Cisco 7206 PPPoE B-RAS and framed-route attribute
Blaster79
Hi all,
i'm configuring a Cisco 7206 NPE-G2 as B-RAS for PPPoE over a Gigabit Ethernet interface. Everything is ok but i'm having problems when i try to pass the framed-route attribute from the RADIUS to assign a /29 subnet to a PPPoE client, the 7206 seems to skip it and no route is installed in the routing table.
This is the configuration:
upgrade fpd auto
version 15.0
service password-encryption
hostname 7206-BRAS
boot-start-marker
boot-end-marker
enable secret 5 xxxxx
aaa new-model
aaa group server radius RADIUS1
server-private xx.xx.xx.xx auth-port 1812 acct-port 1813 key 7 xxxxx
aaa authentication login default local
aaa authentication ppp default group RADIUS1
aaa authorization network default group RADIUS1 local
aaa accounting delay-start
aaa accounting update periodic 10
aaa accounting network default
action-type start-stop
group RADIUS1
aaa session-id common
clock timezone CEST 1
ip source-route
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
username admin password 7 xxx
bba-group pppoe PPPOE
virtual-template 1
vendor-tag circuit-id service
vendor-tag dsl-sync-rate service
sessions per-mac limit 1
interface Loopback0
ip address 10.1.0.254 255.255.255.0
interface GigabitEthernet0/1
ip address xx.xx.xx.xx 255.255.255.252
duplex full
speed 1000
media-type rj45
negotiation auto
interface FastEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex full
speed 1000
media-type rj45
negotiation auto
interface GigabitEthernet0/3
no ip address
duplex auto
speed 1000
media-type sfp
negotiation auto
vlan-range dot1q 1 4094
  pppoe enable group PPPOE
  exit-vlan-config
interface Virtual-Template1
mtu 1492
ip unnumbered Loopback0
ip tcp adjust-mss 1452
peer default ip address pool POOL1
no keepalive
ppp authentication chap pap
ppp ipcp address accept
router eigrp 1
network xx.xx.xx.xx xx.xx.xx.xx
redistribute connected
redistribute static
ip local pool POOL1 10.1.0.1 10.1.0.253
ip forward-protocol nd
no ip http server
no ip http secure-server
radius-server attribute 8 include-in-access-req
radius-server attribute nas-port format d
radius-server attribute nas-port-id include circuit-id
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
This is what i see in the debug, starting from the access-accept packet from the radius:
Mar 28 09:50:25.887: RADIUS: Received from id 1645/165 xx.xx.xx.xx:1812, Access-Accept, len 54
Mar 28 09:50:25.887: RADIUS:  authenticator 83 89 7D B3 16 5E C0 B1 - 19 3D 50 F2 C8 92 A4 61
Mar 28 09:50:25.887: RADIUS:  Service-Type        [6]   6   Framed                    [2]
Mar 28 09:50:25.887: RADIUS:  Framed-Protocol     [7]   6   PPP                       [1]
Mar 28 09:50:25.887: RADIUS:  Framed-IP-Address   [8]   6   10.1.0.50
Mar 28 09:50:25.887: RADIUS:  Framed-Route        [22]  16  "10.1.1.0/29"
Mar 28 09:50:25.887: RADIUS(00004122): Received from id 1645/165
Mar 28 09:50:25.887: ppp957 PPP: Received LOGIN Response PASS
Mar 28 09:50:25.887: ppp957 PPP AUTHOR: Author Data Available
Mar 28 09:50:25.887: ppp957 PPP: Receive Attrs from[authen] Keep[LCP] MERGE
Mar 28 09:50:25.887: ppp957 PPP: Keep Attr: service-type         2 [Framed]
Mar 28 09:50:25.887: ppp957 PPP: Keep Attr: Framed-Protocol      1 [PPP]
Mar 28 09:50:25.887: ppp957 PPP: Skip Attr: addr                 10.1.0.50
Mar 28 09:50:25.887: ppp957 PPP: Skip Attr: route                "10.1.1.0 255.255.255.248"
Mar 28 09:50:25.887: ppp957 PPP: Phase is FORWARDING, Attempting Forward
Mar 28 09:50:25.891: ppp957 PPP: Receive Attrs from[SSS] Keep[NCPs] MERGE
Mar 28 09:50:25.891: ppp957 PPP: Skip Attr: service-type         2 [Framed]
Mar 28 09:50:25.891: ppp957 PPP: Skip Attr: Framed-Protocol      1 [PPP]
Mar 28 09:50:25.891: ppp957 PPP: Keep Attr: addr                 10.1.0.50
Mar 28 09:50:25.891: ppp957 PPP: Skip Attr: route                "10.1.1.0 255.255.255.248"
Mar 28 09:50:25.895: [957]PPPoE 2959: State LCP_NEGOTIATION    Event SSS CONNECT LOCAL
Mar 28 09:50:25.895: [957]PPPoE 2959: Segment (SSS class): UPDATED
Mar 28 09:50:25.895: [957]PPPoE 2959: Segment (SSS class): BOUND
Mar 28 09:50:25.895: [957]PPPoE 2959: data path set to Virtual Acess
Mar 28 09:50:25.895: [957]PPPoE 2959: State LCP_NEGOTIATION    Event SSM UPDATED
Mar 28 09:50:25.895: AAA/BIND(00004122): Bind i/f Virtual-Access1.1
Mar 28 09:50:25.895: Vi1.1 PPP: Phase is AUTHENTICATING, Authenticated User
Mar 28 09:50:25.895: Vi1.1 LCP AUTHOR: Process LCP Author Data
Mar 28 09:50:25.895: Vi1.1 LCP AUTHOR: Process Attr: service-type
Mar 28 09:50:25.895: Vi1.1 LCP AUTHOR: Process Attr: Framed-Protocol
Mar 28 09:50:25.895: Vi1.1 LCP AUTHOR: Authorization succeeded
Mar 28 09:50:25.895: Vi1.1 CHAP: O SUCCESS id 1 len 4
Mar 28 09:50:25.895: [957]PPPoE 2959: AAA get dynamic attrs
Mar 28 09:50:25.895: Vi1.1 PPP: Store Author Attr: addr
Mar 28 09:50:25.895: Vi1.1 PPP: Phase is UP
Mar 28 09:50:25.895: Vi1.1 IPCP: Protocol configured, start CP. state[Initial]
Mar 28 09:50:25.895: Vi1.1 IPCP: Event[OPEN] State[Initial to Starting]
Mar 28 09:50:25.895: Vi1.1 IPCP: O CONFREQ [Starting] id 1 len 10
Mar 28 09:50:25.895: Vi1.1 IPCP:    Address 10.1.0.254 (0x03061F2C73FE)
Mar 28 09:50:25.895: Vi1.1 IPCP: Event[UP] State[Starting to REQsent]
Mar 28 09:50:25.895: [957]PPPoE 2959: State PTA_BINDING    Event STATIC BIND RESPONSE
Mar 28 09:50:25.895: [957]PPPoE 2959: Connected PTA
Mar 28 09:50:25.963: Vi1.1 IPCP: I CONFREQ [REQsent] id 1 len 22
Mar 28 09:50:25.963: Vi1.1 IPCP:    Address 0.0.0.0 (0x030600000000)
Mar 28 09:50:25.963: Vi1.1 IPCP:    PrimaryDNS 0.0.0.0 (0x810600000000)
Mar 28 09:50:25.963: Vi1.1 IPCP:    SecondaryDNS 0.0.0.0 (0x830600000000)
Mar 28 09:50:25.963: Vi1.1 IPCP AUTHOR: Start.  Her address 0.0.0.0, we want 0.0.0.0
Mar 28 09:50:25.963: Vi1.1 IPCP AUTHOR: Authorization succeeded
Mar 28 09:50:25.963: Vi1.1 IPCP AUTHOR: Done.  Her address 0.0.0.0, we want 10.1.0.50
Mar 28 09:50:25.963: Vi1.1 IPCP AUTHOR: no author-info for primary dns
Mar 28 09:50:25.963: Vi1.1 IPCP AUTHOR: no author-info for seconday dns
Mar 28 09:50:25.963: Vi1.1 IPCP: O CONFNAK [REQsent] id 1 len 22
Mar 28 09:50:25.963: Vi1.1 IPCP:    Address 10.1.0.50 (0x03061F2C7332)
Mar 28 09:50:25.963: Vi1.1 IPCP:    PrimaryDNS 8.8.8.8 (0x81061F2C7201)
Mar 28 09:50:25.963: Vi1.1 IPCP:    SecondaryDNS 8.8.4.4 (0x83061F2C7202)
Mar 28 09:50:25.963: Vi1.1 IPCP: Event[Receive ConfReq-] State[REQsent to REQsent]
Mar 28 09:50:25.967: Vi1.1 IPCP: I CONFACK [REQsent] id 1 len 10
Mar 28 09:50:25.967: Vi1.1 IPCP:    Address 10.1.0.254 (0x03061F2C73FE)
Mar 28 09:50:25.967: Vi1.1 IPCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
Mar 28 09:50:26.003: Vi1.1 IPCP: I CONFREQ [ACKrcvd] id 2 len 22
Mar 28 09:50:26.003: Vi1.1 IPCP:    Address 10.1.0.50 (0x03061F2C7332)
Mar 28 09:50:26.003: Vi1.1 IPCP:    PrimaryDNS 8.8.8.8 (0x81061F2C7201)
Mar 28 09:50:26.003: Vi1.1 IPCP:    SecondaryDNS 8.8.4.4 (0x83061F2C7202)
Mar 28 09:50:26.003: Vi1.1 IPCP AUTHOR: no author-info for primary dns
Mar 28 09:50:26.003: Vi1.1 IPCP AUTHOR: no author-info for seconday dns
Mar 28 09:50:26.003: Vi1.1 IPCP: O CONFACK [ACKrcvd] id 2 len 22
Mar 28 09:50:26.003: Vi1.1 IPCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
Mar 28 09:50:26.007: Vi1.1 IPCP: State is Open
Mar 28 09:50:26.007: Vi1.1 IPCP: Install route to 10.1.0.50
I tried also with Cisco-AVpair ip:route with the same results. What i'm doing wrong?
mavespig
Level 3
Level 3
can you paste here the radius user definition?
The attribute should be defined as:
        Framed-Route += "10.1.1.0/29 0.0.0.0"
Marco
Blaster79
Hi Marco,
actually i have:
Framed-Route = "10.1.1.0/29"
but i tried also:
Mar 28 14:03:31.391: ppp958 PPP: Skip Attr: route                "10.1.1.0 255.255.255.248 0.0.0.0"
Blaster79
I solved this by upgrading IOS image from IP BASE to ADV IP SERVICES.
