Cisco 3660 and Microsoft Azure
Hi! sorry but my english is no very good.
My question is, the Cisco 3660 is posible VPN tunnel between cisco 3660 and Microsoft Azure?
http://msdn.microsoft.com/en-us/library/azure/jj156075.aspx
IPsec ParametersIKE Phase 1 setup
PropertyStatic Routing VPN gatewayDynamic Routing VPN gateway and High Performance VPN gateway
IKE Version
IKEv1
IKEv2
Diffie-Hellman Group
Group 2 (1024 bit)
Group 2 (1024 bit)
Authentication Method
Pre-Shared Key
Pre-Shared Key
Encryption Algorithms
AES256
AES128
3DES
AES256
3DES
Hashing Algorithm
SHA1(SHA128)
SHA1(SHA128)
Phase 1 Security Association (SA) Lifetime (Time)
28,800 seconds
28,800 seconds
IKE Phase 2 setup
IKE Version
IKEv1
IKEv2
Hashing Algorithm
SHA1(SHA128)
SHA1(SHA128)
Phase 2 Security Association (SA) Lifetime (Time)
3,600 seconds
Phase 2 Security Association (SA) Lifetime (Throughput)
102,400,000 KB
IPsec SA Encryption & Authentication Offers (in the order of preference)
  1. ESP-AES256
  2. ESP-AES128
  3. ESP-3DES
  4. N/A
See Dynamic Routing Gateway IPsec Security Association (SA) Offers
Perfect Forward Secrecy (PFS)
No
Yes (DH Group1)
Dead Peer Detection
Not supported
Supported
Thank you!!
Regards.
Christian
joe19366
it can do the right Static Routing VPN gateway settings with an enterprise or ipsec capable image;
but the performance may not be what you're looking for.
you can grab an asa 5505 on ebay for $200 - may be your best option for ikev1
-Joe
