cisco 4331 ISR
mellalBrahim
hey,
acually i am going to deploy i new cisco ISR 4331, this last should support 4 Link point to point with 512 ko as bandwidth, so i'll insert two NIM-2T catres.
is that possible without any issue ?? does the router support those links normally ??
thanks in advance.
12 Replies 12
Leo Laohoo
  1. Is the router running SD-WAN or autonomous mode?
  2. What is the exact firmware version of the router?
  3. What licenses are enabled?
  4. What bandwidth is enabled?
- autonomous model
- version : 16.09.04
- license : securityk9 , ipbasek9
- primary link 2 mbps , secondary 512 kbps.
Please read FN - 72323 - Cisco IOS XE Software: QuoVadis Root CA 2 Decommission Might Affect Smart Licensing, Smart Call Home, and Other Functionality.
I strongly recommend doing the WORKAROUND or upgrade to the latest 16.9.X.  DO NOT, under any circumstances, upgrade to 16.10.X and later.
Hey,
What about the version, 17.03.02 ??
Leo Laohoo
Post the complete output to the following commands:
sh license feature
sh platform hardware throughput level
hey,
the sh license feature is unknowing ,
Upgrade to the latest 16.9.X.
DO NOT, under any circumstances, upgrade to 17.X.X and later.
NOTE:  The router is licensed for 100 kbps Mbps only.
So to use 512 kbps link or up we should buy a new licence ??
Wait.  My eyes are deceiving me.
The router is licensed for 100 Mbps.
mellalBrahim
so everything whould be good once i downgrade to the lastest 16.9.x version ??
many thinks @Leo Laohoo
Yes.
many thanks leo.
