Cisco 6500/6509 with Sup 720-3B Ports
Hamidsattarrana
Hi All! Hope you guys are well.
We have 6509-E with SUP720-3B. The supervisor engine has one Ethernet port.
It also has Card Type: WS-X6548-GE-45AF.
My question is what is the purpose of Ethernet port on Supervisor Engine, Is it uplink etc? In fact, I can performed NAT and all other things on the ports come with WS-X6548-GE-45AF?
Hello @Hamidsattarrana ,
Catalyst 6500 implements routed interface and routed subinterface using a VLAN, they are emulated. The VLAN used is called an internal VLAN.
However, try to use only SVIs on your Catalyst 6500 and have the downstream port connected to an external device acting as access layer switch.
In this way you should be able to perform your tests.
Instead of connecting gi0/3 to gi0/4 of the same device.
Hope to help
Giuseppe
8 Replies 8
the SUP720-3B should actually have TWO GigabitEthernet ports, which indeed are uplink ports. These ports are fully configurable. Check the datasheet linked below:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/product_data_sheet09186a0080159856.html
But what if I terminate uplink from ISP into Card WS-X6548-GE-45AF. And make 1/48 outside NAT interface and 1/47.300 inside NAT interface. And then connect the 1/47.300 interface with 1/46 (Trunk Link with allowed Vlan 300). And 1/45 as access port. Just for testing purpose, I am making this scenerio. DHCP is also configured for Vlan 300.
Actually I have configured the above scenerio. But when I tried to configure vlan 300. I am getting the following error.
VLAN id: 300 is an internal vlan id - cannot use it to create a VTP VLAN.
Please Guide.
Joseph W. Doherty
Those ports (there should be two), on a sup720, are really intended more as management ports.  You can generally use them as edge ports, but they often will not work/perform as well as some line card ports.  (BTW, the sup32's supervisor ports, were designed for high performance as uplinks.)
Diagram 6509 Uploaded.jpg Hi!
I am configuring Cisco 6509 as Core/Edge device.
On gi 0/3 I have created sub-interface int gig 0/3.300 with an IP address of 192.168.32.1. Also DHCP server is configured.
I want to terminate Gi 0/3 physically to Gi 0/4.
Gi 0/4 should be Trunk link with allowed vlan 300.
But after creating Sub-Interface for Vlan 300, I am not able to create Vlan 300 on the same switch.
Error: vlan id: 300 is an internal vlan id - cannot use it to create a vtp vlan.
if i delete Gi 0/4.300 subinterface then I can create Vlan 300.
Basically I want to use 6509 as Edge Router and and also Core-SW for all other access switches. Kindly check the diagram and suggest.
Thanks & Regards,
Hamid
Hope to help
Giuseppe
Thanks for the suggestion. It's working via SVI method.
One more thing I would like to ask. I have created Interface Vlan 300 but when I am trying to apply service policy on this interface. I am getting the following error. Any idea?
Configuarion:
Interface Vlan 300
service-policy output VOIP-POLICY
Error after executing above command:
NBAR/STILE is not supported on this platform,Policymap rejected!
VOIP Policy Configurations:
class-map VOIP
match protocol rtp audio
exit
policy-map VOIP-POLICY
match class VOIP
priority 10000
exit
Interface Vlan 300
Thanks.
the error message says you cannot use NBAR that is the feature invoked when doing a match protocol
instead of this use an extended ACL for a range of destination UDP ports 16000 to 32000.
Hope to help
Giuseppe
As Giuseppe notes, NBAR isn't supported on the sup720.
What he also suggests may, or may not, be exactly the same as the NBAR match statement.  (Some NBAR statements do much deeper matching/analysis than any ACL can, some, though, are really no more than a "pretty face" on an ACL.)
I recall the only 6500 supervisor that supported a variant/flavor of NBAR was the sup32 PISA.
