Cisco 7206VXR (NPE-G2)
Need to upgrade IOS for Cisco 7206VXR (NPE-G2) please suggest me the stable image and also please let me know if need to upgrade boot helper as well.
TRV-777-MPLS-RT1#show bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1   .. image        EDD729F8  955DD4   29  9264468 Jan 18 2000 16:50:10 -05:00 c7200p-kboot-mz.124-15.T7.bin
2   .. crashinfo    77E206C7  98E518   25   231105 Apr 21 2013 18:16:03 -04:00 crashinfo_20130421-221603
56040168 bytes available (9495832 bytes used)
TRV-777-MPLS-RT1#dir
Directory of disk2:/
    1  -rw-    31915084  Jan 18 2000 16:59:46 -05:00  c7200p-advsecurityk9-mz.124-15.T7.bin
    2  -rw-     6389760   Feb 6 2009 09:55:48 -05:00  sdm.tar
    3  -rw-     1505280   Feb 6 2009 09:56:00 -05:00  common.tar
    4  -rw-        1038   Feb 6 2009 09:56:06 -05:00  home.shtml
    5  -rw-      112640   Feb 6 2009 09:56:12 -05:00  home.tar
    6  -rw-      527849   Feb 6 2009 09:56:18 -05:00  128MB.sdf
    7  -rw-      793739   Feb 6 2009 09:56:26 -05:00  256MB.sdf
    8  -rw-     1697952   Feb 6 2009 09:56:38 -05:00  securedesktop-ios-3.1.1.45-k9.pkg
    9  -rw-      415956   Feb 6 2009 09:56:46 -05:00  sslclient-win-1.1.4.176.pkg
Hello
its not very clear why you want to upgrade and what features you need to support.  You seem to be running T train image which generally has a number of new features., and I believe 12.4 is now rather old. Perhaps you should look at 15.2 and check feature navigator and release notes to see if it has all the features you need.
i believe it is good practise to use the correct boot image too to match your chosen ios.
hope this helps
mark
