Cisco 3560 Dual ISP Failover help
Jeff Mercader
hi experts! question for home lab setup is it possible to have the setup of when isp1 goes down pc1 on the diagram goes to isp2 on a different vlan and vice versa. Currently they work on their own pc1 gets internet of isp1 . pc2 gets internet from isp2. they dont see each other. i have the right ios ver for each cisco device. this is a small project been trying to get to work while studing for ccna and my question is what i am trying to do is it possible? and if so is it pbr? or ip sla? or both? Im at a lost how to implement this. Let me know if additional info is needed.
still this issue not solve ?
MHM
11 Replies 11
Jeff Mercader
thanks for the reply but command IP nat on the switch doesnt seem to be available?
SKYNET-SW0(config)#ip nat ?
% Unrecognized command
iam assuming on the link above its applicable to run the commands on the switch as it was both local connection to the isps
No need to do NAT in SW' run NAT in routers connect to ISP.
Job of SW is forward traffic to edge router' in edge router you can do NAT.
MHM
Hello
FYI -You need to have NAT applied on both rtrs ( if those isp connections are internet facing) and have some conditional routing ( possible ipsa/object tracking) in case either isp transport link or reachability upstream from the ISP fails so the rtrs can be aware of any failure and re-route/converge accordingly.
You do not share much information about you network especially how the routing is setup between your L3 switch and the two wan rtrs and what NAT (if any) is currently in place
Kind Regards
Paul
Hi Paul and @MHM Cisco World
here is the lab setup i have for this hope it helps point me in the right direction.
C3560
no aaa new-model
clock timezone Manila 8
system mtu routing 1500
vtp mode transparent
authentication mac-move permit
ip routing
ip name-server 10.100.100.2
ip name-server 192.168.1.1
errdisable recovery cause psecure-violation
errdisable recovery interval 320
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 100
name PLDT-BACKUP
##F017 is where TPLINK Deco e4 is connected
interface FastEthernet0/17
switchport access vlan 100
switchport mode access
switchport port-security maximum 20
spanning-tree portfast
#F0/18 is PC2
interface FastEthernet0/18
switchport port-security maximum 5
##f0/33 is PC1
interface FastEthernet0/33
##This is connected to G0/0 of Cisco 1921
interface GigabitEthernet0/1
switchport mode trunk
switchport nonegotiate
interface Vlan1
ip address 10.100.100.3 255.255.255.0
interface Vlan100
ip address dhcp
router ospf 1
log-adjacency-changes
auto-cost reference-bandwidth 1000
network 10.0.0.0 0.255.255.255 area 0
network 15.15.15.15 0.0.0.0 area 0
network 192.168.1.0 0.0.0.255 area 0
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16, Fa0/33, Fa0/34, Fa0/35, Fa0/36
Fa0/37, Fa0/38, Fa0/39, Fa0/40, Fa0/41, Fa0/42, Fa0/43, Fa0/44, Fa0/45, Fa0/46, Fa0/47, Fa0/48, Gi0/2, Gi0/3, Gi0/4
100  PLDT-BACKUP                      active    Fa0/17, Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22, Fa0/23, Fa0/24, Fa0/25, Fa0/26, Fa0/27, Fa0/28, Fa0/29, Fa0/30, Fa0/31, Fa0/32
####Cisco 1921
ip name-server 192.168.68.1
interface GigabitEthernet0/0
ip address 10.100.100.2 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex full
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
router ospf 1
router-id 11.11.11.11
passive-interface GigabitEthernet0/1
network 10.100.100.0 0.0.0.255 area 0
network 11.11.11.11 0.0.0.0 area 0
default-information originate
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
access-list 1 permit 10.0.0.0 0.255.255.255
There are several things I would like to address:
- you say "command IP nat on the switch doesnt seem to be available". That is a correct observation. You will need NAT for the second vlan but it can not be provided by the switch.
- I see that routing is enabled on the switch. It seems to be exchanging routing info with the router. Is there any other source of routing information for the switch?
- you have 2 vlans/2 subnets active on the switch. What is the default gateway for devices in both subnets? Is it the switch? the router? something else?
- the switch configures the connection to the router as a trunk, which would carry both vlans. But the router configuration treats the connection as access and not as trunk. So what happens with traffic from vlan 100?
- the switch OSPF configuration specifies 3 networks. Clearly one network is for vlan 1, one network is for vlan 100, what is the third network?
- it is unusual for a home lab setup to have 2 ISP. Do you exchange any routing information with either/both of the ISP?
- there is configuration on the router for NAT for vlan 1. If vlan 100 is to access Internet it would need NAT. Where is that NAT configured?
Rick
Hi Rick , thanks for your reply. Please below.
Hi There are none to my knowledge
DG for the 10.100.x network is the 1921 Router, the 192.168.1.x is from the TP Link e4
didnt configure any sub interface on the router so what happened is vlan100 kept within the network any device plugs into the vlan100 ports get ip address from the tp link e4 commercial router
its the loopback of the device, 11.11 is cisco1921 and i think i made 15.15.x is the switch
no exchange going on for both these are typical commercial isp accounts i just happened to have access to both accnts
there is no NAT configure for vlan100. i just plug in tplink router/modem to the port plug in pc2 on a vlan100 port it was assigned an ip address and could browse the internet using isp2 normally.
Thanks for the additional information. Here are my thoughts:
The switch needs some type of indication when one of the ISP has failed. If there was exchange of routing information that might have been one way to do it. If there is not routing information exchange then you probably needs something like IP SLA to detect failure of an ISP.
If there is not any processing on the router for vlan 100 then I suggest that you change the switch configuration to make the connection to the router an access port rather than a trunk.
It appears that what you have currently works ok but does not provide any redundancy/failover. To achieve redundancy you would need:
- a way to detect failure of an ISP. IP SLA could be used for that.
- a way to redirect traffic. PBR can be used for that.
- you would need to change the configuration of NAT on your router to translate addresses from vlan 100 if they are forwarded to the router. And you would need to change the NAT of tplink to translate addresses from vlan 1 if they are forwarded to tplink.
Rick
Jeff Mercader
nat is already configured on VLAN1, VLAN100 on the diagram doesnt have a managed router to configure NAT. TP DECOe4 mesh unit
im was thinking if there was a device that would tell where to go in case they cant reach their designated isp it would be the 3560. unless im not understanding.
I have little time so I share with you idea if I not reply I hope you understand.
Now
You have SW two vlan'
Each vlan have one router do routing and NAT for one vlan'
Each router IP is GW for host in it vlan
You can not manage both router <<- confirm that
So here SW even with ip routing is l2 SW it cannot do anything if one edge router failed
BUT
You can use
Ip sla to detect internet via each edge router
And use EEM if ip sla is down then SW will change vlan assign to port' this force port to get new vlan and traffic forward to other edge router.
Note:- in eem make port up/down to force pc get new IP from dhcp server
MHM
MHM
