Cisco 4503 switch port issue
janaka prabath
Dear Sir,
When there is a power failure our router to switch link would not come up , we have to reset switch port all the time , so we are facing a problem as it is remote site , all the time we have to go to reset the port.So I hope your kind reply to sort out this issue.
Switch - 4503
Router - 3725
The link is layer three.
Best Regards
Leo Laohoo
Before the port gets reset, what is the complete output to the command "sh interface status error"?
Leo Laohoo
Dear Mr.Leo ,
Today I found Rj 45 chassis and I replaced it , but the problem was same .Finally I changed router port ( Fa 0/1 to Fa 1/0 )  which is connected to the Switch , then it was ok. I couldnt understand the reason.Anyway thank you very much for reply.
Cheers
