Cisco 4506 E 7L vs Juniper Ex4600
Hello cisco team
We need some clarification about inter OEM communication we have juniper Ex4600 switch at core level and we are going to connect cisco 4506 E 7-L at access level with 10 Gig SFP+ Fiber transceiver.
Can you please let us know if we face any challenge during installation if yes please let us know what would be the challenges and measures what we need to take care.
Giuseppe Larosa
Hello @DeeprajRachappawar4038 ,
no issues at physical level however (switchport no negotiate on Cisco side can help however)
You need to look at the STP level
Juniper EX 4600 will likely run either RSTP (single instance for each Vlan) or MST.
The best interaction is to have EX 4600 to run MST and the new Cisco to run MST
please note that the native vlan concept on 802.1Q is supported by default only signaling protocols and not for user data on inter switch links
Use a native vlan like 999 dedicated to this scope with no L3 devices on it
Use MST 802.1s or later define the same set of MST instances
Juniper default should be similar to switchport trunk allowed vlan none Cisco default is swithport trunk allowed vlan all.
Be aware of this.
see
https://networktest.com/jnpriop/cookbook.pdf
note also recent JUNOS has changed the command syntax see the JNCIA-JUNOS program
Hope to help
Giuseppe
Hi Giuseppe Larosa
Thank you..!
Joseph W. Doherty
A L2 or L3 connection?
If L2, as Giuseppe notes, you can run into STP issues. If L3, there's often no issues.
