Cisco 7206VXR running 12.3(8)T suspected memory leak
turfsniffer0
Hi Guys,
We have a "core" router in our WAN that has started misbehaving. I first noticed the problem when I couldn't remotely log into the unit, we have a connection through the aux port to another 7206 on the same site and this also wouldn't allow access - although I was able to trap some logging messages that were indicating that router had no available memory:
Mar 9 17:57:39.432: %SYS-2-MALLOCFAIL: Memory allocation of 10000 bytes failed from 0x608B2E20, alignment 0
Pool: Processor Free: 3827300 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
-Process= "SNMP ENGINE", ipl= 0, pid= 147
-Traceback= 60786144 608A0598 608A3818 608B2E28 6101D310 6101D4F0 60FFAF98 60FFB27C 610223E0 60FF2140 6101A0D8 6086A888 6086A86C
%% Low on memory; try again later
To resolve we had to send a field engineer out - and in the end we had to reboot the router. We closely monitored the unit and memory utilisation appears to be steadily incrementing to the point that we have to do a manual reload every few days. The unit only has 128mb of memory, although we have other similar units running the same protocols and services, and same traffic profile and their memory utilisation sits steadily around 50%. So we actually replaced the NPE engine - which effectively changed the memory. No difference. I disabled netflow on the router and it immediately freed up 10% of the memory, but the issue still continues.
Last night I had to perform another reload, but before doing this I disabled all serial and lan interfaces and monitored memory - it was still incrementing. The dead process seems to be taking a huge chunk....also PDU dispatcher which I know is related to the SNMP engine, appears to be taking more than its fair share - especially when compared to other similar routers in our network. Here's the output of SHOW PROCESS MEMORY SORTED:
Total: 54564032, Used: 42297572, Free: 12266460
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   43774368   13289940   22984988          0          0 *Init*
   0   0  127051652  118895552   17750564     258176          0 *Dead*
   6   0  112026940  109590076    4214860     280684     767700 Pool Manager
  52   0  174701108    4322292     701796     392508          0 IP Input
137   0     597808          0     658692          0          0 CCPROXY_CT
  23   0     279536     179652     251984          0          0 ARP Input
155   0    2432936    2053688     217748          0          0 OSPF Router 140
  91   0     217744          0     210860          0          0 PPTP Mgmt
  70   0     199664          0     209548          0          0 IP RIB Update
108   0     159872          0     166756          0          0 QOS_MODULE_MAIN
116   0     275528          0     160644          0          0 Proxy Session Ap
   4   0      65580          0      90464          0          0 EDDRI_MAIN
110   0      79844          0      89728          0          0 CCVPM_HTSP
103   0   34655144    2938240      79872          0          0 TPLUS
  75   0      74904          0      74904          0          0 CEF process
136   0        188        188      60884          0          0 CC-API_VCM
140   0    1696500      48676      38780      13520          0 PIM Process
  41   0      27432        188      34164          0          0 VNM DSPRM MAIN
128   0      24892        376      30096          0          0 EM Applet Direct
   3   0      57648     161460      28272      17388          0 OSPF Hello 140
  98   0       1696          0      26580          0          0 Border Element p
   97   0       1884        188      26580          0          0 gk process
  54   0      24088       5748      25224          0          0 CDP Protocol
109   0        180          0      25064          0          0 RPMS_PROC_MAIN
146   0  449015212          0      24928          0          0 PDU DISPATCHER
143   0          0        812      24884          0          0 traffic_shape
  83   0          0          0      24884          0          0 COPS
107   0          0          0      24884          0          0 VoIP AAA
  81   0      30332        188      23260          0          0 DHCPD Receive
  31   0      16176          0      23060          0          0 Critical Bkgnd
104   2     124932     115052      20300          0          0 Virtual Exec
147   0  262494064  711485256      18040          0          0 SNMP ENGINE
  26   0      10860      15848      17744          0       3640 Entity MIB API
111   0      10472          0      17356          0          0 CCVPM_R2
  77   0     731316          0      14328          0          0 TCP Protocols
145   0   31453124   31452040      14028          0          0 IP SNMP
  65   0          0          0      12900          0          0 L2X Data Daemon
  88   0        188        188      12896          0          0 X.25 Background
  29   0        188        188      12884          0          0 Dialer event
  92   0        188        188      12884          0          0 PPTP Data
  33   0        188        188      12884          0          0 Logger
  30   0        188        188      12884          0          0 XML Proxy Client
134   0          0          0      12884          0          0 TCP Driver
   14   0          0          0      12884          0          0 Policy Manager
148   0          0          0      12884          0          0 SNMP ConfCopyPro
  44   0        188        188      12884          0          0 ATM OAM Input
  45   0        188        188      12884          0          0 ATM OAM TIMER
149   0      34448      34448      12884          0          0 SNMP Traps
  90   0          0          0      12884          0          0 L2F management d
  76   0          0   17715588      12884          0          0 TCP Timer
  73   0        188        188      12884          0          0 PPP IPCP
  72   0        188        188      12884          0          0 PPP IP Route
  32   0      84728          0      12884      17016          0 Net Background
  56   0          0          0      12884          0          0 SSS Test Client
  64   0        188        188      12884          0          0 L2TP mgmt daemon
  63   0          0          0      12884          0          0 L2X SSS manager
  55   0          0          0      12884          0          0 SSS Manager
  62   0          0          0      12884          0          0 L2X Socket proce
  59   0        376        376      12884          0          0 PPP Hooks
  61   0          0          0      12884          0          0 VPDN call manage
   0   0      12044  157917540      12044          0          0 *Sched*
100   0       6168        188      11928          0          0 LOCAL AAA
  79   0       1696          0      11580          0          0 HTTP CORE
122   0       3904       1868      10224          0          0 EM Server
  69   0        244       2224      10128          0          0 IP Background
    1   0       7528       4440       9972          0          0 Chunk Manager
  35   0    2097504    1835316       9884          0          0 Per-Second Jobs
  66   0          0       5668       9884          0       1300 EM FD Syslog
  67   0          0          0       9884          0          0 EM FD SNMP
  68   0          0          0       9884          0          0 EM FD Memory Thr
  16   0          0          0       9884          0          0 OIR Handler
  74   0        188        188       9884          0          0 Adj Manager
  11   0        212        212       9884          0          0 ATM AutoVC Perio
139   0       2936        188       9640          0          0 IGMP Input
113   0       1696          0       8580          0          0 http client proc
124   0       1696          0       8580          0          0 SAA Event Proces
127   0       1196          0       8080          0          0 trunk conditioni
119   0        812          0       7696          0          0 SYSMGT Events
150   0        564        188       7260          0          0 NTP
112   0        328          0       7212          0          0 CCSWVOICE
121   0        188        188       6904          0          0 cerf_daemon_proc
  87   0          0          0       6896          0          0 PAD InCall
114   0          0          0       6892          0          0 TACACS+
  46   0        188        188       6884          0          0 TurboACL
  80   0          0          0       6884          0          0 RARP Input
  82   0          0          0       6884          0          0 IP Cache Ager
  43   0        940        940       6884          0          0 Flash MIB Update
   86   0        188        188       6884          0          0 RBSCP Background
  84   0        188        188       6884          0          0 PPP SSS
  85   0        188        188       6884          0          0 PPP Bind
  89   0        188        188       6884          0          0 Dialer Forwarder
  42   0          0          0       6884          0          0 CES Line Conditi
  39   0          0          0       6884          0          0 SONET alarm time
  47   0        188        188       6884          0          0 AAA Server
  78   0          0          0       6884          0          0 Socket Timers
  48   0          0          0       6884          0          0 AAA ACCT Proc
  95   0          0          0       6884          0          0 bsm_xmt_proc
  96   0        188        188       6884          0          0 RLM groups Proce
  40   0          0          0       6884          0          0 POS APS Event Pr
  50   0        188        188       6884          0          0 AAA Dictionary R
  51   0          0          0       6884          0          0 AC Mgr
  34   0  157191176        188       6884          0          0 TTY Background
  49   0          0          0       6884          0          0 ACCT Periodic Pr
102   0        188        188       6884          0          0 LINE AAA
  28   0        188        188       6884          0          0 GraphIt
  27   0          0          0       6884          0          0 SERIAL A'detect
105   0        188        188       6884          0          0 VSP_MGR
106   0          0          0       6884          0          0 EM Background Pr
  71   0          0          0       6884          0          0 SNMP Timers
   24   0          0          0       6884          0          0 HC Counter Timer
  22   0          0          0       6884          0          0 IPC BackPressure
  21   0          0          0       6884          0          0 IPC Seat Manager
  20   0          0          0       6884          0          0 IPC Deferred Por
  53   0          0          0       6884          0          0 ICMP event handl
  57   0          0          0       6884          0          0 SSS Feature Mana
101   0        188        188       6884          0          0 ENABLE AAA
115   0          0          0       6884          0          0 FB/KS Log HouseK
  19   0          0          0       6884          0          0 IPC Periodic Tim
117   0        188        188       6884          0          0 RMON Recycle Pro
118   0        188        188       6884          0          0 RMON Deferred Se
  58   0          0          0       6884          0          0 SSS Feature Time
120   0        188    5744844       6884          0          0 AAA SEND STOP EV
  38   0          0          0       6884          0          0 CSP Timer
  93   0        188        188       6884          0          0 RUDPV1 Main Proc
123   0          0          0       6884          0          0 RMON Packets
  94   0          0          0       6884          0          0 bsm_timers
125   0          0          0       6884          0          0 VPDN Scal
126   0          0          0       6884          0          0 trunk conditioni
  60   0          0          0       6884          0          0 X.25 Encaps Mana
  18   0          0          0       6884          0          0 IPC Zone Manager
131   0          0          0       6884          0          0 Net Input
132   0        188        188       6884          0          0 Compute load avg
133   0      82524        512       6884          0          0 Per-minute Jobs
  17   0          0          0       6884          0          0 IPC Dynamic Cach
135   0          0          0       6884          0          0 TCP Listener
  99   0        188        188       6884          0          0 CRM_CALL_UPDATE_
  15   0          0          0       6884          0          0 EnvMon
138   0          0          0       6884          0          0 CEF Scanner
  25   0        188        188       6884          0          0 DDR Timers
  13   0        188        188       6884          0          0 AAA high-capacit
141   0          0  174614784       6884          0          0 Mwheel Process
142   0        188        188       6884          0          0 IP Flow Backgrou
  12   0        188        188       6884          0          0 ATM VC Auto Crea
   8   0        188        188       6884          0          0 Timers
  10   0        188        188       6884          0          0 ATM Idle Timer
   9   0        188        188       6884          0          0 Serial Backgroun
151   0          0          0       6884          0          0 Time Range Proce
   7   0          0          0       6884          0          0 AAA_SERVER_DEADT
152   0          0          0       6884          0          0 xcpa-driver
153   0          0          0       6884          0          0 DHCPD Timer
154   0          0          0       6884          0          0 DHCPD Database
   5   0          0          0       6884          0          0 Check heaps
  37   0          0          0       3884          0          0 Inode Table Dest
    2   0        188        188       3884          0          0 Load Meter
                                 49411560 Total
I used the Cisco Output Interpeter and it highlighted that the *Dead* process might be an issue. Although I can't see any related bugs for the current IOS version 12.3(8)T
I think this is a bug, in fact I would put money on it, but would like some help in trying to identify the cause. TAC cases for this unit can only be raised on our behalf by a third-party, so we'll be probably be waiting a few days before this is actioned.
Any help figuring this one out would be appreciated. I have output for SHOW BUFFERS sand SHOW TECH-SUPPORT if it helps
Cheers
Steve
The top function allocating memory in the dead process being " AAA Interface Struct", we have a matching bug
(assuming that the dead process keeps growing and growing).
This is CSCee57076, duplicate of CSCee35379, and the fix is in 12.3(8)T1 and above.
Herve
hbruyere
Hi Steven,
Can you show us the first few lines of "sh memory allocating-process totals" and "sh memory dead totals" ?
Herve
Hi Herve,
Here's the output you requested:
...#sh memory allocating-process
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   63BF6B40    54564032    33027488    21536544    20830496    20263312
      I/O    7000000    16777216    11016544     5760672     4970072     4895424
          Processor memory
Address      Bytes     Prev     Next Ref   Alloc Proc     Alloc PC  What
63BF6B40 0000000276 00000000 63BF6C7C 001  *Dead*          607D98C4  AAA Interfa
ce Struct
63BF6C7C 0000000428 63BF6B40 63BF6E50 001  *Dead*          607D98C4  AAA Attr Li
st
63BF6E50 0000000340 63BF6C7C 63BF6FCC 001  *Dead*          607D98C4  AAA Interfa
ce Struct
63BF6FCC 0000000356 63BF6E50 63BF7158 001  *Dead*          607D98C4  GENERAL_DB
63BF7158 0000000104 63BF6FCC 63BF71E8 000                  6075CCB8  (fragment)
63BF71E8 0000000276 63BF7158 63BF7324 001  *Dead*          607D98C4  AAA Interfa
ce Struct
63BF7324 0000000356 63BF71E8 63BF74B0 001  *Dead*          607D98C4  GENERAL_DB
63BF74B0 0000000356 63BF7324 63BF763C 001  *Dead*          607D98C4  GENERAL_DB
63BF763C 0000000356 63BF74B0 63BF77C8 001  *Dead*          607D98C4  GENERAL_DB
63BF77C8 0000000096 63BF763C 63BF7850 000                  6075CCB8  (fragment)
63BF7850 0000000356 63BF77C8 63BF79DC 001  *Dead*          607D98C4  GENERAL_DB
63BF79DC 0000000428 63BF7850 63BF7BB0 001  *Dead*          607D98C4  AAA Attr Li
st
63BF7BB0 0000000144 63BF79DC 63BF7C68 000                  607437A8  (fragment)
63BF7C68 0000000356 63BF7BB0 63BF7DF4 001  *Dead*          607D98C4  GENERAL_DB
63BF7DF4 0000000276 63BF7C68 63BF7F30 001  *Dead*          607D98C4  AAA Interfa
ce Struct
63BF7F30 0000000356 63BF7DF4 63BF80BC 001  *Dead*          607D98C4  GENERAL_DB
63BF80BC 0000000276 63BF7F30 63BF81F8 001  *Dead*          607D98C4  AAA Interfa
ce Struct
63BF81F8 0000000032 63BF80BC 63BF8240 000                  6075B148  (fragment)
63BF8240 0000000276 63BF81F8 63BF837C 001  *Dead*          607D98C4  AAA Interfa
ce Struct
63BF837C 0000000296 63BF8240 63BF84CC 000                  60EDA11C  (coalesced)
63BF84CC 0000000428 63BF837C 63BF86A0 001  *Dead*          607D98C4  AAA Attr Li
st
63BF86A0 0000000276 63BF84CC 63BF87DC 001  *Dead*          607D98C4  AAA Interfa
ce Struct
63BF87DC 0000000036 63BF86A0 63BF8828 000                  6075B148  (fragment)
63BF8828 0000000476 63BF87DC 63BF8A2C 001  *Dead*          607D98C4  AAA Attr Li
st
63BF8A2C 0000000276 63BF8828 63BF8B68 001  *Dead*          607D98C4  AAA Interfa
ce Struct
63BF8B68 0000000276 63BF8A2C 63BF8CA4 001  *Dead*          607D98C4  AAA Interfa
ce Struct
63BF8CA4 0000000036 63BF8B68 63BF8CF0 000                  6075B148  (fragment)
63BF8CF0 0000000276 63BF8CA4 63BF8E2C 001  *Dead*          607D98C4  AAA Interfa
ce Struct
63BF8E2C 0000000356 63BF8CF0 63BF8FB8 001  *Dead*          607D98C4  GENERAL_DB
63BF8FB8 0000000108 63BF8E2C 63BF904C 000                  6075CCB8  (fragment)
63BF904C 0000000356 63BF8FB8 63BF91D8 001  *Dead*          607D98C4  GENERAL_DB
...#sh memory dead totals
Processor   63BF6B40    54564032    33144160    21419872    20830496    20263312
Dead Proc Summary for: Processor
    PC          Total  Name
0x607D98C4       2491  AAA Interface Struct
0x607D98C4       2491  AAA Attr List
0x607D98C4       2491  GENERAL_DB
0x607558D8         16  AAA Acct DB ch
0x60751308          3  AAA DB Chunk
0x607C4304          1  Chain Cache No
0x6074378C          1  AAA attr list handle IDs
0x608574E8          1  AAA Acct AVLnode chunk
0x60742D24          1  AAA attr list handle IDs
0x607558AC          1  AAA Acct DB chunk
0x607577A0          1  AAA Acct Rec chunk
0x607AAAA4          1  TTY timers array
0x607D98C4          1  AAA Unique Id Hash Table
Dead Proc Summary for: I/O
    PC          Total  Name
cheers
Steve
Herve
Thanks a million Herve!!!
