Cisco 6509 Module Guide
Hamidsattarrana
HI!
I need some information regarding Cisco 6509-E Modules. Can someone tell me do the below mentioned module support NAT?
WS-X6548-GE-45AF
WS-X6148A-GE-45AF
Jon Marshall
On the 6500 it is the supervisor that supports NAT not the individual modules.
Jon
my sup2Ts support it and i believe the sup720s support it too depending on image
(config)#ip nat ?
create Create flow entries
inside Inside address translation
log NAT Logging
outside Outside address translation
pool Define pool of addresses
service Special translation for application using non-standard port
translation NAT translation entry configuration
Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G
48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-TX
2 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-TX
Thanks for the Info. I want to terminate 3 ISPs into Cisco 6509-E.
Physically how can I do that?
Previously I am using a Cisco 3750. All ISPs are going to Switch-ports then connected with router via Sub-Interfaces.
I am new to Cisco 6509-E.
One more thing I want to know how can I check if switch is working fine? We are planning to purchase it.
Giuseppe Larosa
Hello @Hamidsattarrana ,
just to add to Jon's answer you configure NAT on SVI interfaces , this becomes an action in the TCAM table.
Being the Cat6500 a distributed platform the supervisor buid the master copy of TCAM table and then sends it to the line cards that have a CFC or DFC module.
in your case the linecard 6148 is likely able to connect only to 32 Gbps the shared bus
usually the linecards for sup720 should be something like 6xab  with x=7 or x=8 these ones are the best as they can host the DFC and have a local copy of the TCAM table.
So I would put users on linecard 6148 and servers on linecard 6748
Hope to help
Giuseppe
