Cisco 3945 E PAT issue
Sudhir Menon
Hi ,
We have a 3845  router deployed at a tier  2 ISP  for  PATing user based sessions to the Internet ,the issue happening is when the NAT table size reaches approximately 2,000,000 the router gets hung and has to be restarted
the router has a memory of 256 MB RAM and approximately 100 MB free ,below is the show version and show proc mem
Can some one help me identify the issue we are facing
Cisco IOS Software, 3800 Software (C3845-ENTBASE-M), Version 12.4(9)T3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sat 24-Mar-07 00:05 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
uptime is 1 hour, 9 minutes
System restarted at 12:05:53 UTC Fri Sep 16 2011
System image file is "flash:c3845-entbase-mz.124-9.T3.bin"
Cisco 3845 (revision 1.0) with 222208K/39936K bytes of memory.
Processor board ID FHK1118F0HT
2 FastEthernet interfaces
2 Gigabit Ethernet interfaces
4 Serial interfaces
4 Channelized (E1 or T1)/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
Processor Pool Total:  169056224 Used:   69902956 Free:   99153268
      I/O Pool Total:   40893952 Used:   11728272 Free:   29165680
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   57736864   25274508   30778204        637     315627 *Init*
   0   0      12128     263332      12128          0          0 *Sched*
   0   0    1727472    1297972     642904          8          8 *Dead*
   1   0   46224632     421764   45820620          0          0 Chunk Manager
   2   0        252        252       4044          0          0 Load Meter
   4   0       3364        252      10216          0          0 Check heaps
   5   0     692420      38360     329932         45          0 Pool Manager
   6   0        252        252       7044          0          0 Timers
   7   0          0          0       7044          0          0 IPC Dynamic Cach
   8   0          0          0       7044          0          0 IPC Zone Manager
   9   0          0          0       7044          0          0 IPC Periodic Tim
  10   0          0          0       7044          0          0 IPC Deferred Por
  11   0        744          0       7788          0          0 IPC Seat Manager
  12   0          0          0       7044          0          0 IPC BackPressure
  13   0          0          0      13044          0          0 OIR Handler
  14   0          0          0      25044          0          0 Crash writer
  15   0        252        252       7044          0          0 Environmental mo
  16   0       4060     452436       8584     783320     783320 ARP Input
  17   0        252        252       7044          0          0 ATM Idle Timer
  18   0        252        252       7044          0          0 AAA high-capacit
  19   0          0          0       7044          0          0 AAA_SERVER_DEADT
  20   0          0          0      13044          0          0 Policy Manager
  21   0        252        252       7044          0          0 DDR Timers
  22   0       7896          0      14940         50         50 Entity MIB API
  23   0     262884          0     272928    1496565    1496533 EEM ED Syslog
  24   0          0          0       7044          0          0 HC Counter Timer
  25   0        252        252       7044          0          0 Serial Backgroun
  26   0          0          0       7044          0          0 RO Notify Timers
  27   0      10052          0      14096          0          0 RMI RM Notify Wa
  28   0        252        252       7044          0          0 SMART
  29   0        252        252       7044          0          0 GraphIt
  30   0        252        252      13044          0          0 Dialer event
  31   0          0          0       7044          0          0 SERIAL A'detect
  32   0        252        252      13044          0          0 XML Proxy Client
  33 706    3170672    3078200      99848        311        310 Virtual Exec
  34   0          0          0       4044          0          0 Inode Table Dest
  35   0          0          0       7044          0          0 Critical Bkgnd
  36   0      50260        800      13800       1726       1726 Net Background
  37   0       2404       2004      13444          0          0 IDB Work
  38   0     235168      96008     247960    1829403    1829404 Logger
  39   0        252        560       7044          0          0 TTY Background
  40   0          0     144620      10044          0          0 Per-Second Jobs
  41   0          0          0       7044          0          0 AggMgr Process
  42   0          0          0       4044          0          0 dev_device_inser
  43   0          0          0       4044          0          0 dev_device_remov
  44   0          0          0      13044          0          0 sal_dpc_process
  45   0          0          0       7044          0          0 ARL Table Manage
  46   0        252        252       7044          0          0 ESWPPM
  47   0        252        252       4044          0          0 Eswilp Storm Con
  48   0        252        252       7044          0          0 ESWILPPM
  49   0        252        252       4044          0          0 Eswilp Storm Con
  50   0        252        252       7044          0          0 Netclock Backgro
  51   0        252        252       7044          0          0 SM Monitor
  52   0        252        252       7044          0          0 Bryce I2C CMD Qu
  54   0        252        252       7044          0          0 Ether-Switch RBC
  55   0          0          0       4044          0          0 IGMP Snooping Pr
  56   0          0          0       4044          0          0 IGMP Snooping Re
  57   0        252        252       7044          0          0 Call Management
  59   0        252        252       7044          0          0 Dot1x Mgr Proces
  60   0          0          0       7044          0          0 MAB Framework
  61   0          0          0       7044          0          0 EAP Framework
  62   0       2500        252       9292          0          0 DTP Protocol
  63   0        252        252       7044          0          0 PI MATM Aging Pr
  64   0        252        252       7044          0          0 EtherChnl
  65   0        252        252       7044          0          0 AAA Dictionary R
  66   0        252        252       7044          0          0 AAA Server
  67   0          0          0       7044          0          0 AAA ACCT Proc
  68   0          0          0       7044          0          0 ACCT Periodic Pr
  69   0      12944        252      19736        567        567 CDP Protocol
  70   0        252        252      13044          0          0 Ethernet LMI
  71   0    7466872     905724    1592508    1629871    1629868 IP Input
  72   0          0          0       7044          0          0 ICMP event handl
  73   0        252        252       7044          0          0 TurboACL
  74   0        252        252       7044          0          0 TurboACL chunk
  75   0       5704        252      10656         28         28 MOP Protocols
  76   0        504        504      13044          0          0 PPP Hooks
  78   0          0          0      13044          0          0 SSS Manager
  79   0          0          0      13044          0          0 SSS Test Client
  80   0          0          0       7044          0          0 SSS Feature Mana
  81   0          0          0       7044          0          0 SSS Feature Time
  82   0          0          0      13044          0          0 VPDN call manage
  83   0          0          0      13100          0          0 L2X Socket proce
  84   0          0          0      13044          0          0 L2X SSS manager
  85   0        252        252      13044          0          0 L2TP mgmt daemon
  86   0          0          0       7044          0          0 X.25 Encaps Mana
  87   0          0          0       7044          0          0 IP Traceroute
  88   0        580          0      10624          0          0 IP Background
  89   0        164          0      10208          0          0 IP RIB Update
  90   0        252        252      13044          0          0 PPP IP Route
  91   0        252        252      13044          0          0 PPP IPCP
  92   0          0          0       7044          0          0 SNMP Timers
  93   0      73444          0      73444          0          0 CEF process
  94   0          0       4092      13044         31         31 TCP Timer
  95   0     186068          0      13044          0          0 TCP Protocols
  96   0          0          0      25044          0          0 COPS
  97   0          0          0       7044          0          0 Socket Timers
  98   0        416        252       7208          0          0 Dot1x Supplicant
  99   0        416        252       7208          0          0 Dot1x Supplicant
100   0        416        252       7208          0          0 Dot1x Supplicant
101   0        500        156       7544          0          0 L2MM
102   0          0          0       7044          0          0 MRD
103   0       5052          0      12096          0          0 IGMPSN
104   0        252        252       7044          0          0 RLM groups Proce
105   0     122064        252     128856          0          0 SCTP Main Proces
106   0          0          0       7044          0          0 IUA Main Process
107   0        252        252       7044          0          0 RUDPV1 Main Proc
108   0          0          0       7044          0          0 bsm_timers
109   0          0          0       7044          0          0 bsm_xmt_proc
110   0          0          0      10044          0          0 CES Client SVC R
111   0     120988        252     119692          0          0 DHCPD Receive
112   0        252        252       7044          0          0 Dialer Forwarder
113   0          0    4697092       7044          0          0 IP Cache Ager
114   0        252        252      10044          0          0 Adj Manager
115   0        252        252      13044          0          0 ATM OAM Input
116   0        252        252      13044          0          0 ATM OAM TIMER
117   0        940          0      10984          0          0 HTTP CORE
118   0          0          0       7044          0          0 RARP Input
119   0          0          0       7044          0          0 PAD InCall
120   0        252        252      13044          0          0 X.25 Background
121   0        252        252       7044          0          0 PPP Bind
122   0        252        252       7044          0          0 PPP SSS
123   0          0          0       7044          0          0 MQC Flow Event B
124   0        252        252       7044          0          0 RBSCP Background
125   0        252        252       7044          0          0 CRM_CALL_UPDATE_
127   0        252        252       7044          0          0 AAA Cached Serve
128   0        252        252       7044          0          0 ENABLE AAA
129   0          0          0       7044          0          0 EM Background Pr
130   0          0          0       7044          0          0 Key chain liveke
131   0        252        252       7044          0          0 LINE AAA
132   0        252        252       7044          0          0 LOCAL AAA
133   0       1032        252       7824          0          0 TPLUS
134   0        252        252       7044          0          0 Control-plane ho
135   0          0          0       7044          0          0 PM Callback
136   0        252        252       7044          0          0 AAA SEND STOP EV
137   0          0          0      10044          0          0 EEM ED CLI
138   0          0          0      10044          0          0 EEM ED Counter
139   0          0          0      10044          0          0 EEM ED Interface
140   0          0          0      10044          0          0 EEM ED IOSWD
141   0          0          0      10044          0          0 EEM ED Memory-th
142   0          0          0      10044          0          0 EEM ED None
143   0          0          0      10044          0          0 EEM ED OIR
144   0         76          0      10120          0          0 EEM ED Resource
145   0          0          0      10044          0          0 EEM ED SNMP
146   0          0          0      10044          0          0 EEM ED Timer
147   0          0          0      10044          0          0 EEM ED Track
148   0      13408       3684      17428          0          0 EEM Server
149   0        252        252       7044          0          0 RMON Recycle Pro
150   0        252        252       7044          0          0 RMON Deferred Se
151   0          0          0       7044          0          0 Syslog Traps
152   0       9240       1564      14564          0          0 VLAN Manager
153   0          0          0       7044          0          0 DHCPD Timer
154   0      10012        252      19144          0          0 EEM Policy Direc
155   0  444298256  444299172      14828    4569177    4569177 Syslog
156   0          0          0       7044          0          0 VPDN Scal
157   0          0          0       7044      11160      11160 Net Input
158   0        252        252       7044          0          0 Compute load avg
159   0          0          0       7044          0          0 Per-minute Jobs
160   0        164          0       7208          0          0 CEF Scanner
161   0        252          0      25296          0          0 tHUB
162   0        504        252      13296          0          0 tENM
163   0      74676       3124      70888    1440147    1440147 IP NAT Ager
164   0          0          0       7044          0          0 IP NAT WLAN
165   0        792        252       7584        108        108 NTP
166   0        172          0       7216          0          0 DHCPD Database
                                 81560476 Total
6 Replies 6
cadet alain
You could upgrade the memory of the router to support a bigger nat table if it can or you could try to change the nat timeout for tcp sessions from the default of 24 hrs to a lesser value with the ip nat timeout command.
Regards.
Alain.
Hi Alain ,
I have done the same attached is the show run of the router
hi,
did it solve anything ? You'll have to clear your dynamic nat entries first.
Regards.
Alain.
The router hang still continues and have to reboot the router to bring it up
And yes after applying the NAT timeouts I did reset the NAT table
Maybe you could try this:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gt_natrl.pdf
Regards.
Alain.
skarthic
Hi Sudhir,
Are you sure it goes upto 2E6 translations? Following is an excerpt from NAT FAQ doc which says each 10000 translation consumes 3Meg of DRAM.
Q. How many concurrent NAT sessions are supported in Cisco IOS NAT?
A. The NAT session limit is bounded by the amount of available DRAM in the router. Each NAT translation consumes about 312 bytes in DRAM. As a result, 10,000 translations (more than would generally be handled on a single router) consume about 3 MB. Therefore, typical routing hardware has more than enough memory to support thousands of NAT translations.
This means 2Million translations would mean 600 Meg of DRAM at least.
Are you sure all the 2Million translations are for valid traffic. Please make sure of that.
This is the NAT doc that I mentioned -
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_q_and_a_item09186a00800e523b.shtml
Can you collect the "show ip nat stat" and "show proc mem sorted" the next time before you reload the box.
Thanks.
