Syslog over TLS NCS540X
TCP port 6514 is the default port for syslog over TLS, i want change this port's value, but i don't find anything for this
Have you idéa?
Sorry for bad news
There is no way to change port of syslog over tls for ios xr.
MHM
6 Replies 6
Devaa
Check if the below command works.
conf t
logging host x.x.x.x transport tls port 7514
end
Cisco NCS540X, use IOS XR, this CLI don't exist.
logging tls-server xxx <<- when you enter to server mode what command is available? Try search for change port' use ""?""
i have already search with "?", but any option for this...
Sorry for bad news
MHM
vishalbhandari
@Gilles Dellaccio To change the default TCP port (6514) for syslog over TLS, you typically need to modify the configuration of your syslog server or client, depending on which side you want to change. Look for a configuration file like rsyslog.conf, syslog-ng.conf, or your syslog server's specific settings. In these files, you should find a line defining the port (e.g., input(type="imtcp" port="6514") in Rsyslog). Update the port number to your desired value, save the file, and restart the syslog service to apply the changes. If you're using a managed solution, refer to the specific vendor's documentation for port customization options.
