Cisco 7600 line card intermittently reloading - 0x8
shamblindl
Hey all,
I've got a bit of a problem with a 7600-ES+40G3CXL line card intermittently reloading itself, each time for a 3-5 minute period. We've been trying to troubleshoot why it's happening, but unfortunately, all we can find is that the reason it's resetting is "0x8". We haven't had any luck in finding out what this means, but would any of you happen to know?
IOS version is 12.2(33)SRD2a
If it helps, the reset only happened twice yesterday evening, but then proceeded to wait several hours before resetting again.
router#remote command module 2 sho log onbo
PID: CWAN Metro 40G Lin, VID: NA , SN: NA
UPTIME SUMMARY INFORMATION
First customer power on : 03/12/2010 16:17:06
Total uptime : 0 years 0 weeks 0 days 0 hours 0 minutes
Total downtime : 0 years 0 weeks 0 days 0 hours 0 minutes
Number of resets : 1
Number of slot changes : 0
Current reset reason : 0x8
Current reset timestamp : 02/27/2016 07:43:59
Current slot : 2
Current uptime : 0 years 0 weeks 0 days 0 hours 0 minutes
Reset | |
Reason | Count |
No historical data to display
ENVIRONMENT SUMMARY INFORMATION
MM/DD/YYYY HH:MM:SS Ins count Rem count
VID PID TAN Serial No
No environment summary data to display
ERROR MESSAGE SUMMARY INFORMATION
Facility-Sev-Name | Count | Persistence Flag
MM/DD/YYYY HH:MM:SS
EDIT: Upon further troubleshooting, it looks like we're being affected by bug CSCth11714. Anyone have a good way to deal with this, even if it's just to upgrade IOS?
Philip D'Ath
It says the only fix is to upgrade - so that is what I would be doing.
Philip D'Ath
Yeah, that's what we ended up doing. My coworkers and I were just curious if anyone had found an unlisted workaround or anything.
Thanks!
