Cisco 7204 100% CPU with OC3 module?
ahmad82pkn
Level 3
Level 3
i bought new RF Cisco 7204VXR NPE-G1.
As soon i enable OC3 module ( PA-POS-OC3SMI) CPU of the router shoot to 100%, and if i reboot the router, it wont comeback not even on Console.
I had to remove the POS card and then boot router and then hot insert the module.
so i put the command
int pos 4/0
loopback internal
as soon igave this command, CPU dropped down to normal.
Whats the deal here? now i need to activate the circuit on this POS interface, but as soon i remove loopback internal command , CPU shoots to 100%
Although CPU sorted dont show any process causing it.
any idea?
    9999999999999999999999999999999999999999999999999999999999
    5555533333111114444444444777774444466666777775555566666444
100 *****                    *****     ********************
90 ************************************************************
80 ************************************************************
70 ************************************************************
60 ************************************************************
50 ************************************************************
40 ************************************************************
30 ************************************************************
20 ************************************************************
10 ************************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
CPU utilization for five seconds: 95%/96%; one minute: 95%; five minutes: 79%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
120         460   2738070          0  0.16%  0.19%  0.17%   0 RBSCP Background
   2       14840     54802        270  0.08%  0.03%  0.01%   0 Load Meter
216        1008    275696          3  0.08%  0.02%  0.00%   0 NTP
107       14252    547872         26  0.08%  0.10%  0.11%   0 DHCPD Receive
212        1104     17867         61  0.08%  0.01%  0.00%   0 PDU DISPATCHER
211        3568     35725         99  0.08%  0.03%  0.00%   0 IP SNMP
  56          76    274011          0  0.08%  0.00%  0.00%   0 ISA Common Helpe
207         716   2738358          0  0.08%  0.12%  0.13%   0 CCPROXY_CT
  93          60    273936          0  0.08%  0.01%  0.00%   0 Socket Timers
  40         772    275060          2  0.08%  0.04%  0.02%   0 Per-Second Jobs
104         120    273967          0  0.08%  0.01%  0.00%   0 RUDPV1 Main Proc
  68       16716    135866        123  0.08%  0.18%  0.10%   0 IP Input
  12          20    273971          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  14           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  13          44    273971          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  11           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  17           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  18           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  10           0      4568          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  15           0         1          0  0.00%  0.00%  0.00%   0 IPC BackPressure
   9           4         2       2000  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
  22           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  16      171340    274564        624  0.00%  0.00%  0.00%   0 EnvMon
  19        5476     66968         81  0.00%  0.01%  0.00%   0 ARP Input
  25          40         4      10000  0.00%  0.00%  0.00%   0 Entity MIB API
  26          28        37        756  0.00%  0.00%  0.00%   0 EEM ED Syslog
  27          92     68502          1  0.00%  0.00%  0.00%   0 HC Counter Timer
  28           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  20           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  30           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  31           0         1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  21           4         2       2000  0.00%  0.00%  0.00%   0 AAA high-capacit
  23           4         1       4000  0.00%  0.00%  0.00%   0 Policy Manager
  34           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  35           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
ahmad82pkn
Level 3
Level 3
ok issue resolved:)
i need to add this command under POS interface
pos scramble-atm
thank you for viewing this thread
