cisco 3945 with ISM-VPN.
elad-g
I have cisco router 3945 with ISM-VPN , I need to use with crypto tunnels.
right now I am using with 'crypto-map' configuration.
Is it posseble to configure Tunnel GRE ipsec protection If I have ISM-VPN module ?
The ISM-VPN can handle with Tunnels ?
Thanks.
Lei Tian
Answered in the other thread.
galliher1
oops, errant click. ;-) No problems on my side.
PaulP
The ISM module will give you better performance so it is the router to allow you or restrict you from using a feature. I don't see any issues with this.
Have you tried the configuration and experience issues or you are trying to find out before "breaking" anything?
Hope it helps,
Paul
