12-19-2006 08:22 AM - edited 03-03-2019 03:05 PM
How stable is the enviornment with Cisco and Dell using the GVRP protocol for Inter-Vlan routing?
I have a new distribution rack of all 3750's and all my edge switches are Dell managed switches. I would like to have a trunk port setup and share do the vlan taging.
Thanks.
Solved! Go to Solution.
07-08-2008 11:26 AM
was this a success, if so ~ do you have a pdf or link that can provide more details for this?
12-20-2006 01:21 PM
Cisco TAC said that there is no support for GVRP with the 3750's. If you are using the default VLAN only on the Dell switch, it's works fine. You just run into problems when you have more than 2.
Thanks.
07-08-2008 11:26 AM
