Cisco 3750 mtu problem
JGFR
Hello
I have problem with Lan2Lan and MTU. I use Cisco 3750G on each side, but one of my switch have different Jumbo MTU :
- First side :
3750-side-a#show system mtu
System MTU size is 1500 bytes
System Jumbo MTU size is 1500 bytes
System Alternate MTU size is 1500 bytes
Routing MTU size is 1500 bytes
3750-side-b#show system mtu
System MTU size is 1998 bytes
System Jumbo MTU size is 9000 bytes
How to set System Jumbo MTU of same value ?
Jordan
Reza Sharifi
Try:
config t
system mtu <1500-9198>
Julio E. Moisa
Try using system mtu jumbo <1500-1998> globally.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Please select the rating if it is useful.
