Cisco 7200 router doesn't respond to snmpget/snmpwalk, or sends traps to Nagios
nashpaz01
Please help! I've been beating my brains out trying to config a router 10.10.1.2 to receive and send snmp packets/traps with a Nagios server 192.168.1.2 , using these instructions:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-3_7_JA/configuration/guide/i1237sc/s37snmp.html
On the Nagios server 192.168.1.2 (Centos 6.4) I tried these commands and got nothing:
[root@tamaras-nagios ~]# snmpwalk -Os -c public -v 1 10.10.1.2
Timeout: No Response from 10.10.1.2
[root@tamaras-nagios ~]# snmpget -mALL -v2c -cpublic 10.10.1.2 all
Timeout: No Response from 10.10.1.2.
Also, traps aren't being received :-( There is a firewall between the two, but I've gone over its rules and there shouldn't be a problem. There's a ping from the Nagios to the Router and vice versa.
The Nagios works fine with other stations and network devices, so I imagine I've missed something in the router config. I'm going for a v2c snmp config but I don't mind v1 if it'll work.
These are the router specs:
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 15.0(1)M, RELEASE SOFTWARE (fc2)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.2(25)S9, RELEASE SOFTWARE (fc1)
(some chosen lines from the running config):
access-list 18 permit 192.168.1.2
snmp-server community public RO
snmp-server community ronni RW
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps gatekeeper
snmp-server enable traps eigrp
(all the snmp traps are enabled so I won't paste the whole list)
snmp-server host 192.168.1.2 version 2c public udp-port 161
snmp-server manager
(output of show snmp host):
Notification host: 192.168.1.2        udp-port: 161   type: trap
user: public    security model: v2c
Notification host: 192.168.1.2        udp-port: 162   type: trap
Chassis: 30929908
0 SNMP packets input
    0 Bad SNMP version errors
    0 Unknown community name
    0 Illegal operation for community name supplied
    0 Encoding errors
    0 Number of requested variables
    0 Number of altered variables
    0 Get-request PDUs
    0 Get-next PDUs
    0 Set-request PDUs
    0 Input queue packet drops (Maximum queue size 1000)
39174 SNMP packets output
    0 Too big errors (Maximum packet size 1500)
    0 No such name errors
    0 Bad values errors
    0 General errors
    0 Response PDUs
    23567 Trap PDUs
SNMP Dispatcher:
   queue 0/75 (current/max), 0 dropped
SNMP Engine:
   queue 0/1000 (current/max), 0 dropped
SNMP logging: enabled
    Logging to 192.168.1.2.162, 0/10, 7 sent, 0 dropped.
    Logging to 192.168.1.2.161, 0/10, 4 sent, 0 dropped.
SNMP Manager-role output packets
    0 Get-request PDUs
    0 Get-next PDUs
    0 Get-bulk PDUs
    0 Set-request PDUs
    15607 Inform-request PDUs
    2786 Timeouts
    0 Drops
SNMP Manager-role input packets
    0 Inform request PDUs
    0 Trap PDUs
    0 Response PDUs
    0 Responses with errors
SNMP informs: enabled
    Informs in flight 0/25 (current/max)
        11704 sent, 0 in-flight, 2276 retries, 508 failed, 11196 dropped
nashpaz01
Figured it out line by line.
I had a restriction on the interface:
control-plane host
 management-interface FastEthernet0/0 allow ssh telnet
once I added:
management-interface FastEthernet0/0 allow snmp
and all is well :-)
