Cisco 6509- Image is supposed to support CAR- comes up with error.
gregwoodson
Im using image s72033-pk9sv-mz.122-18.SXD7b.bin on a 6509.  I get the following error when trying to rate-limit an interface:
"Rate-limit command is not supported in hardware  use service-policy command"
Does anyone have insight as to why rate limiting is not supported?  Is there a different version of code I should be looking at?
6 Replies 6
Jon Marshall
Which interface are you trying to apply rate-limiting ie.
1) is it a L2 switchport or a L3 routed port
2) which linecard are you trying to apply it on
what is the actual command you are using ?
Jon
on a VLAN Actually (so layer 3)- I have not tried it on a physical routing interface or switchport interface.  The exact configs are:
rate-limit input 10000000 512000 512000 conform-action transmit exceed-action drop
rate-limit output 10000000 512000 512000 conform-action transmit exceed-action drop
Hello Greg,
I would say that the error message is clear
you should use a service-policy that is modular QoS
if in a policy-map you invoke the police command you are actually emulating CAR with modular QoS
policy-map police-all
class class-default
police 10000000 ! other parameters here
int vlan XX
service-policy in police-all
Hope to help
Giuseppe
So why would the Software Advisor say that the image supports CAR, but you have to emulate it using Modular QoS?  It would be much simpler for me to use the rate-limit command.
Greg
Because it does support CAR just not on all interface types.
Jon
Is there something somewhere that shows what types of interfaces are supported and which arent?  That's actually very useful information- I just want to make sure we are doing this the correct way to eliminate problems.
