Cisco 7500 router - high input drop packet.
bryanntg123
FastEthernet8/0 have high input/output drop packet, please advice how to fine tune it. Router CPU and memory is ok. Thanks
Below is the show interface
FastEthernet8/0 is up, line protocol is up
Hardware is cyBus FastEthernet Interface, address is 0060.3edc.5700 (bia 0060.3edc.5700)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 6d03h
Input queue: 0/75/19175/0 (size/max/drops/flushes); Total output drops: 17875294
Queueing strategy: fifo
Output queue :0/4096 (size/max)
5 minute input rate 6000 bits/sec, 10 packets/sec
5 minute output rate 3000 bits/sec, 4 packets/sec
2309239694 packets input, 2815330998 bytes
Received 0 broadcasts, 0 runts, 0 giants, 109 throttles
5 input errors, 5 CRC, 0 frame, 0 overrun, 49162952 ignored
0 watchdog
2288024906 packets output, 2176370355 bytes, 0 underruns
0 lost carrier, 0 no carrier
FastEthernet8/0.1 is up, line protocol is up
Internet address is <removed>
Encapsulation ISL Virtual LAN, Color 21.
FastEthernet8/0.2 is up, line protocol is up
Encapsulation ISL Virtual LAN, Color 34.
Giuseppe Larosa
Hello Bryan,
There is simply too much traffic on this link.
in 6d03h you have had
49162952 ignored
or the counters are fake or the octets count have wrapped many times.
you have had a 2% loss in input
and 17875294 / 2288024906 = 0.78 % outbound loss.
You are using a old FE module not a PA mounted on a VIP linecard.
You could try to shape outbound on the other side but ignored are caused by the incoming packet rate more then the traffic volume.
You can try to implement traffic-shaping for outgoing direction to minimize output drops.
Hope to help
Giuseppe
