Cisco 7500 Router reloaded after Software forced crash
rvg2k
Our router reloaded yesterday with a Software forced crash . I ant to identify the reason for the crash and also the fix for this problem . Attached is the crashinfo output .
------------------ show version ------------------
IOS (tm) RSP Software (RSP-ISV-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 20:51 by dchih
ROM: System Bootstrap, Version 12.0(20011126:200409) [mssunil-RSP16_BENGAL_120S 251], DEVELOPMENT SOFTWARE
Jasmin uptime is 39 minutes
System returned to ROM by error - a Software forced crash, PC 0x404BBE54 at 22:29:40 IST Thu Aug 4 2011
System restarted at 22:32:06 IST Thu Aug 4 2011
System image file is "disk0:rsp-isv-mz.123-26.bin"
cisco RSP16 (R7000A) processor with 524288K/8216K bytes of memory.
R7000 CPU at 400MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
Bridging software.
Chassis Interface.
1 VIP6-80 RM7000B controller (2 FastEthernet)(8 Serial).
1 VIP2 R5K controller (8 Serial).
2 FastEthernet/IEEE 802.3 interface(s)
16 Serial network interface(s)
2043K bytes of non-volatile configuration memory.
62720K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
No slave installed in slot 2.
Collin Clark
TAC has the tools for determining the crash. You'll need to open a case with Cisco.
we dont have facility to open the TAC case . If anybody can give us some input on the Error message recorded because of any BUG we an go for an IOS upgrade .
Then you have an impasse.  I've had a look at your crashinfo and it seems that you are running an ancient RSP IOS version.  This is the first thing I'd look into and upgrade the IOS of your router before proceeding any further.
