0          0          0       6848          0          0 Vegas DHCP glean
  78   0          0          0       6868          0          0 SNMP Timers
  79   0     166372       3444      14340     140280          0 IP SNMP
  80   0      21160          0      12848          0          0 PDU DISPATCHER
  81   0      50448      71504      12952          0          0 SNMP ENGINE
  82   0          0          0      12848          0          0 SNMP ConfCopyPro
  83   0          0          0      12848          0          0 SNMP Traps
  84   0        940        184       7604          0          0 NTP
  85   0        184          0       7032          0          0 DHCPD Database
                                  4205532 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 1%/0%; one minute: 1%; five minutes: 0%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0         1          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2           0       112          0  0.00%  0.00%  0.00%   0 Load Meter
   3           0         4          0  0.00%  0.00%  0.00%   0 SpanTree Helper
   4         120        57       2105  0.00%  0.02%  0.00%   0 Check heaps
   5           8        39        205  0.00%  0.00%  0.00%   0 Pool Manager
   6           0         2          0  0.00%  0.00%  0.00%   0 Timers
   7          12         3       4000  0.00%  0.00%  0.00%   0 Entity MIB API
   8           0       112          0  0.00%  0.00%  0.00%   0 HC Counter Timer
   9         228      1716        132  0.00%  0.02%  0.01%   0 ARP Input
  10           0         1          0  0.00%  0.00%  0.00%   0 Net Input
  11           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  12           4       396         10  0.00%  0.00%  0.00%   0 Net Background
  13           0        10          0  0.00%  0.00%  0.00%   0 Logger
  14           0       552          0  0.00%  0.00%  0.00%   0 TTY Background
  15           0       560          0  0.00%  0.00%  0.00%   0 Per-Second Jobs
  16           0       113          0  0.00%  0.00%  0.00%   0 Compute load avg
  17          36        10       3600  0.00%  0.00%  0.00%   0 Per-minute Jobs
  18           0         3          0  0.00%  0.00%  0.00%   0 AggMgr Process
  19           0         2          0  0.00%  0.00%  0.00%   0 Vegas Storm Cont
  20           0     13891          0  0.00%  0.00%  0.00%   0 Vegas LED Proces
  21           0         1          0  0.00%  0.00%  0.00%   0 SCQ_PROCESS
  22          40      4760          8  0.00%  0.00%  0.00%   0 RAM Access
  23           4      8161          0  0.00%  0.00%  0.00%   0 SW Frame Ager
  24           4         6        666  0.00%  0.00%  0.00%   0 VLAN Info Update
  25           0      1110          0  0.00%  0.00%  0.00%   0 L2TM Process
  26        2208      1655       1334  0.40%  0.40%  0.36%   0 Vegas Statistics
  27           0      1110          0  0.00%  0.00%  0.00%   0 L3TM
  28           0      7699          0  0.00%  0.00%  0.00%   0 HMATM Learn proc
  29           4       556          7  0.00%  0.00%  0.00%   0 HMATM Age proces
  30           4        11        363  0.00%  0.00%  0.00%   0 VL2MM
  31           0         1          0  0.00%  0.00%  0.00%   0 Vegas Bridging
  32         116      6931         16  0.00%  0.00%  0.00%   0 VegasPM
  33           0       288          0  0.00%  0.00%  0.00%   0 VUR_MGR bg proce
  34           4        79         50  0.00%  0.00%  0.00%   0 CDP Protocol
  35        1004      5710        175  0.49%  0.36%  0.19%   0 IP Input
  36          12        43        279  0.00%  0.00%  0.00%   0 DTP Protocol
  37           0        58          0  0.00%  0.00%  0.00%   0 Ethchnl
  38           8         6       1333  0.00%  0.00%  0.00%   0 VLAN Manager
  39           0       556          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  40           0         6          0  0.00%  0.00%  0.00%   0 VMATM Callback
  41         184       555        331  0.00%  0.00%  0.00%   0 Spanning Tree
  42           0        10          0  0.00%  0.00%  0.00%   0 Port-Security
  43           0       556          0  0.00%  0.00%  0.00%   0 UDLD
  44           0        15          0  0.00%  0.00%  0.00%   0 DHCPD Receive
  45           0         1          0  0.00%  0.00%  0.00%   0 IP RIB Update
  46           0         1          0  0.00%  0.00%  0.00%   0 HTTP Timer
  47           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
  48           0        97          0  0.00%  0.00%  0.00%   0 TCP Timer
  49           0         5          0  0.00%  0.00%  0.00%   0 TCP Protocols
  50           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
  51           4         6        666  0.00%  0.00%  0.00%   0 L2MM
  52           0         1          0  0.00%  0.00%  0.00%   0 MRD
  53           0         1          0  0.00%  0.00%  0.00%   0 IGMPSN
  54           0         2          0  0.00%  0.00%  0.00%   0 L2TRACE SERVER
  55           0         9          0  0.00%  0.00%  0.00%   0 Cluster L2
  56           0        56          0  0.00%  0.00%  0.00%   0 Cluster RARP
  57           4        83         48  0.00%  0.00%  0.00%   0 Cluster Base
  58           0       112          0  0.00%  0.00%  0.00%   0 Adj Manager
  59           0        10          0  0.00%  0.00%  0.00%   0 IP Cache Ager
  60        1000     34935         28  0.08%  0.01%  0.00%   1 Virtual Exec
  62           0         2          0  0.00%  0.00%  0.00%   0 Router Autoconf
  63           0         2          0  0.00%  0.00%  0.00%   0 VTPMIB EDIT BUFF
  64           0      1552          0  0.00%  0.00%  0.00%   0 PM Callback
  65           0         1          0  0.00%  0.00%  0.00%   0 VFM Queue Proces
  66           4         1       4000  0.00%  0.00%  0.00%   0 VFM/VQM Merge Pr
  67           0         1          0  0.00%  0.00%  0.00%   0 VFM Deferred Upd
  68           0         5          0  0.00%  0.00%  0.00%   0 DHCPD Timer
  69           0        13          0  0.00%  0.00%  0.00%   0 VTP Trap Process
  70           0         1          0  0.00%  0.00%  0.00%   0 l2vlanifmib
  71           0       556          0  0.00%  0.00%  0.00%   0 Vegas EnvMon Pro
  72           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
  73           0         2          0  0.00%  0.00%  0.00%   0 STP STACK TOPOLO
  74           0         2          0  0.00%  0.00%  0.00%   0 STP FAST TRANSIT
  75           0         2          0  0.00%  0.00%  0.00%   0 STP STACK TOPOLO
  76           0         2          0  0.00%  0.00%  0.00%   0 CSRT RAPID TRANS
  77           0         1          0  0.00%  0.00%  0.00%   0 Vegas DHCP glean
  78           0         3          0  0.00%  0.00%  0.00%   0 SNMP Timers
  79           4        74         54  0.00%  0.00%  0.00%   0 IP SNMP
  80           0        25          0  0.00%  0.00%  0.00%   0 PDU DISPATCHER
  81          20        25        800  0.00%  0.00%  0.00%   0 SNMP ENGINE
  82           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
  83           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
  84           0       565          0  0.00%  0.00%  0.00%   0 NTP
  85           0       155          0  0.00%  0.00%  0.00%   0 DHCPD Database
------------------ Mempool statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor     A38C5C    56380324     4205796    52174528    51250292    51652132
      I/O   80000000     8388608     1181412     7207196     7195720     7204368
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x00000000  0x03FFD7FF    67098624  Local  R/W    main
0x00003000  0x006760F3     6762740  IText  R/W    main:text
0x006760F4  0x008A1689     2274710  IData  R/W    main:data
0x008A168A  0x00A38C57     1668558  IBss   R/W    main:bss
0x00A38C5C  0x03FFD7FF    56380324  Local  R/W    main:heap
0x80000000  0x807FFFFF     8388608  Iomem  R/W    iomem
------------------ show buffers ------------------
Buffer elements:
     475 in free list (500 max allowed)
     2872 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50):
     50 in free list (20 min, 150 max allowed)
     215 hits, 0 misses, 0 trims, 0 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 40, permanent 25, peak 40 @ 00:09:15):
     28 in free list (10 min, 150 max allowed)
     398 hits, 5 misses, 0 trims, 15 created
Big buffers, 1524 bytes (total 148, permanent 128, peak 148 @ 00:08:29):
     139 in free list (128 min, 512 max allowed)
     2408 hits, 12 misses, 0 trims, 20 created
VeryBig buffers, 4520 bytes (total 1, permanent 0, peak 2 @ 00:08:41):
     1 in free list (0 min, 0 max allowed)
     9 hits, 15 misses, 29 trims, 30 created
Large buffers, 5024 bytes (total 0, permanent 0):
     0 in free list (0 min, 0 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 0, permanent 0):
Interface buffer pools:
Ram Access buffers, 1524 bytes (total 150, permanent 100, peak 166 @ 00:09:27):
     150 in free list (100 min, 150 max allowed)
     5081 hits, 22 misses, 16 trims, 66 created
CPU1 buffers, 1524 bytes (total 4, permanent 4):
     1 in free list (0 min, 4 max allowed)
     3693 hits, 923 fallbacks
CPU13 buffers, 1524 bytes (total 32, permanent 32):
     1 in free list (0 min, 32 max allowed)
     80 hits, 2 fallbacks
CPU11 buffers, 1524 bytes (total 16, permanent 16):
     0 in free list (0 min, 16 max allowed)
     16 hits, 0 fallbacks
CPU6 buffers, 1524 bytes (total 10, permanent 10):
     1 in free list (0 min, 10 max allowed)
     2080 hits, 208 fallbacks
CPU3 buffers, 1524 bytes (total 20, permanent 20):
     10 in free list (0 min, 20 max allowed)
     10 hits, 0 misses
CPU0 buffers, 1524 bytes (total 16, permanent 16):
     3 in free list (0 min, 16 max allowed)
     1393 hits, 285 fallbacks
CPU5 buffers, 1524 bytes (total 16, permanent 16):
     1 in free list (0 min, 16 max allowed)
     47 hits, 3 fallbacks
CPU8 buffers, 1524 bytes (total 32, permanent 32):
     16 in free list (0 min, 32 max allowed)
     16 hits, 0 misses
CPU4 buffers, 1524 bytes (total 150, permanent 150):
     73 in free list (0 min, 150 max allowed)
     6477 hits, 0 misses
CPU2 buffers, 1524 bytes (total 10, permanent 10):
     2 in free list (0 min, 10 max allowed)
     3159 hits, 968 fallbacks
CPU10 buffers, 1524 bytes (total 8, permanent 8):
     0 in free list (0 min, 8 max allowed)
     8 hits, 0 fallbacks
CPU9 buffers, 1524 bytes (total 32, permanent 32):
     16 hits, 0 misses
i had  given the Tech-support  .pls check and provide the solution ASAP.
