How to use HTTPS with TCL on a 881-W router?
Mark Wright
I have been able to get https to work from IOS command using copy or more. I have also able to get http gets and posts to work form TCL scripts.
But what I need to get to work from TCL is Secure HTTP (https). I am using a 881-W Router.
The http.tcl file on the router history shows that SSL suport added.
# Rough version history:
# 1.0     Old http_get interface
# 2.0     http:: namespace and http::geturl
# 2.1     Added callbacks to handle arriving data, and timeouts
# 2.2     Added ability to fetch into a channel
# 2.3     Added SSL support, and ability to post from a channel
#     This version also cleans up error cases and eliminates the
#     "ioerror" status in favor of raising an error
# 2.4     Added -binary option to http::geturl and charset element
#     to the state array.
Does anyone have been able to get this to work?
If so do you have an example TCL script using https?
Mark Wright
0 Replies 0
