Cisco 7200 VXR SFP Error :(
ahmad82pkn
Level 3
Level 3
Hi i just installed SFP module in Cisco VXR 7204  PA-POS-2OC3 port adapter
it detected the module fine, but when i enable the POS interface
i get following error.
what to do?
Mar  7 17:30:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface POS1/1, changed state to up
Mar  7 17:30:41: %GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port 1 has bad crc
Mar  7 17:30:41: %GBIC_SECURITY-4-EEPROM_SECURITY_ERR: GBIC in POS1/1 failed security check
Mar  7 17:30:51: %GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port 1 has bad crc
Mar  7 17:30:51: %GBIC_SECURITY-4-EEPROM_SECURITY_ERR: GBIC in POS1/1 failed security check
Mar  7 17:30:52: %LINEPROTO-5-UPDOWN: Line protocol on Interface POS1/1, changed state to down
Mar  7 17:31:04: %LINK-5-CHANGED: Interface POS1/1, changed state to administratively down
Mar  7 17:31:04: %ENTITY_ALARM-6-INFO: ASSERT INFO PO1/1 Physical Port Administrative State Down
Interface POS1/1
dma mode : push
Hardware is Packet over SONET (hwidb=0x40D0330)
fastsend            = 0x0058BBD0, turbofs    = 0x053C7F30
multicast fs        = 0x00000000
SFP security failure
Before i enabled the interface i could see
Interface POS1/1
dma mode : push
fastsend            = 0x0058BBD0, turbofs    = 0x05889A68
SFP is TRPD03I1AAYS-FJ OC3 SM-IR
any suggestion? is this bad SFP? do i need to buy newone? or if i can fix it?
6 Replies 6
Leo Laohoo
What kind of SFP is this?
SM-IR
Neeraj Arora
Level 3
Level 3
These messages generally come when a 3rd party SFP is used which Cisco device is not able to validate using its CRC present in EEPROM.
you can try the following commands but keep in mind that a lot of times these commands did not make much difference:
switch(config)# service unsupported-transceiver
switch(config)# no errdisable detect cause gbic-invalid
try and let us know if they work for you
Both commands not recognized , may be my IOS is old.
c7200p-ik91s-mz.
i am asking vendor to send me new module, lets see if it helps.
Tell the vendor to RE-FLASH the IDPROM for Cisco.
Actually the SFP i was using were old from my inventory, i dont know from where i got that.
New one are working fine so i am back on track. here is what my new SFP shows .
Interface POS1/1
dma mode : push
SFP is SFP-OC3-IR1-GT OC3 SM-IR
Thank you everyone for your inputs:)
