I have no 'ip routing command'
Lewis Goulden
                   I have seen on the core switch I am working on currently there is not the 'ip routing' statement.
HOSTNAME#show ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 11:39 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x123FB194
ROM: 12.2(31r)SGA4
Dagobah Revision 95, Swamp Revision 28
TP-CSA uptime is 4 weeks, 2 days, 18 hours, 33 minutes
System restarted at 15:58:13 UTC Sat Feb 2 2013
System image file is "bootflash:cat4500-entservicesk9-mz.122-54.SG1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4506 (MPC8245) processor (revision 7) with 524288K bytes of memory.
Processor board ID FOX0803056H
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from Reload
20 Virtual Ethernet interfaces
134 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
HOSTNAME#show run | i ip rout
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip route x.x.x.0 255.255.255.0 x.x.x.x
Could this cause a problem ? or is it the software version not showing it into the config.
there is the ability to input this command.....
HOSTNAME(config)#ip routing ?
  protocol  IP routing protocol
  <cr>
Any input will be greatly appreciated. !
kind regards
2 Accepted Solutions
Giuseppe Larosa
Hello Lewis,
ip routing may be the default in your IOS image.
There are few static routes configured and so IP routing is likely enabled.
to check if ip routing is enabled post the output of
show ip route.
The output of this show command is totally different with ip routing disabled.
If the ouput is the usual with entries corresponding to the static routes you are fine.
Hope to help
Giuseppe
Hi Lewis
From command reference ->
Catalyst 4500 Series Switch
Cisco IOS Command Reference
Release 12.2(54)SG
"For example, IP routing is enabled by default. To disable IP routing, specify the no ip routing command and specify ip routing to reenable it."
Best Regards
Please rate helpful posts
Best Regards Please rate all helpful posts and close solved questions
Giuseppe Larosa
Hello Lewis,
show ip route.
Hope to help
Giuseppe
Hi Lewis
Release 12.2(54)SG
Best Regards
