setting up vpdn on 2600 to connect ISP
OneCiscoGuy
I have configured VPDN/Dialer on router 2600 to connect to our ISP via Fibre Optics modem but its simply not connecting. I need someone to help out please. I'm new to this, so need a clear guide.
The router consists of 3 interfaces
- Inter fa0/0 = 10.0.0.6 255.255.255.248 (LAN 1)
- Inter fa0/1 = IP is unassigned (interface connected to Fibre Optics modem)
- Inter e1/0 = 192.168.200.1 255.255.255.0 (LAN 2)
The connection is planned to run like this:
LAN1 & LAN2 (Inter fa0/0 & Inter e1/0) <-> Inter fa0/1 <-> Dialer1 <-> Modem <-> ISP <-> Internet.
The Modem will just server as mere "modem" or just a bridge, as the actual routing is configured on "dialer interface" in the router.
We're not using a dedicated IP address to link to ISP but a public one.
After configuring the interfaces, VPDN, dialer interface, NAT, access-list, ISP's assigned username/password, etc I'm simply not connecting to our ISP, even when I do a ping. The ISP's IP address which we're pinging is 118.23.8.80
What am I missign out? How do I connect the dots here?
Below are the results for Running config, Ping, and Debug:
Running Config:
Router1#show running-config
Building configuration...
Current configuration : 3083 bytes
! Last configuration change at 17:39:43  Sun Apr 17 2011
version 12.3
hostname Router1
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
logging monitor errors
enable secret 5 xxxxxxxxxxx
clock timezone
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip name-server 10.1.1.150
ip cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface FastEthernet0/0
ip address 10.0.0.6 255.255.255.248
duplex auto
speed auto
interface FastEthernet0/1
description Uplink WAN interface, to the ISP modem
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
duplex auto
speed auto
pppoe enable
no cdp enable
interface Ethernet1/0
ip address 192.168.200.1 255.255.255.0
ip nat inside
half-duplex
interface Dialer1
description Fibre Optics WAN dialer, to the ISP server
ip address negotiated
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxx@xxx.com
ppp chap password 0 xxxxxx
ppp ipcp dns request accept
ppp ipcp address accept
router ospf 1
log-adjacency-changes
network 10.0.0.0 0.255.255.255 area 0
network 192.168.0.0 0.0.255.255 area 0
ip nat inside source list 10 interface Dialer1 overload
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 10 permit 10.1.0.0 0.0.255.255
access-list 10 permit 192.168.0.0 0.0.255.255
dialer-list 1 protocol ip permit
no cdp run
line con 0
exec-timeout 40 0
line aux 0
line vty 0 4
exec-timeout 20 0
password xxxxxx
login
line vty 5 15
exec-timeout 20 0
password xxxxxx
login
End
Ping result:
Router1#ping 118.23.8.80
Sending 5, 100-byte ICMP Echos to 118.23.8.80, timeout is 2 seconds:
Apr 17 15:36:15.142: IP: tableid=0, s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), routed via RIB
Apr 17 15:36:15.146: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, sending
Apr 17 15:36:15.146: NAT: dialer not up for Dialer1, no translation, dial and drop
Apr 17 15:36:15.146: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, encapsulation failed.
Apr 17 15:36:17.142: IP: tableid=0, s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), routed via RIB
Apr 17 15:36:17.142: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, sending
Apr 17 15:36:17.142: NAT: dialer not up for Dialer1, no translation, dial and drop
Apr 17 15:36:17.142: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, encapsulation failed.
Apr 17 15:36:19.142: IP: tableid=0, s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), routed via RIB
Apr 17 15:36:19.142: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, sending
Apr 17 15:36:19.142: NAT: dialer not up for Dialer1, no translation, dial and drop
Apr 17 15:36:19.142: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, encapsulation failed
Apr 17 15:36:19.202: IP: s=10.0.10.1 (local), d=224.0.0.5 (FastEthernet0/0), len76, sending broad/multicast
Apr 17 15:36:19.202: IP: s=10.0.1.1 (local), d=224.0.0.5 (FastEthernet0/0.1), len 76, sending broad/multicast
Apr 17 15:36:19.202: IP: s=10.1.1.1 (local), d=224.0.0.5 (FastEthernet0/0.2), len 76, sending broad/multicast
Apr 17 15:36:19.206: IP: s=10.1.12.1 (local), d=224.0.0.5 (FastEthernet0/0.3), len 76, sending broad/multicast
Apr 17 15:36:19.206: IP: s=10.1.13.1 (local), d=224.0.0.5 (FastEthernet0/0.4), len 76, sending broad/multicast
Apr 17 15:36:19.206: IP: s=10.1.14.1 (local), d=224.0.0.5 (FastEthernet0/0.5), len 76, sending broad/multicast.
Apr 17 15:36:21.142: IP: tableid=0, s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), routed via RIB
Apr 17 15:36:21.142: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, sending
Apr 17 15:36:21.142: NAT: dialer not up for Dialer1, no translation, dial and drop
Apr 17 15:36:21.142: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, encapsulation failed.
Apr 17 15:36:23.142: IP: tableid=0, s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), routed via RIB
Apr 17 15:36:23.142: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, sending
Apr 17 15:36:23.142: NAT: dialer not up for Dialer1, no translation, dial and drop
Apr 17 15:36:23.142: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, encapsulation failed.
Success rate is 0 percent (0/5)
The Debug result:
Apr 17 15:59:34.926: CEF: background resolution thread state:
Apr 17 15:59:34.926: Thread fast_thread: Empty
Apr 17 15:59:34.926: Thread todothread: Empty
Apr 17 15:59:34.926: Thread slow_thread: Empty
Apr 17 15:59:35.926: CEF: background resolution thread state:
Apr 17 15:59:35.926: Thread fast_thread: Empty
Apr 17 15:59:35.926: Thread todothread: Empty
Apr 17 15:59:35.926: Thread slow_thread: Empty
Apr 17 15:59:36.302: SNMP: HC Timer 82C875A8 fired
Apr 17 15:59:36.302: SNMP: HC Timer 82C875A8 rearmed, delay = 5000
Apr 17 15:59:36.362: IP: tableid=0, s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), routed via RIB
Apr 17 15:59:36.362: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, sending
Apr 17 15:59:36.362: NAT: dialer not up for Dialer1, no translation, dial and drop
Apr 17 15:59:36.362: Di1 DDR: ip (s=10.1.12.1, d=118.23.8.80), 100 bytes, outgoing interesting (ip PERMIT)
Apr 17 15:59:36.362: DDR: 45000064 00910000 FF013097 0A010201 76170858 080041B2
Apr 17 15:59:36.366: DDR: 001D0000 00000000 4D86EEF4 ABCDABCD ABCDABCD ABCDABCD
Apr 17 15:59:36.370: Di1 DDR: dialer_fsm_idle()
Apr 17 15:59:36.370: Di1 DDR: Cannot place call, no dialer string set
Apr 17 15:59:36.370: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, encapsulation failed
Apr 17 15:59:36.482: crm_send_periodic_update
Apr 17 15:59:36.642: SNMP: HC Timer 82C2DFB4 fired
Apr 17 15:59:36.642: SNMP: HC Timer 82C2DFB4 rearmed, delay = 20000.
Apr 17 15:59:36.930: CEF: background resolution thread state:
Apr 17 15:59:36.930: Thread fast_thread: Empty
Apr 17 15:59:36.930: Thread todothread: Empty
Apr 17 15:59:36.930: Thread slow_thread: Empty
Apr 17 15:59:37.934:
Apr 17 15:59:37.934: Rudpv1 Sent: Pkts 0,  Data Bytes 0,  Data Pkts 0
Apr 17 15:59:37.934: Rudpv1 Rcvd: Pkts 0,  Data Bytes 0,  Data Pkts 0
Apr 17 15:59:37.938: Rudpv1 Discarded: 0,  Retransmitted 0
Apr 17 15:59:37.938: CEF: background resolution thread state:
Apr 17 15:59:37.938: Thread fast_thread: Empty
Apr 17 15:59:37.938: Thread todothread: Empty
Apr 17 15:59:37.938: Thread slow_thread: Empty
Apr 17 15:59:38.358: IP: tableid=0, s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), routed via RIB
Apr 17 15:59:38.358: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, sending
Apr 17 15:59:38.358: NAT: dialer not up for Dialer1, no translation, dial and drop
Apr 17 15:59:38.358: Di1 DDR: ip (s=10.1.12.1, d=118.23.8.80), 100 bytes, outgoing interesting (ip PERMIT)
Apr 17 15:59:38.358: DDR: 45000064 00920000 FF013096 0A010201 76170858 080039E5
Apr 17 15:59:38.362: DDR: 001D0001 00000000 4D86F6C0 ABCDABCD ABCDABCD ABCDABCD
Apr 17 15:59:38.366: Di1 DDR: dialer_fsm_idle()
Apr 17 15:59:38.366: Di1 DDR: Cannot place call, no dialer string set
Apr 17 15:59:38.366: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, encapsulation failed
Apr 17 15:59:38.942: CEF: background resolution thread state:
Apr 17 15:59:38.942: Thread fast_thread: Empty
Apr 17 15:59:38.942: Thread todothread: Empty
Apr 17 15:59:38.942: Thread slow_thread: Empty
Apr 17 15:59:39.202: OSPF: Send hello to 224.0.0.5 area 0 on FastEthernet0/0 from 10.0.10.1
Apr 17 15:59:39.202: IP: s=10.0.10.1 (local), d=224.0.0.5 (FastEthernet0/0), len76, sending broad/multicast
Apr 17 15:59:39.202: OSPF: Send hello to 224.0.0..5 area 0 on FastEthernet0/0.1 from 10.0.1.1
Apr 17 15:59:39.202: IP: s=10.0.1.1 (local), d=224.0.0.5 (FastEthernet0/0.1), len 76, sending broad/multicast
Apr 17 15:59:39.206: OSPF: Send hello to 224.0.0.5 area 0 on FastEthernet0/0.2 from 10.1.1.1
Apr 17 15:59:39.206: IP: s=10.1.1.1 (local), d=224.0.0.5 (FastEthernet0/0.2), len 76, sending broad/multicast
Apr 17 15:59:39.210: OSPF: Send hello to 224.0.0.5 area 0 on FastEthernet0/0.3 from 10.1.12.1
Apr 17 15:59:39.210: IP: s=10.1.12.1 (local), d=224.0.0.5 (FastEthernet0/0.3), len 76, sending broad/multicast
Apr 17 15:59:39.210: OSPF: Send hello to 224.0.0.5 area 0 on FastEthernet0/0.4 from 10.1.13.1
Apr 17 15:59:39.210: IP: s=10.1.13.1 (local), d=224.0.0.5 (FastEthernet0/0.4), len 76, sending broad/multicast
Apr 17 15:59:39.214: OSPF: Send hello to 224.0.0.5 area 0 on FastEthernet0/0.5 from 10.1.14.1
Apr 17 15:59:39.214: IP: s=10.1.14.1 (local), d=224.0.0.5 (FastEthernet0/0.5), len 76, sending broad/multicast
Apr 17 15:59:39.950: CEF: background resolution thread state:
Apr 17 15:59:39.950: Thread fast_thread: Empty
Apr 17 15:59:39.950: Thread todothread: Empty
Apr 17 15:59:39.950: Thread slow_thread: Empty
Apr 17 15:59:40.358: IP: tableid=0, s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), routed via RIB
Apr 17 15:59:40.358: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, sending
Apr 17 15:59:40.358: NAT: dialer not up for Dialer1, no translation, dial and drop
Apr 17 15:59:40.358: Di1 DDR: ip (s=10.1.12.1, d=118.23.8.80), 100 bytes, outgoing interesting (ip PERMIT)
Apr 17 15:59:40.358: DDR: 45000064 00930000 FF013095 0A010201 76170858 08003214
Apr 17 15:59:40.362: DDR: 001D0002 00000000 4D86FE90 ABCDABCD ABCDABCD ABCDABCD
Apr 17 15:59:40.366: Di1 DDR: dialer_.fsm_idle()
Apr 17 15:59:40.366: Di1 DDR: Cannot place call, no dialer string set
Apr 17 15:59:40.366: IP: s=10.1.12.1 (local), d=118.23.8.80 (Dialer1), len 100, encapsulation failed
Apr 17 15:59:40.814: %AMDP2_FE-5-LOSTCARR: Ethernet1/0 cable/transceiver problem?
samavedula_rama
Okay. I see the traffic sourced from 10.1.12.1 . Did you try to source it from 192.168.xx.xx ?? Because I see, there is no NAT applied on that FE interface.
And on ISP facing FE interface, may be a pppoe-client dial-pool-number 1 may help.
Thanks for the response, but the 10.1.12.1 is a subinterface configured in the router. I'm not pinging from a client under this interface but rather pinging directly from the router's console to the ISP.
I've added the NAT on the interface fa0/0 as you suggested,
and.........
I added this as well but its not connecting either.
When I ping the ISP, below are the error message it returns every 10 seconds or there about:
Apr 19 16:02:21.286: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
Apr 19 16:02:21.294: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Apr 19 16:02:21.334: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
Apr 19 16:02:21.338: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down.....
Success rate is 0 percent (0/5) Router1#ping 118.23.8.80
