04-19-2011 04:32 AM - edited 03-04-2019 12:06 PM
Hello !
I purchased a Cisco 520 and am trying to set it up on my home network.
Its ADSL PPPoA for WAN.
I am trying to setup 2 LANS.
One General Network
One DMZ for webhosting.
Now, since this router has 4 ethernet ports, i assumed i did not need VLANS.
Except when i try configure an interface with an IP address i get this error:
% IP addresses may not be configured on L2 links.
Now. Ive looked around on the internet about this error. And it seems that since these interfaces are not Layer 3 interfaces,
they need to be associated with VLANS.
This would be OK. Except this requires an IP address on an interface on the router! Back to square one!
This is how I would normaly do it:
conf t
vlan 10
ip address 192.168.2.0 255.255.255.0
conf t
int fa0
switchport mode access
swtchport access vlan 10
Now the problem with this is, what would be the default gateway of the connecting device?
My understanding is that the ethernet port needs an ip address for example 192.168.2.1
Any help would be greatly appreciated!
Solved! Go to Solution.
04-19-2011 06:36 AM
the good config would be:
conf t
vlan 10
name general
vlan 20
name DMZ
int vlan 10
ip address 192.168.10.1 255.255.255.0
exit
int vlan 20
ip address 192.168.20.1 255.255.255.0
exit
int fa0
switchport access vlan 10
int fa1
switchport access vlan 20
And the default gateway for the PC connected to fa0 would be 192.168.10.1?
Exact.
Regards.
Alain.
04-19-2011 05:38 AM
conf t
vlan 10
ip address 192.168.2.0 255.255.255.0 <----- This is not an host ip address but a subnet address so the Cisco device won't let you enter this.
the address of the Vlan interface you configured. By default they are all members of Vlan1.
this is true for a L3 port but not for a L2( switch) port. These 4 ethernet ports are switch ports.
Regards.
Alain.
04-19-2011 06:32 AM
So would i be correct in setting it up like this: ?
conf t
vlan 10
name general
exit
vlan 20
name DMZ
exit
int fa0
int fa1
04-19-2011 06:36 AM
conf t
vlan 10
name general
vlan 20
name DMZ
int vlan 10
exit
int vlan 20
exit
int fa0
int fa1
Exact.
Regards.
Alain.
04-19-2011 06:46 AM
Interesting, i try add the vlans to the default config and it tells me :
Vlan can not be added. Maximum number of 4 vlan(s) in the database.
Here is a sh ip int brief:
ATM0 unassigned YES NVRAM initializing down
ATM0.1 unassigned YES unset initializing down
Dialer0 unassigned YES NVRAM up up
FastEthernet0 unassigned YES unset up down
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
NVI0 unassigned YES unset administratively down down
Vlan1 unassigned YES NVRAM administratively down down
Vlan75 192.168.75.1 YES NVRAM up down
04-19-2011 07:03 AM
the syntax here is sh vlan-sw br
Regards.
04-19-2011 07:21 AM
Thank you. That solves this issue!
Cheers!
