Cisco 7600 high CPU utilization due to interrupt
Oleg Volkov
Dear Sirs!
We have next router:
spb-bg3#sh inventory
NAME: "CISCO7604", DESCR: "Cisco Systems Cisco 7600 4-slot Chassis System"
PID: CISCO7604         , VID: V01, SN: FOX1523H7E8
NAME: "CLK-7600 1", DESCR: "OSR-7600 Clock FRU 1"
PID: CLK-7600         , VID:   , SN: NWG15170KKT
NAME: "CLK-7600 2", DESCR: "OSR-7600 Clock FRU 2"
NAME: "module 1", DESCR: "RSP720-3CXL-GE 2 ports Route Switch Processor 720 Rev. 5.7"
PID: RSP720-3CXL-GE   , VID: V05, SN: JAE14020F5G
NAME: "msfc sub-module of 1", DESCR: "7600-MSFC4 C7600 MSFC4 Daughterboard Rev. 1.5"
PID: 7600-MSFC4       , VID: 000, SN: JAE141407G1
NAME: "switching engine sub-module of 1", DESCR: "7600-PFC3CXL Policy Feature Card 3 Rev. 1.0"
PID: 7600-PFC3CXL     , VID: 000, SN: JAE14330DXT
NAME: "module 2", DESCR: "RSP720-3CXL-GE 2 ports Route Switch Processor 720 Rev. 5.7"
PID: RSP720-3CXL-GE   , VID: V05, SN: JAE1212BVZ5
NAME: "msfc sub-module of 2", DESCR: "7600-MSFC4 C7600 MSFC4 Daughterboard Rev. 1.1"
PID: 7600-MSFC4       , VID: 000, SN: JAE1239W35T
NAME: "switching engine sub-module of 2", DESCR: "7600-PFC3CXL Policy Feature Card 3 Rev. 1.0"
PID: 7600-PFC3CXL     , VID: 000, SN: JAE1224LDKG
NAME: "module 3", DESCR: "WS-X6704-10GE CEF720 4 port 10-Gigabit Ethernet Rev. 2.6"
PID: WS-X6704-10GE     , VID: V02, SN: SAL1136ZLAV
NAME: "switching engine sub-module of 3", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.0"
PID: WS-F6700-CFC     , VID: V05, SN: SAL11391QGA
NAME: "Transceiver Te3/4", DESCR: "Transceiver 10Gbase-LR Te3/4"
PID: XENPAK-10GB-LR   , VID: V03 , SN: INT07350098
NAME: "FAN-MOD-4HS 1", DESCR: "High Speed Fan Module for CISCO7604 1"
PID: FAN-MOD-4HS       , VID: V01, SN: NID1530001Q
NAME: "PS 1 PWR-2700-AC/4", DESCR: "2700W AC power supply for CISCO7604 1"
PID: PWR-2700-AC/4     , VID: V02, SN: APS1511006G
NAME: "PS 2 PWR-2700-AC/4", DESCR: "2700W AC power supply for CISCO7604 2"
PID: PWR-2700-AC/4     , VID: V02, SN: APS1503008V
spb-bg3#show module
Mod Ports Card Type                             Model             Serial No.
   1   2 Route Switch Processor 720 (Hot)       RSP720-3CXL-GE     JAE14020F5G
   2   2 Route Switch Processor 720 (Active)   RSP720-3CXL-GE     JAE1212BVZ5
   3   4 CEF720 4 port 10-Gigabit Ethernet     WS-X6704-10GE     SAL1136ZLAV
Mod MAC addresses                      Hw   Fw           Sw           Status
   1 0001.0002.0003 to 0001.0002.0006   5.7   12.2(33r)SRD 12.2(33)SRE7 Ok
   2 0001.0002.0003 to 0001.0002.0006   5.7   12.2(33r)SRC 12.2(33)SRE7 Ok
   3 0019.3036.f5b8 to 0019.3036.f5bb   2.6   12.2(14r)S5 12.2(33)SRE7 Ok
Mod Sub-Module                 Model             Serial       Hw     Status
   1 Policy Feature Card 3       7600-PFC3CXL       JAE14330DXT 1.0   Ok
   1 C7600 MSFC4 Daughterboard   7600-MSFC4         JAE141407G1 1.5   Ok
   2 Policy Feature Card 3       7600-PFC3CXL       JAE1224LDKG 1.0   Ok
   2 C7600 MSFC4 Daughterboard   7600-MSFC4         JAE1239W35T 1.1   Ok
   3 Centralized Forwarding Card WS-F6700-CFC       SAL11391QGA 4.0   Ok
Mod Online Diag Status
   1 Pass
   2 Pass
   3 Pass
CPU utilization progressing in the time and can be 70% or more:
spb-bg3#sh processes cpu
CPU utilization for five seconds: 54%/50%; one minute: 53%; five minutes:
52%
Software is:
spb-bg3#show version
Cisco IOS Software, c7600rsp72043_rp Software
(c7600rsp72043_rp-IPSERVICES-M), Version 12.2(33)SRE7a, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 22-Oct-12 01:54 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRC3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software
(fc1)
spb-bg3 uptime is 6 days, 18 hours, 12 minutes
Uptime for this control processor is 6 days, 18 hours, 10 minutes
System returned to ROM by reload (SP by reload)
System restarted at 20:49:18 MSK Thu Jan 31 2013
System image file is
"bootdisk:c7600rsp72043-ipservices-mz.122-33.SRE7a.bin"
Last reload type: Normal Reload
Cisco CISCO7604 (M 8500) processor (revision 2.0) with
1900544K/131072K bytes
of memory.
Processor board ID FOX1523H7E8
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from power-on
3 Virtual Ethernet interfaces
4 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
We checked packets by netdr:
------- dump of incoming inband packet -------
interface Te3/4.2150, routine process_rx_packet_inline, timestamp 14:54:54.528
dbus info: src_vlan 0x866(2150), src_indx 0x83(131), len 0x5BC(1468)
bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x380(896)
C0020000 08660000 00830005 BC080000 00060574 0E000040 00000000 03802000
destmac E8.B7.48.29.C3.00, srcmac 00.1C.F6.20.21.F8, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x60, totlen 1450, identifier 65387
df 1, mf 0, fo 0, ttl 56, src 93.158.134.3, dst 46.228.1.18
   tcp src 80, dst 58326, seq 1649285763, ack 570972423, win 34 off 5 checksum 0x9C99 ack
And check cef for this IP:
spb-bg3#show ip cef 46.228.1.18
46.228.1.16/29
   nexthop 93.174.240.74 TenGigabitEthernet3/4.2404
spb-bg3#show mls cef lookup 46.228.1.18
Codes: decap - Decapsulation, + - Push Label
Index Prefix             Adjacency
6147   46.228.1.16/29     Unknown Adj
spb-bg3#ping 46.228.1.19
Sending 5, 100-byte ICMP Echos to 46.228.1.19, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
We can see adjacency is Unknown Adj
What can we do for diagnostic why it is packet has been software switched?
Thanks in advance!
PS:
I can send more information, if it need.
Helping seriously ill children, all together. All information about this, is posted on my blog
Oleg Volkov
spb-bg3#remote command switch show process cpu | e 0.00
CPU utilization for five seconds: 6%/0%; one minute: 6%; five minutes: 7%
PID Runtime(ms)     Invoked     uSecs   5Sec   1Min   5Min TTY Process
136   131451912   670886475       195 3.83% 3.84% 3.87%   0 slcp process
181   72998904     2259214     32311 1.43% 1.29% 1.34%   0 Vlan Statistics
182       37804     7255662         5 0.07% 0.02% 0.02%   0 L2 PI_E consiste
184   25117408     684762     36680 0.95% 0.48% 0.47%   0 TYFIB Table Mana
spb-bg3#show platform hardware capacity forwarding
L2 Forwarding Resources
           MAC Table usage:   Module Collisions Total       Used       %Used
                               1               0 98304         41         1%
                              2               0 98304         41         1%
             VPN CAM usage:                       Total       Used       %Used
                                                     512         0         0%
L3 Forwarding Resources
Module            FIB TCAM usage:                     Total       Used     %Used
   1                     72 bits (IPv4, MPLS, EoM)     671744     446982     67%
                         144 bits (IP mcast, IPv6)     188416       11859     6%
                      detail:     Protocol                   Used       %Used
                                   IPv4                     444934         66%
                                   MPLS                       2048         1%
                                  EoM                           0         0%
                                   IPv6                       11852         6%
                                   IPv4 mcast                     4         1%
                                   IPv6 mcast                     3         1%
             Adjacency usage:                     Total       Used       %Used
                                               1048576         203         1%
   2                     72 bits (IPv4, MPLS, EoM)     671744     446982     67%
                                   IPv4                     444934         66%
                                   MPLS                       2048         1%
                                  EoM                           0         0%
                                   IPv6                       11852         6%
                                   IPv4 mcast                     4         1%
                                  IPv6 mcast                     3         1%
                                               1048576         206         1%
     Forwarding engine load:
                      Module       pps   peak-pps                     peak-time
                     1         366334   1316799 00:56:31 MSK Tue Jan 29 2013
                     2         357624   1328917 00:56:34 MSK Tue Jan 29 2013
spb-bg3#show mls cef exception status
Current IPv4 FIB exception state = FALSE
Current IPv6 FIB exception state = FALSE
Current MPLS FIB exception state = FALSE
spb-bg3#show ibc | i rate
         5 minute rx rate 73323000 bits/sec, 21114 packets/sec
         5 minute tx rate 151267000 bits/sec, 41671 packets/sec
spb-bg3#remote command switch show ibc | i rate
         5 minute rx rate 1000 bits/sec, 1 packets/sec
         5 minute tx rate 12000 bits/sec, 17 packets/sec
Also, we tryed
remote command switch test mls cef tcam-shadow off
but this has no any effect
spb-bg3#show interfaces
GigabitEthernet1/1 is administratively down, line protocol is down
(disabled)
   Hardware is C7600 1Gb 802.3, address is e8b7.4829.c300 (bia
e8b7.4829.c300)
   MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
   Keepalive set (10 sec)
   Full-duplex, 1000Mb/s
   input flow-control is off, output flow-control is off
   Clock mode is auto
   Last input never, output never, output hang never
   Queueing strategy: fifo
   Output queue: 0/40 (size/max)
     1 packets input, 82 bytes, 0 no buffer
     Received 1 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     1 packets output, 82 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet1/2 is up, line protocol is up (connected)
   Hardware is C7600 1Gb 802.3, address is 0001.0002.0004 (bia
0001.0002.0004)
   Description: irkutsk4-as2 Fa0/40
   MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
   Full-duplex, 100Mb/s
   Media-type configured as RJ45 connector
   Clock mode is auto
   Last input never, output 00:00:46, output hang never
   Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
     201600 packets input, 14617813 bytes, 0 no buffer
     Received 19442 broadcasts (19441 multicasts)
     29213 packets output, 5564566 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
GigabitEthernet2/1 is administratively down, line protocol is down
(disabled)
e8b7.4829.c300)
   Clock mode is auto
     7 packets input, 556 bytes, 0 no buffer
     Received 4 broadcasts (0 IP multicasts)
     7 packets output, 556 bytes, 0 underruns
GigabitEthernet2/2 is up, line protocol is up (connected)
0001.0002.0004)
   Description: irkutsk4-as2 Fa0/41
   Clock mode is auto
   Last input never, output 00:00:24, output hang never
     601469 packets input, 52914055 bytes, 0 no buffer
     Received 20410 broadcasts (20408 multicasts)
     572453 packets output, 71436193 bytes, 0 underruns
TenGigabitEthernet3/1 is administratively down, line protocol is down
(disabled)
   Hardware is C7600 10Gb 802.3, address is e8b7.4829.c300 (bia
e8b7.4829.c300)
   MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
   Full-duplex, 10Gb/s
   Transport mode LAN (10GBASE-R, 10.3125Gb/s)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 packets output, 0 bytes, 0 underruns
TenGigabitEthernet3/2 is administratively down, line protocol is down
(disabled)
e8b7.4829.c300)
   Full-duplex, 10Gb/s
TenGigabitEthernet3/3 is administratively down, line protocol is down
(disabled)
e8b7.4829.c300)
   Full-duplex, 10Gb/s
TenGigabitEthernet3/4 is up, line protocol is up (connected)
e8b7.4829.c300)
   Description: tmp borovaya-bb Te4/2(dolzhno bit spb-ds1 Te1/3)
   MTU 9216 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 62/255, rxload 62/255
   Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
   Full-duplex, 10Gb/s
   Last input 00:00:00, output 00:00:00, output hang never
   Input queue: 0/2000/4844/4844 (size/max/drops/flushes); Total output
drops: 0
   30 second input rate 2425383000 bits/sec, 411132 packets/sec
   30 second output rate 2425089000 bits/sec, 410755 packets/sec
   L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
   L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
   L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
     130490761819 packets input, 100484004636045 bytes, 0 no buffer
     Received 827934 broadcasts (0 IP multicasts)
     130318869111 packets output, 100468002524630 bytes, 0 underruns
TenGigabitEthernet3/4.282 is up, line protocol is up (connected)
e8b7.4829.c300)
   Description: Cogent Uplink
   Internet address is 149.6.141.74/30
     reliability 255/255, txload 61/255, rxload 61/255
   Encapsulation 802.1Q Virtual LAN, Vlan ID 282.
TenGigabitEthernet3/4.423 is up, line protocol is up (connected)
e8b7.4829.c300)
   Description: Level3 Uplink
   Internet address is 212.162.24.42/30
   Encapsulation 802.1Q Virtual LAN, Vlan ID 423.
TenGigabitEthernet3/4.2101 is up, line protocol is up (connected)
e8b7.4829.c300)
   Description: Linkey Uplink
   Internet address is 93.174.240.130/29
   Encapsulation 802.1Q Virtual LAN, Vlan ID 2101.
TenGigabitEthernet3/4.2144 is up, line protocol is up (connected)
e8b7.4829.c300)
   Description: ipv6 bgp spb-bg3 -:- borovaya-bb
   Encapsulation 802.1Q Virtual LAN, Vlan ID 2144.
TenGigabitEthernet3/4.2150 is up, line protocol is up (connected)
e8b7.4829.c300)
   Description: ASBR Net Severen-Telecom(iBGP)
   Internet address is 93.174.240.17/28
   Encapsulation 802.1Q Virtual LAN, Vlan ID 2150.
TenGigabitEthernet3/4.2403 is up, line protocol is up (connected)
e8b7.4829.c300)
   Description: eBGP-oktybrsk-bg-7200
   Internet address is 93.174.240.69/30
   Encapsulation 802.1Q Virtual LAN, Vlan ID 2403.
TenGigabitEthernet3/4.2404 is up, line protocol is up (connected)
e8b7.4829.c300)
   Description: eBGP-kantemir-bg-7200
   Internet address is 93.174.240.73/30
   Encapsulation 802.1Q Virtual LAN, Vlan ID 2404.
TenGigabitEthernet3/4.2405 is up, line protocol is up (connected)
e8b7.4829.c300)
   Description: eBGP-kantemir-bg2-7200
   Internet address is 93.174.240.81/30
   Encapsulation 802.1Q Virtual LAN, Vlan ID 2405.
Loopback0 is up, line protocol is up
   Hardware is Loopback
   Internet address is 93.174.240.1/32
   MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
   Encapsulation LOOPBACK, loopback not set
   Last input 6d18h, output never, output hang never
   Output queue: 0/0 (size/max)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     6 packets output, 456 bytes, 0 underruns
Vlan1 is administratively down, line protocol is down
Hardware is EtherSVI, address is e8b7.4829.c300 (bia e8b7.4829.c300)
   Keepalive not supported
     0 output errors, 1 interface resets
Vlan2998 is up, line protocol is up
   Description: Management spb-bg3-sdby
   Internet address is 192.168.96.130/25
   Last input 00:00:22, output 02:03:03, output hang never
   Input queue: 0/75/5/5 (size/max/drops/flushes); Total output drops: 0
   L2 Switched: ucast: 123868 pkt, 9089152 bytes - mcast: 0 pkt, 0 bytes
     123863 packets input, 9088832 bytes, 0 no buffer
     44 packets output, 2816 bytes, 0 underruns
     0 output errors, 0 interface resets
Vlan2999 is up, line protocol is up
   Internet address is 192.168.96.2/25
   Input queue: 0/75/7/7 (size/max/drops/flushes); Total output drops: 0
   5 minute input rate 2000 bits/sec, 2 packets/sec
   5 minute output rate 2000 bits/sec, 2 packets/sec
   L2 Switched: ucast: 522766 pkt, 45707429 bytes - mcast: 965 pkt, 78165
bytes
     523823 packets input, 45791342 bytes, 0 no buffer
     Received 965 broadcasts (0 IP multicasts)
     543355 packets output, 63729632 bytes, 0 underruns
spb-bg3#
spb-bg3#show interfaces switching
Interface GigabitEthernet1/1 is disabled
GigabitEthernet1/2 irkutsk4-as2 Fa0/40
     Protocol CDP
           Switching path   Pkts In   Chars In   Pkts Out Chars Out
                 Process         0         0       9726   4629576
             Cache misses         0         -         -         -
                     Fast         0         0         0         0
               Auton/SSE         0         0         0         0
     NOTE: all counts are cumulative and reset only after a reload.
Interface GigabitEthernet2/1 is disabled
GigabitEthernet2/2 irkutsk4-as2 Fa0/41
     Protocol CDP
                     Fast         0         0         0         0
               Auton/SSE         0         0         0         0
Interface TenGigabitEthernet3/1 is disabled
Interface TenGigabitEthernet3/2 is disabled
Interface TenGigabitEthernet3/3 is disabled
TenGigabitEthernet3/4 tmp borovaya-bb Te4/2(dolzhno bit spb-ds1 Te1/3)
           Throttle count         0
                   Drops         RP       4844         SP         0
             SPD Flushes       Fast       4844       SSE         0
             SPD Aggress       Fast         0
             SPD Priority     Inputs   6743190     Drops         0
     Protocol IP
                 Process   9965536 1519945312  9705174 1687829356
                     Fast 10306455540 7764909874529 10137069249 7701218554070
               Auton/SSE 120225897867 92235309380788 120253629612
92717467559684
    Protocol ARP
                 Process     36768   2206080       5487     526752
                     Fast          0         0         0         0
               Auton/SSE         0         0         0         0
     Protocol CDP
                 Process         0         0       9724   4550832
                     Fast         0         0         0         0
               Auton/SSE         0         0         0         0
     Protocol IPv6
                 Process     471605   86014905     415610   73501191
                     Fast     100369   21071304     100346   20665185
               Auton/SSE         0         0   16889518 4774252730
     Protocol Other
                 Process       2908     223916         0         0
                     Fast         0         0         0         0
               Auton/SSE         0         0         0         0
Loopback0
     Protocol IPv6
                 Process         6       456         6       456
                     Fast         0         0         0         0
               Auton/SSE         0         0         0         0
Interface Vlan1 is disabled
Vlan2998 Management spb-bg3-sdby
           Throttle count         0
                   Drops         RP         5         SP         0
             SPD Flushes       Fast         5       SSE         0
              SPD Aggress       Fast         0
             SPD Priority     Inputs         39     Drops         0
     Protocol IP
                 Process     123856   8593260         0         0
                     Fast         0         0         0         0
               Auton/SSE         0         0         0         0
     Protocol ARP
                 Process         39       2340         44       4224
                    Fast         0         0         0         0
               Auton/SSE         0         0         0         0
Vlan2999 Management spb-bg3
           Throttle count         0
                   Drops         RP         7         SP         0
             SPD Flushes       Fast         7       SSE         0
             SPD Aggress       Fast         0
             SPD Priority     Inputs       160    Drops         0
     Protocol IP
                 Process     523120   43643167     543593   81159675
                    Fast         0         0         0         0
               Auton/SSE         0         0         0         0
     Protocol ARP
                 Process         40       2400         51       4896
                     Fast         0         0         0         0
               Auton/SSE         0         0         0         0
     Protocol Other
                 Process       965     74305         0         0
                     Fast         0         0         0         0
               Auton/SSE         0         0         0         0
spb-bg3#
spb-bg3#show interfaces stats
GigabitEthernet1/2
               Processor         0         0       9726   4318344
             Route cache         0         0         0         0
       Distributed cache         0         0         0         0
                   Total         0         0       9726   4318344
GigabitEthernet2/2
               Processor         0         0       9727   4318788
             Route cache         0         0         0         0
                   Total         0         0       9727   4318788
               Processor   10477630 1692313946   10136738 1442142751
             Route cache 10308785965 7766506836351 10139379069 7702802276676
       Distributed cache 120243310696 92248296235339 120289585371
92736530145221
                   Total 130562574291 100016495385636 130439101178
100440774564648
Loopback0
               Processor         0         0         6       456
             Route cache         0         0         0         0
                   Total         0         0         6       456
Vlan2998
               Processor     123895   9091180         44       2816
             Route cache         0         0          0         0
                   Total     123895   9091180         44       2816
Vlan2999
               Processor     524181   45820016     543678   63773697
             Route cache         0         0         0         0
                   Total     524181   45820016     543678   63773697
spb-bg3#show ip nat translations
spb-bg3#
spb-bg3#show alignment
No spurious memory references have been recorded.
No alignment data has been recorded.
spb-bg3#
after clearing cef, CPU utilization drop to 10-12 percents, but then slowly increases and  after few hours, may be 50 -70 percents
