cisco 4500 -standby supervisor is disabled state?
hasan yenilmez
Hi ,
what can be the reason , standby supervisor is disabled state ?
redundancy  mode sso, show  redundancy and show module  outoputs are below.
thanks in advance
4510R-E#show redundancy states
       my state = 13 -ACTIVE
     peer state = 1  -DISABLED
           Mode = Simplex
           Unit = Primary
        Unit ID = 5
Redundancy Mode (Operational) = Stateful Switchover
Redundancy Mode (Configured)  = Stateful Switchover
Redundancy State              = Non Redundant
     Maintenance Mode = Disabled
    Manual Swact = disabled (system is simplex (no peer unit))
Communications = Down      Reason: Simplex mode
   client count = 54
client_notification_TMR = 240000 milliseconds
          keep_alive TMR = 9000 milliseconds
        keep_alive count = 0
    keep_alive threshold = 18
           RF debug mask = 0x0
4510R-E#show module
Chassis Type : WS-C4510R-E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1    24  1000BaseX (SFP)                        WS-X4624-SFP-E     JAE14080M09
2    24  1000BaseX (SFP)                        WS-X4624-SFP-E     JAE14080LZ7
3    18  10GE (X2), 1000BaseX (SFP)             WS-X4606-X2-E      JAE140901X6
4    18  10GE (X2), 1000BaseX (SFP)             WS-X4606-X2-E      JAE140901QN
5     6  Sup 6-E 10GE (X2), 1000BaseX (SFP)     WS-X45-SUP6-E      JAE141205MH
6        Supervisor
7    18  10GE (X2), 1000BaseX (SFP)             WS-X4606-X2-E      JAE140901QS
8    48  1000BaseX SFP                          WS-X4448-GB-SFP    JAE1406496U
M MAC addresses                    Hw  Fw           Sw               Status
1 0026.99ad.f1f8 to 0026.99ad.f20f 1.1                               Ok
2 0026.99ad.f9e4 to 0026.99ad.f9fb 1.1                               Ok
3 0026.99ad.f582 to 0026.99ad.f593 1.2                               Ok
4 0026.99ad.f67e to 0026.99ad.f68f 1.2                               Ok
5 68ef.bdab.7c80 to 68ef.bdab.7c85 1.6 12.2(44r)SG5 12.2(53)SG1      Ok
6 Unknown                              Unknown      Unknown          Other
7 0026.99ad.f6b4 to 0026.99ad.f6c5 1.2                               Ok
8 68ef.bd15.5da0 to 68ef.bd15.5dcf 1.3                               Ok
Mod  Redundancy role     Operating mode      Redundancy status
5   Active Supervisor   SSO                 Active
6   Standby Supervisor  SSO                 Disabled
9 Replies 9
mahmoodmkl
Level 7
Level 7
I think u need to install the SUP's in slot 1 and 2.
No, slots 5 and 6 are reserved for sup on 4510R.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan Shirshin
It is likely standby sup is stuck in boot or ROMMON mode as it is showing Other status in the outputs above.
Connect with console to it and check which state it is in. If it is in ROMMON, try boot with manual "boot" command.
By the way, did you check if the 12.2(53)SG1 image present in the specified boot location on standby?
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Kind Regards,
Ivan Shirshin
Hi Ivan,
If we boot the secondary SUP from the ROMMON mode, will only this SUP be booted or the entire switch will reboot?
Thanks and Regards
Satyen
Thank you. It was in ROMMON mode and boot command resolved the issue.
plinkqld
My sup is getting to the loading ios services and then nothing. problem is happenning with two sup 7's, one original and one added from spares...
shiguoshun
Hello,I have this question withe the same of your !
IS this problem is OK?
And how you to do it well?Would you tell me ?
Thans a lot !
suz-b2-1f-cat07#show module
Chassis Type : WS-C4510R+E
1    48  10/100/1000BaseT UPOE E Series         WS-X4748-UPOE+E    CAT1924L9T4
 2    48  10/100/1000BaseT UPOE E Series         WS-X4748-UPOE+E    CAT1924L9XY
 3    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E   CAT1951L0P0
 4    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E   CAT1950L70J
 5        Supervisor
6     8  Sup 8-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP8-E      CAT1944L34H
 7    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE102863S1
1 d8b1.9027.58e4 to d8b1.9027.5913 1.1                               Ok
 2 80e0.1d5a.560c to 80e0.1d5a.563b 1.1                               Ok
 3 00f2.8b0f.4e78 to 00f2.8b0f.4ea7 1.1                               Ok
 4 cc46.d611.c6f0 to cc46.d611.c71f 1.1                               Ok
 5 Unknown                              Unknown      Unknown          Other
 6 58ac.78b4.b408 to 58ac.78b4.b40f 1.3 15.1(1r)SG5  03.03.00.XO      Ok
 7 0018.73bb.1880 to 0018.73bb.18af 2.3                               Ok
5   Standby Supervisor  RPR                 Disabled
 6   Active Supervisor   RPR                 Active
Hi, I have the same issue - was this resolved?
shiguoshun
HI,I thinka you must upgrade the SUP's IOS,make sure is the same with the first one .you can add my QQ:26296016.
