08-07-2005 04:18 AM - edited 03-03-2019 10:13 AM
I'm using a Cisco 760 isdn router to conect myself to the internet. All is working fine except for the fact that it will not use the 2nd channel to set up a 128k connection. ppp multilink is set to on. When the connection is made there are no errors on the console screen. What is going wrong here?
Kind regards,
Robin Meeuwsen
08-07-2005 04:58 AM
Hello Robin,
these are the settings that should let you use both ISDN channels, can you check if you have the second line configured as well ?
-->set ppp multilink on
-->set 2 auto on
GP
08-07-2005 09:16 AM
2 is set to on already. Still one channel is used.
Robin
08-07-2005 10:48 AM
Hello Robin,
who is your provider ? The ISP might not support PPP multilink...
GP
08-08-2005 11:56 PM
The provider is Wanadoo France. I also think it's a providerproblem but they do say on their website that it should be possible to surf at 128k. Shouldn't I get an errormessage when trying to use 2 channels?
Kind regards,
Robin MEEUWSEN
