Bookmark
Subscribe
1054
cisco 3745
dhanikonda
Dear sir,
I have cisco 3745 router in that i want to inistall NM-2FE-2W this cord is compatable for this router.
my sh ver is below..
sh ver
IOS (tm) 3700 Software (C3745-IK9O3S-M), Version 12.2(15)T7, RELEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Sat 09-Aug-03 04:04 by ccai
Image text-base: 0x60008954, data-base: 0x61D7C000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
DP-INTERNET2 uptime is 1 week, 2 days, 1 hour, 21 minutes
System restarted at 13:40:00 IST Sun Feb 1 2009
System image file is "flash:c3745-ik9o3s-mz.122-15.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 3745 (R7000) processor (revision 2.0) with 111616K/19456K bytes of memory.
Processor board ID JMX0737L4PY
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
4 Serial(sync/async) network interface(s)
8 ISDN Basic Rate interface(s)
1 Virtual Private Network (VPN) Module(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31360K bytes of ATA System CompactFlash (Read/Write)
Thanks&Regards
srini
Giuseppe Larosa
Hello Srini,
I tried to use the software advisor tool.
From an hardware point of view it is fine.
Looking at IOS releases it starts to show from 12.3 IP base
12.3(26)
c3745-ipbase-mz.123-26
or
12.4(15)T8
c3745-ipbasek9-mz.124-15.T8
I remember I used the NM on a C3745 with 12.3(8)T adventeprise
So an IOS upgrade may be required
Hope to help
Giuseppe
Dear sir,
Thanks for ur support
srini
