Cisco 4221 Celular Profile is inactive
ermionline
Hi Guys,
I am configuring cisco 4221 ISR Router. but cellular profile is inactive state.
Service LED is solid green
RSSI LED is solid green
WWAN LED is also solid green
14 Replies 14
post the configuration of your router. Inactive profiles often have to do with chat scripts. Who is your provider ?
Okay, here is the show run output. my service provider is ethiotelecom
Current configuration : 3727 bytes
! Last configuration change at 11:14:44 UTC Wed Aug 8 2018
version 16.5
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
subscriber templating
chat-script lte " "AT!CALL"TIMEOUT 60 "OK"
diagnostic bootup level minimal
redundancy
 mode none
controller Cellular 0/2/0
 lte sim data-profile 10 attach-profile 10
 lte modem link-recovery disable
no cdp run
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 shutdown
 negotiation auto
interface Cellular0/2/0
 ip address negotiated
 dialer in-band
 dialer idle-timeout 0
 dialer-group 1
 ipv6 address autoconfig
 pulse-time 1
interface Cellular0/2/1
 no ip address
ip forward-protocol nd
no ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 Cellular0/2/0
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipv6 permit
control-plane
line con 0
 transport input none
 stopbits 1
line vty 0 4
 login
your chat script doesn't look right. You need to be careful to add all necessary characters and spaces:
You have configured:
It should be:
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
I have changed the chat script but still no luck.
post the running configuration again after the change...
OKay, Here it is
Router(config)#do sh run
Building configuration...
Current configuration : 3728 bytes
! Last configuration change at 08:56:53 UTC Thu Aug 9 2018
version 16.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
crypto pki trustpoint TP-self-signed-3480386732
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3480386732
 revocation-check none
 rsakeypair TP-self-signed-3480386732
crypto pki certificate chain TP-self-signed-3480386732
 certificate self-signed 01
  30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33343830 33383637 3332301E 170D3138 30353139 30363537
  31305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 34383033
  38363733 32308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
  0A028201 0100C27F 21B23716 39DF32F8 C72B229D 65648469 C9173782 1D1CD93F
  933FAC66 3964FAA7 E524E369 5354ED86 300C23BF 4ECE6A4F 9ADC684D D6FE7CD9
  76CDA0D5 0709D48F DCF97CFE EF58EA91 A272E46A A8DD16AD 0238EB49 DA4B485F
  E774A89E A8CF89FA 40D8635B 1BEE3FE4 162EE242 771DAA47 0745BCCB 1A046E73
  99F418AE 6FF0513C AA81AF93 ACA9F6DF 9F886A82 FB83BB55 F8317B9B 756D221E
  47141326 1CBD55A4 7A911BE6 596067EF 469D6294 C3F992C5 AB5B9FCE B9839D26
  C6F926D0 F8EFCAC8 A48E8272 9367E121 482FDE28 B028AAA6 24F7FF40 954C531D
  BF3D0281 0622C3EC CD5A3706 3FB1E746 36E678D5 49D36AD8 73118FC9 EB316C32
  0B3DB45D 11130203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
  301F0603 551D2304 18301680 14D03604 FB218D30 552EF7A0 08BCC747 D161584E
  2A301D06 03551D0E 04160414 D03604FB 218D3055 2EF7A008 BCC747D1 61584E2A
  300D0609 2A864886 F70D0101 05050003 82010100 2D25D54A DFB2F70C 3FF8B964
  07DE18BC 1F7BBD22 AB3F1FC4 199CEDA0 931DB598 58A675D6 5BB2A3D3 3C0930E5
  E5BF3A84 EE3ED3D1 F9F863CB 2B532958 67878A7D C6C189D5 052F06B5 95BB9D9E
  3C841701 9456E827 163F2761 99AC250C 0D183BEB 3E3BCA56 14956495 63EA3CA9
  78272908 D67BEAD7 549842D2 39774BAB 314ACF4B 66AB7E46 8A82292D 6243E169
  06CFC465 93A780CC 5F28B62A 5452CFAE A12474D9 63A3C640 6AC46C39 2CE3D74F
  E8FFA818 D624D92E 8F69F426 50782796 B729BA63 2CDC46B0 D9F8F50A BB443ED1
  F8055159 D7CBB1DE D8A69CF8 655F3804 8828DB16 68736ECB FBF7D61B 96CFBBD8
  4A901C4D 989B47D5 DCE441EA 55C1879B 0B692AEC
        quit
license udi pid ISR4221/K9 sn FGL214492EY
redundancy
 mode none
 lte sim data-profile 1 attach-profile 10
no cdp run
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 dialer in-band
 dialer-group 1
 pulse-time 1
 no ip address
no ip http server
control-plane
line con 0
 stopbits 1
line vty 0 4
 login
no network-clock synchronization automatic
end
thanks. I am checking...
Can you also post the output of:
show cellular 0/2/0 profile
As well as the output of:
show controller cellular 0/2/0
I want to see which modem and which firmware you have...
OUtPut of sh cellular 0/2/0 profile
Profile 1 = INACTIVE*
PDP Type = IPv4v6
Access Point Name (APN) =
Authentication = None
Profile 2 = INACTIVE
Profile 10 = INACTIVE **
PDP Type = IPv4
Access Point Name (APN) = moenco
Profile 11 = INACTIVE
PDP Type = IPv4
Access Point Name (APN) = etc.com
Profile 15 = INACTIVE
PDP Type = IPv4
  * - Default profile
 ** - LTE attach profile
Output of  show Controller cellular 0/2/0
Router#sh controllers cellular 0/2/0
Interface Cellular0/2/0
4G WWAN NIM - Global Multimode(Europe) LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS unit 2
Cellular Modem Configuration
Modem is recognized as valid
Power save mode is OFF
manufacture id:  0x00001199     product id: 0x000068C0
Sierra Wireless Direct IP MC7304 modem
Modem Uplink Speed = 0 kbit.
Modem Downlink Speed = 0 kbit.
GPS Feature: enabled
GPS Status: GPS mode not enabled
GPS Mode: not configured
Module OIR Details
Module type : NIM-4G-LTE-GA
Module Serial Number : FOC22060G1Q
Module Last Inserted on : Thu Aug  9 12:53:21 2018
Module Last Removed on : Thu Aug  9 12:53:16 2018
Router#sh cell
Router#sh cellular 0/2/0 pro
PDP Type = IPv4v6
PDP Type = IPv4
PDP Type = IPv4
PDP Type = IPv4
  * - Default profile
Router#
Router#
Router#sh contr
Module OIR Details
Module Reload Statistics
Soft OIR reloads = 0
Hard OIR reloads = 1
Modem Management Statistics
Modem resets = 1
Modem user initiated resets = 0
Modem user initiated power-cycles = 0
Modem timeouts = 0
Link recovery is OFF
User initiated Modem Test Commands
Successful Modem Power Cycles : 0
Failed Modem Power Cycles : 0
Successful Modem Resets : 0
Failed Modem Resets : 0
Last known modem state = 'application' mode
AT Command Port = /dev/ttyUSB2
      NMEA Port = /dev/ttyUSB1
      DM   Port = /dev/ttyUSB0
DIP MDM link status retry count = 0 pdp context = 0
DIP MDM link up pending = 0 pdp context = 0
DIP MDM link status retry count = 0 pdp context = 1
DIP MDM link up pending = 0 pdp context = 1
DIP MDM link status retry count = 0 pdp context = 2
DIP MDM link up pending = 0 pdp context = 2
IDB Cellular0/2/0: DIP profile id = 255
IDB Cellular0/2/1: DIP profile id = 255
PDN 0 Channel rate (bps) tx = 0, rx = 0
Max     rate (bps) tx = 0, rx = 0
PDN 1 Channel rate (bps) tx = 0, rx = 0
RSSI LED    : Green
GPS LED     : Off
GPS NMEA port = Disabled   (Stream OFF)
NMEA queue depth: 0
NMEA packet count: 0
DM port = Disabled
Modem Callback Statistics
PacketServiceCallback_count 0
DataBearerCallback_count 0
DormancyStatusCallback_count 0
PowerCallback_count 0
ByteTotalsCallback_count 0
iByteTotalsCallback_count 0
PacketsCountCallback_count 0
iPacketsCountCallback_count 0
ActivationStatusCallback_count 0
MobileIPStatusCallback_count 0
RoamingIndicatorCallback_count 0
DataCapabilitiesCallback_count 1
SignalStrengthCallback_count 0
iSignalStrengthCallback_count 0
RFInfoCallback_count 0
LURejectCallback_count 0
NewSMSCallback_count 0
SLQSSMSEventCallback_count 0
NMEACallback_count 0
PDSStateCallback_count 0
CATEventCallback_count 0
iCATEventCallback_count 0
DeviceStateChangeCbk_count 0
FwDldCompletionCbk_count 0
SLQSOMADMAlertCallback_count 0
OMADMStateCallback_count 0
SLQSServingSystemCallback_count 1
SLQSBandPreferenceCbk_count 0
USSDReleaseCallback_count 0
USSDNotificationCallback_count 0
SLQSSignalStrengthsCallback_count 0
iSLQSSignalStrengthsCallback_count 0
SLQSSDKTerminatedCallback_count 0
SLQSTransLayerInfoCallback_count 0
SLQSTransNWRegInfoCallback_count 0
SLQSSysSelectionPrefCallBack_count 0
NotifySessionStateDisconnect_count 0
WdsEventCallback_count 0
HeartbeatModemStatisticsCallback_count 57
idb at 0x7FE2A439D268, driver data structure at 0x7FE2A439F178
Cellular Linux F/W Info
Firmware Build Date  = 2015/03/04 21:30:23
Firmware Version     = SWI9X15C_05.05.58.00
 The Current Modem SDK Version is 03.03.15
 Modem USB-Serial Driver Version is GobiSerial 2015-08-27/SWI_2.25:GobiSerial
 Modem USB-Net Driver Version is GobiNet 2015-12-08/SWI_2.36
thanks for the info. You are getting no configuration on your profile at all:do you have the SIM card installed and configured for data calls ? Basically, the command:
Router# cellular 0/2/0 lte sim lock 1111
The PIN code should have been given to you by your provider...
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/NIM/software/configuration/guide/4GLTENIM_SW.html#19137
Hi Georg,
Yes i have sim card installed and configured for data calls
HI all,
It started working after I used the below command
router#cellular 0 lte plmn search
Thank you all for you help, really appreciated
good stuff, glad that you got it to work !
Useful good job!
