CISCO 3945 VS 3945e
r.kukreja
HI,
Which router can accomodated maximum no of fast ethernet port.
we have several offices connected thru LL. we need maximum no of ports to accomodate LL.
regards
rajat
Reza Sharifi
The 3945e comes with one extra on board port.
hi,
but if we need to install hwic  fastethernet card then in which router we can install so that we have maximum
no of fast ethernet ports
hi,
can any body answer this ?
Plesae find below:
http://www.cisco.com/c/en/us/products/routers/3900-series-integrated-services-routers-isr/series-comparison.html
Now coming down to the questoin...if you read the below link you would decide to go with the 3945 router.
http://www.cisco.com/c/en/us/products/routers/3945-integrated-services-router-isr/index.html
3945e:
http://www.cisco.com/c/en/us/products/routers/3945e-integrated-services-router-isr/index.html
Only difference you see is that 3945e will have one extra port:-( 4 integrated 10/100/1000 Ethernet ports with 2 SFP ports ) were as 3945 will have 3 integrated ethernet port with 2 SFP.
Inayath
*Plz rate if this info is helpfull.
