Cisco 3550 Not Able to Configure IPv6 OSPF
ashish
Frnds,
I am using 3550 with  c3550-ipservicesk9-mz.122-44.SE6.bin. Have successfully run ipv6  commands on global and interface, however getting below error while  configuring "ipv6 router ospf 1" :
SW1(config)#ipv6 router ospf 1
% Failed to create routing protocol ospf
Command syntax help says its configurable but its not configuring ipv6 OSPF.
SW1(config)#ipv6 router ?
   eigrp  Enhanced Interior Gateway Routing Protocol (EIGRP)
  ospf   Open Shortest Path First (OSPF)
   rip    IPv6 Routing Information Protocol (RIPv6)
pls suggest.
cadet alain
have you entered ipv6 unicast-routing ?
Regards.
Alain
yes, following commands are already running:
SW1(config)#ipv6 unicast-routing
SW1(config)#int vlan 1
SW1(config-if)#ipv6 address abc::/64 eui-64
and check this:
W1(config-if)#ipv6 ?
IPv6 interface subcommands:
  address            Configure IPv6 address on interface
  authentication     authentication subcommands
  bandwidth-percent  Set EIGRP bandwidth limit
  eigrp              Configure EIGRP IPv6 on interface
  enable             Enable IPv6 on interface
  hello-interval     Configures EIGRP-IPv6 hello interval
  hold-time          Configures EIGRP-IPv6 hold time
  mtu                Set IPv6 Maximum Transmission Unit
  nd                 IPv6 interface Neighbor Discovery subcommands
  next-hop-self      Configures EIGRP-IPv6 next-hop-self
  policy             Enable IPv6 policy routing
  redirects          Enable sending of ICMP Redirect messages
rip                Configure RIP routing protocol
  split-horizon      Perform split horizon
  summary-address    Summary prefix
  traffic-filter     Access control list for packets
  unnumbered         Preferred interface for source address selection
  verify             Enable per packet validation
Note: OSPF is missing here
But:
However:
if you can't enable OSPFv3 on an interface then it  means that it is not supported.
Regards.
Alain
