Cisco 7206 IOS upgradation Issue
sanjeevmahadani
Guys,
Pls. suggest, unable to upload IOS for Cisco 7206 router, below is the error.
rommon 10 > boot system tftp c7200-is-mz.124-13d.bin 192.168.1.3
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
loadprog: error - on file open
boot: cannot load "system tftp c7200-is-mz.124-13d.bin 192.168.1.3"
Reg
sanjeev
Raju Sekharan
where is your image located?
if it is not present in the bootflash or compact flash of the router, you need to download this locally to bootflash or compact flash
1. You can check the availble devices in the router by using :dev command"
Example
rommon 1 > dev
     Devices in device table:
             id  name
     bootflash:  boot flash
         slot0:  PCMCIA slot 0
         slot1:  PCMCIA slot 1
        eprom:  EPROM
     rommon 2 >
2. Then you can check if you have a vlaid image availbe in any of these devices
dir bootflash:
dir slot0:
dir slot1:
3. if you have the image preset in any of the devices, use that location to boot the image
ex:
rommon> boot bootflash:
4. if you don't have the valid image prestn in any of the devices, use tftpdnld process to download the image to any bootflash: or compact flash:
Here is the process
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
Then you boot the router using step 3
