Cisco 7606: High CPU
Q S Tahmeed
Hi Forum,
In recent time we observed that one of our routers CPU has spiked abnormally. Even though the amount of bandwidth passing through the Router has increased but its no where proportional to the spike in the CPU. About two weeks ago the overall CPU was less than 20%, which at present is around 40%-60%. A couple of days back it was hovering around 80%+ mark.
Approx BW passing through the router is around 13Gbps during peak times. This router doesn't hold eBGP full feed. It runs OSPF/BGP/Multicast/MPLS services along with few ACLs and no QoS. It also doesn't hold any direct client facing interfaces.
Hardware information along with some show commands are shared below:
Chassis: 7606
SUP: 2 x [WS-SUP720-3B + WS-SUP720 MSFC3 Daughterboard + WS-F6K-PFC3B Policy Feature Card 3]
10G LC: 2 x [WS-X6704-10GE + WS-F6700-CFC]
1G LC: 1 x WS-X6408A-GBIC + 1 x WS-X6516A-GBIC
Attached are show version & show proc cpu hist outputs. I googled through some of the links found under forums as well as under cisco's site. But haven't been able to figure out any specific reason.
Please suggest and feel free to query for any further logs/info.
sh mls cef summary
Total routes:                     15844
    IPv4 unicast routes:          14638
    IPv4 Multicast routes:        21
    MPLS routes:                  1168
    IPv6 unicast routes:          14
    IPv6 multicast routes:        3
    EoM routes:                   3
sh proc cpu sort | ex 0.00%
CPU utilization for five seconds: 40%/31%; one minute: 41%; five minutes: 42%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
 201   5262632002806335232          0  7.91%  7.24%  7.27%   0 IP Input
  11    36612360  97483067        375  0.23%  0.15%  0.12%   0 ARP Input
 516    15545444 282648677         54  0.15%  0.05%  0.03%   0 OSPF-100 Hello
 297    85523128 221162540        386  0.07%  0.18%  0.18%   0 OSPF-100 Router
 361    83265660 259267889        321  0.07%  0.57%  0.65%   0 LFDp Input Proc
   2     9895592  12559300        787  0.07%  0.06%  0.07%   0 Load Meter
 203    31994296 181891950        175  0.07%  0.04%  0.05%   0 ADJ resolve proc
sh mls statistics
Statistics for Earl in Module 6
L2 Forwarding Engine
  Total packets Switched                : 49985702672136
L3 Forwarding Engine
  Total packets Processed               : 44605491282541 @ 1761144 pps
  Total packets L3 Switched             : 43409223699193 @ 1723987 pps
  Total Packets Bridged                 : 1048240217848
  Total Packets FIB Switched            : 43409223699193
  Total Packets ACL Routed              : 0
  Total Packets Netflow Switched        : 0
  Total Mcast Packets Switched/Routed   : 3242987580
  Total ip packets with TOS changed     : 2
  Total ip packets with COS changed     : 2
  Total non ip packets COS changed      : 0
  Total packets dropped by ACL          : 7696946466
  Total packets dropped by Policing     : 0
  Total packets exceeding CIR           : 0
  Total packets exceeding PIR           : 0
Errors
  MAC/IP length inconsistencies         : 51
  Short IP packets received             : 0
  IP header checksum errors             : 2
  No-route packet drops                 : 75391210
  TTL failures                          : 1412616928
  MTU failures                          : 158400
Total packets L3 Processed by all Modules: 44605491282541 @ 1761144 pps
Best Regards,
Tahmeed
Philip D'Ath
Philip D'Ath
Check out this forum post to diagnose high CPU usage.
https://supportforums.cisco.com/document/59926/troubleshooting-high-cpu-6500-sup720
