Cisco 7200 Series NPE-G2 BGP routing table
Sharin Taib
Hi, I was wondering if anyone knew the rough figures that a NPE-G2 is able to hold for the BGP routing table?
378475 network entries using 51472600 bytes of memory
378482 path entries using 21194992 bytes of memory
63008/63003 BGP path/bestpath attribute entries using 8065024 bytes of memory
BGP using 82975730 total bytes of memory
Are these 3 memories different memory allocated or are they are a sub-set of each other?
If a NPE-G2 has 1GB RAM, does it mean that the routing table limit is depending on the RAM availability?
Giuseppe Larosa
Hello Sharin,
the total memory used by BGP is reported in the last line
And it is the sum of the first three reported items
51472600 bytes
21194992 bytes
  8065024 bytes
Yes because it is a software based router. C7200 with NPE G2 are still used as BGP Route Reflector Servers in Service provider networks
The greatest limitation of a C7200 is the forwarding plane with NPE G2 that is able to switch 2,000,000 pps.
Hope to help
Giuseppe
