I am attempting to setup total 8 VLAN’s on a cisco C3560X switch that uses a Sonicwall NSA as the gateway. The VLAN’s need to be completely separate from each other but able to get ip(DHCP) and access the internet via the Sonicwall.
My ip plan is as below.
Sonicwall Ip : 10.10.20.1
Cisco 3560 Management Vlan1 ip : 10.10.20.2
Vlan 10 : 10.10.0.1/255.255.252.0
Vlan 20 : 10.20.0.1/255.255.254.0
Vlan 30 : 10.30.0.1/255.255.254.0
vlan 40 : 10.40.0.1/255.255.252.0
Vlan 50 : 10.50.0.1/255.255.255.254.0
Vlan 60: 10.60.0.1/255.255.255.0
Vlan 70 : 10.70.0.1/255.255.254.0
Vlan 80 : 10.80.0.1/255.255.254.
I want connect sonicwall to Cisco 3560 port no 24 and Access point controller to port no 23 .All vlan port will connected to respective building L2 switch. Then L2 switch connected to Access Point, then Access point connect to users( users need to be get ip from sonicwall with their vlan subnet)Pl see the below Diagram.
Can someone give me full configuration to me?
