cisco 7606-s with RSP 720 with full traffic cpu getting 100 %
arunachalaprabu
We are having cisco 7606-s with RSP 720 and we are running the BGP with 3 operator when we put full load (250 mb) on the trafiic i am facing below issue
BGP session flapping and CPU getting 100% or 95%
any solution for the same
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-        M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Feb-10 01:06 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTE        RPRISEK9-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
TC1_7606_BGPGW-B uptime is 2 weeks, 2 days, 20 hours, 7 minutes
Uptime for this control processor is 2 weeks, 2 days, 20 hours, 7 minutes
System returned to ROM by  power cycle (SP by power on)
System image file is "sup-bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRD4.        bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. CISCO7606-S (M8500) processor (revision 1.1) with 3670016K/262144K bytes o        f memory.
Processor board ID FOX1417GEZ6
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
If
Cisco
Last reset from power-on
1 Virtual Ethernet interface
58 Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
5 Replies 5
Lei Tian
Hi Arunachala Prabu,
Can you post the output of 'show proc cpu sort' while CPU is running high?
HTH,
Lei Tian
CPU utilization for five seconds: 53%/34%; one minute: 33%; five minutes: 32%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0         9          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2       12820    464627         27  0.00%  0.00%  0.00%   0 Load Meter
   3      241776   4179090         57  0.00%  0.01%  0.00%   0 IP SNMP
   4           0         1          0  0.00%  0.00%  0.00%   0 EM Action CNS
   5           0        81          0  0.00%  0.00%  0.00%   0 Retransmission o
   6           0         3          0  0.00%  0.00%  0.00%   0 IPC ISSU Dispatc
   7           0         1          0  0.00%  0.00%  0.00%   0 PF Redun ICC Req
   8    12250584    710386      17245  6.87%  0.98%  0.74%   0 Check heaps
   9          96       484        198  0.00%  0.00%  0.00%   0 Pool Manager
  10           0         2          0  0.00%  0.00%  0.00%   0 Timers
  11      875040   7236655        120  0.00%  0.03%  0.01%   0 ARP Input
  12        1060   2417789          0  0.00%  0.00%  0.00%   0 ARP Background
  13           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  14           0         1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  15           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  16           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  17           4        14        285  0.00%  0.00%  0.00%   0 Entity MIB API
  18        2272    109974         20  0.00%  0.00%  0.00%   0 EEM ED Syslog
  19           0         1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  20           0     38731          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  21         104    464627          0  0.00%  0.00%  0.00%   0 IPC Service NonC
  22           4        97         41  0.00%  0.00%  0.00%   0 PF_Split Sync Pr
  23         152   2320688          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  24        2224   4923040          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  25         120   2320701          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  26      181276   1931997         93  0.07%  0.00%  0.00%   0 IPC Seat Manager
  27           4       533          7  0.00%  0.00%  0.00%   0 IPC Seat Control
  28        2396    464632          5  0.00%  0.00%  0.00%   0 IPC Loadometer
  29           8    232356          0  0.00%  0.00%  0.00%   0 Compute SRP rate
  30           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  31           0         1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  32           0         1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  33           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  34           0         1          0  0.00%  0.00%  0.00%   0 ifIndex Receive
  35           0         1          0  0.00%  0.00%  0.00%   0 SENSOR-MGR event
  36           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  37           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  38           0         1          0  0.00%  0.00%  0.00%   0 Exception contro
  39       50196    651719         77  0.07%  0.00%  0.00%   0 EnvMon
  40         100   2320666          0  0.00%  0.00%  0.00%   0 GraphIt
  41          56       724         77  0.00%  0.00%  0.00%   0 rf proxy rp agen
  42           0         3          0  0.00%  0.00%  0.00%   0 rf proxy message
  43           8        10        800  0.00%  0.00%  0.00%   0 Entity MIB C6k P
  44           0         3          0  0.00%  0.00%  0.00%   0 client_entity_se
  45           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  46           0         1          0  0.00%  0.00%  0.00%   0 Snmp ICC Process
  47           8        51        156  0.00%  0.00%  0.00%   0 Cat6k SNMP
  48           0         9          0  0.00%  0.00%  0.00%   0 Cat6k SNMP Trap
  49         196   2320685          0  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  50           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  51        6476    444628         14  0.00%  0.00%  0.00%   0 Net Background
  52           0         3          0  0.00%  0.00%  0.00%   0 IDB Work
  53         108    219828          0  0.00%  0.00%  0.00%   0 Logger
  54         428   2320662          0  0.00%  0.00%  0.00%   0 TTY Background
  55        2748   2324143          1  0.00%  0.00%  0.00%   0 Per-Second Jobs
  56      400792     39659      10105  0.00%  0.01%  0.00%   0 Per-minute Jobs
  57           8        26        307  0.00%  0.00%  0.00%   0 IF-MGR control p
  58           4        60         66  0.00%  0.00%  0.00%   0 IF-MGR event pro
  59           0         5          0  0.00%  0.00%  0.00%   0 RPC rf_rfmib_not
  60          16       343         46  0.00%  0.00%  0.00%   0 Env action
  61         112   2320687          0  0.00%  0.00%  0.00%   0 EOBC ETSEC FREEZ
  62           0         2          0  0.00%  0.00%  0.00%   0 Flash ICC Server
  63           0         2          0  0.00%  0.00%  0.00%   0 ICC Nego
  64           0      3876          0  0.00%  0.00%  0.00%   0 itasca
  65        7052    640714         11  0.00%  0.00%  0.00%   0 Net Input
  66           0         7          0  0.00%  0.00%  0.00%   0 draco-oir-proces
  67        6900 138935279          0  0.00%  0.00%  0.00%   0 HSRP Common
  68           0        70          0  0.00%  0.00%  0.00%   0 svclc
  69           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  70           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  71           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  72       48668   2250958         21  0.00%  0.00%  0.00%   0 HSRP IPv4
  73           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  74           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  75           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  76           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  77           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  78           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  79           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  80           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  81           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  82           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  83           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  84           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  85           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  86           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  87           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  88           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  89           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  90           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  91           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  92           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  93           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  94           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  95           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  96           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  97           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  98           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  99           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
100           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
101           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
102           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
103           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
104           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
105           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
106           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
107           0        11          0  0.00%  0.00%  0.00%   0 RPC Sync
108           0         3          0  0.00%  0.00%  0.00%   0 RPC rpc-slave-15
109           0         2          0  0.00%  0.00%  0.00%   0 SCP Multicast
110           0      3874          0  0.00%  0.00%  0.00%   0 simba
111           0         3          0  0.00%  0.00%  0.00%   0 MWAM CONFIG ON S
112           0         1          0  0.00%  0.00%  0.00%   0 SAMI CONFIG ON S
113           0         1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
114           0         1          0  0.00%  0.00%  0.00%   0 DHCPC HA
115           0         1          0  0.00%  0.00%  0.00%   0 DHCPD HA
116           0         1          0  0.00%  0.00%  0.00%   0 MDR SM Proxy Sla
117         992     38725         25  0.00%  0.00%  0.00%   0 RF CWAN HA Proce
118           0         1          0  0.00%  0.00%  0.00%   0 CWAN HA VLAN SYN
119           0         1          0  0.00%  0.00%  0.00%   0 CWAN IF EVENT HA
120           0         1          0  0.00%  0.00%  0.00%   0 CWAN APS HA Proc
121           0         1          0  0.00%  0.00%  0.00%   0 CWAN SRP HA Proc
122           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
123        1244   2320648          0  0.00%  0.00%  0.00%   0 Heartbeat Proces
124           0         2          0  0.00%  0.00%  0.00%   0 Const ICC reques
125           0         1          0  0.00%  0.00%  0.00%   0 Const ICC event
126           0         1          0  0.00%  0.00%  0.00%   0 Const ICC except
127           0         1          0  0.00%  0.00%  0.00%   0 ICC Local Reques
128        4184    214428         19  0.00%  0.00%  0.00%   0 ICC Async mcast
129           0         1          0  0.00%  0.00%  0.00%   0 ICC_REQ Debug Pr
130           0         1          0  0.00%  0.00%  0.00%   0 ICC FC Process
131           0         1          0  0.00%  0.00%  0.00%   0 ICC FC Test Send
132           0         1          0  0.00%  0.00%  0.00%   0 ICC FC Test Low
133           0         1          0  0.00%  0.00%  0.00%   0 PF Sync process
134           0         1          0  0.00%  0.00%  0.00%   0 QoS HA CHKPT
135           0         1          0  0.00%  0.00%  0.00%   0 CWRP SPA TSM HA
136           0         2          0  0.00%  0.00%  0.00%   0 Switch IP Host T
137         316   2254613          0  0.00%  0.00%  0.00%   0 Track
138           0         1          0  0.00%  0.00%  0.00%   0 IKE HA Mgr
139           0         1          0  0.00%  0.00%  0.00%   0 IPSEC HA Mgr
140           8        23        347  0.00%  0.00%  0.00%   0 PF_Init Process
141           0        25          0  0.00%  0.00%  0.00%   0 RPC pf-split-rp
142           0        11          0  0.00%  0.00%  0.00%   0 RPC idprom-MP
143           4     45988          0  0.00%  0.00%  0.00%   0 Transport Port A
144           0         1          0  0.00%  0.00%  0.00%   0 BACK CHECK
145           4        38        105  0.00%  0.00%  0.00%   0 RTTYS Process
146           0         1          0  0.00%  0.00%  0.00%   0 RFS server proce
147        3384    465432          7  0.00%  0.00%  0.00%   0 Compute load avg
148           0         1          0  0.00%  0.00%  0.00%   0 CHKPT rcv MSG pr
149           0         2          0  0.00%  0.00%  0.00%   0 cpf_process_msg_
150           0         1          0  0.00%  0.00%  0.00%   0 cpf_process_ipcQ
151           0         1          0  0.00%  0.00%  0.00%   0 IPC Apps Task
152           0         4          0  0.00%  0.00%  0.00%   0 OBFL Cfg Dispatc
153           0         3          0  0.00%  0.00%  0.00%   0 AggMgr Process
154           0         2          0  0.00%  0.00%  0.00%   0 CWAN ICC
155           0         1          0  0.00%  0.00%  0.00%   0 SFF8472
156           0         1          0  0.00%  0.00%  0.00%   0 Remote Console P
157           0         1          0  0.00%  0.00%  0.00%   0 CCB SEND RETRY A
158           0         1          0  0.00%  0.00%  0.00%   0 POS APS Event Pr
159           0         3          0  0.00%  0.00%  0.00%   0 CWAN OIR Handler
160           0         2          0  0.00%  0.00%  0.00%   0 CWAN Egress SACL
161           0         1          0  0.00%  0.00%  0.00%   0 DSX3MIB ll handl
162           0         1          0  0.00%  0.00%  0.00%   0 FPD Management P
163           0         1          0  0.00%  0.00%  0.00%   0 FPD Action Proce
164           0         2          0  0.00%  0.00%  0.00%   0 const FPD ICC pr
165           0         1          0  0.00%  0.00%  0.00%   0 dwdm RPC RP proc
166           0         2          0  0.00%  0.00%  0.00%   0 netclk_process
167           0         1          0  0.00%  0.00%  0.00%   0 netclk_ha_proces
168           0         7          0  0.00%  0.00%  0.00%   0 SCP async: LCP#5
169           0         2          0  0.00%  0.00%  0.00%   0 CWAN ACD tasks
170           0         3          0  0.00%  0.00%  0.00%   0 ACE_REQUESTS han
171        2208  71602644          0  0.00%  0.00%  0.00%   0 ACE Tunnel Task
172           0         1          0  0.00%  0.00%  0.00%   0 ACE VRF Task
173           0        17          0  0.00%  0.00%  0.00%   0 CMFI RP process
174         168   2320685          0  0.00%  0.00%  0.00%   0 CWAN CHOCX PROCE
175           0         1          0  0.00%  0.00%  0.00%   0 HAL Mailbox
176         236   2320686          0  0.00%  0.00%  0.00%   0 CWAN CHDSX PROCE
177           0         1          0  0.00%  0.00%  0.00%   0 CT3 Mailbox
178           0         1          0  0.00%  0.00%  0.00%   0 CE3 Mailbox
179           0         2          0  0.00%  0.00%  0.00%   0 MIP Mailbox
180           0         1          0  0.00%  0.00%  0.00%   0 Earl NDE Task
181         540    455288          1  0.00%  0.00%  0.00%   0 esw_vlan_stat_pr
182           0         7          0  0.00%  0.00%  0.00%   0 Gemini L3 forwar
183           0         1          0  0.00%  0.00%  0.00%   0 CWRP SPA ATM OIR
184           0         1          0  0.00%  0.00%  0.00%   0 ACE event
185           0         1          0  0.00%  0.00%  0.00%   0 ACE HAPI
186          76    154905          0  0.00%  0.00%  0.00%   0 ACE policy loade
187           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
188           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
189           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
190           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
191          12     38731          0  0.00%  0.00%  0.00%   0 DFS flush period
192           0         2          0  0.00%  0.00%  0.00%   0 AAA Server
193           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
194        1972  71879144          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
195           0         1          0  0.00%  0.00%  0.00%   0 AAA System Acct
196           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
197           0      7747          0  0.00%  0.00%  0.00%   0 IP Admin SM Proc
198           0         3          0  0.00%  0.00%  0.00%   0 CEF RP IPC Backg
199           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
200           4     19368          0  0.00%  0.00%  0.00%   0 DHCP Snooping
201           0         2          0  0.00%  0.00%  0.00%   0 CEF switching ba
202          60       203        295  0.00%  0.00%  0.00%   0 IP ARP Adjacency
203      372064   7424635         50  0.00%  0.02%  0.00%   0 IP Input
204           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
205       39100    265775        147  0.00%  0.00%  0.00%   0 ADJ resolve proc
206           0         1          0  0.00%  0.00%  0.00%   0 PPCP RP Stats Ba
207           0         1          0  0.00%  0.00%  0.00%   0 IPv6 Echo event
208         360     34776         10  0.00%  0.00%  0.00%   0 MOP Protocols
209           0         2          0  0.00%  0.00%  0.00%   0 PPP SIP
210           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
211           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
212     1640336   2186180        750  0.00%  0.00%  0.00%   0 BGP Scheduler
213           0         1          0  0.00%  0.00%  0.00%   0 HDLC HA
214           0         4          0  0.00%  0.00%  0.00%   0 ARP HA
215           0        24          0  0.00%  0.00%  0.00%   0 SSM connection m
216       31764   3218885          9  0.00%  0.00%  0.00%   0 Spanning Tree
217           0         5          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
218           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
219           0         1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
220           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
221         656   9073396          0  0.00%  0.00%  0.00%   0 SSS Feature Time
222           0         1          0  0.00%  0.00%  0.00%   0 SG DPM
223           0         1          0  0.00%  0.00%  0.00%   0 Timer handler fo
224           0         1          0  0.00%  0.00%  0.00%   0 Prepaid response
225           0         1          0  0.00%  0.00%  0.00%   0 Timed Policy act
226           0         1          0  0.00%  0.00%  0.00%   0 AAA response han
227           0         1          0  0.00%  0.00%  0.00%   0 AAA EPD HANDLER
228           0         1          0  0.00%  0.00%  0.00%   0 PM EPD API
229           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
230           0         3          0  0.00%  0.00%  0.00%   0 cv6 per prefix a
231           0         1          0  0.00%  0.00%  0.00%   0 CCM
232           0         2          0  0.00%  0.00%  0.00%   0 CCM IPC flow con
233           0         1          0  0.00%  0.00%  0.00%   0 DMLP Counter
234           0         2          0  0.00%  0.00%  0.00%   0 802.1x Accountin
235           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
236           0         1          0  0.00%  0.00%  0.00%   0 EAP Framework
237           0         2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
238         148   2264285          0  0.00%  0.00%  0.00%   0 Ethernet Timer C
239           0         2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
240           0         1          0  0.00%  0.00%  0.00%   0 IMA PROC
241           0         2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
242        1968  71602714          0  0.00%  0.00%  0.00%   0 IPAM Manager
243           0         2          0  0.00%  0.00%  0.00%   0 IPAM Events
244          12       140         85  0.00%  0.00%  0.00%   0 SW VLAN RP
245           0         2          0  0.00%  0.00%  0.00%   0 const ipfib per-
246           0         2          0  0.00%  0.00%  0.00%   0 CFMPAL-RP Proces
247     3136448   5046468        621  0.00%  0.05%  0.05%   0 BGP Router
248           0         2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
249          28         5       5600  0.00%  0.00%  0.00%   0 crypto sw pk pro
250          48       362        132  0.00%  0.00%  0.00%   0 HWIF QoS Process
251           0        74          0  0.00%  0.00%  0.00%   0 EEM Server
252           0         1          0  0.00%  0.00%  0.00%   0 MLS FIB RP
253           0         1          0  0.00%  0.00%  0.00%   0 mcast_rp_icc Pro
254           0         2          0  0.00%  0.00%  0.00%   0 QOS Stats Export
255          84    232339          0  0.00%  0.00%  0.00%   0 QOS Stats Gather
256           0         1          0  0.00%  0.00%  0.00%   0 Switch IP Admiss
257           0         2          0  0.00%  0.00%  0.00%   0 Switch IP Host T
258           0        33          0  0.00%  0.00%  0.00%   0 TCAM API Process
259           0         2          0  0.00%  0.00%  0.00%   0 REP Topology cha
260           0         1          0  0.00%  0.00%  0.00%   0 TC SIP
261           0         2          0  0.00%  0.00%  0.00%   0 IP PORTBUNDLE
262           0         1          0  0.00%  0.00%  0.00%   0 SG CMD HANDLER
263        1868  71602695          0  0.00%  0.00%  0.00%   0 RADIUS Proxy
264           0         1          0  0.00%  0.00%  0.00%   0 vaccess_lock_pro
265           0         1          0  0.00%  0.00%  0.00%   0 va_lock_ha_proce
266           0         1          0  0.00%  0.00%  0.00%   0 AC Switch
267           0         2          0  0.00%  0.00%  0.00%   0 EFP Errd
268           0         1          0  0.00%  0.00%  0.00%   0 LSP Tunnel FRR
269           0         1          0  0.00%  0.00%  0.00%   0 MPLS Auto-Tunnel
270           0         1          0  0.00%  0.00%  0.00%   0 O-UNI Client Msg
271           0         1          0  0.00%  0.00%  0.00%   0 IP Traceroute
272         652     46233         14  0.00%  0.00%  0.00%   0 CEF background p
273           0         1          0  0.00%  0.00%  0.00%   0 IP IRDP
274         740     38874         19  0.00%  0.00%  0.00%   0 IP Background
275      312996    310315       1008  0.00%  0.01%  0.00%   0 IP RIB Update
276           0         1          0  0.00%  0.00%  0.00%   0 ATM HA
277           0         3          0  0.00%  0.00%  0.00%   0 SNMP Timers
278           0         1          0  0.00%  0.00%  0.00%   0 XDR background p
279       81292    232827        349  0.00%  0.00%  0.00%   0 XDR mcast
280           0         1          0  0.00%  0.00%  0.00%   0 CEM PROC
281           0         1          0  0.00%  0.00%  0.00%   0 CEM HA
282       65000   1184311         54  0.00%  0.00%  0.00%   0 BGP I/O
283    22508264    118875     189348 11.83%  1.53%  1.12%   0 BGP Scanner
284           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
285           0        48          0  0.00%  0.00%  0.00%   0 static
286           0         1          0  0.00%  0.00%  0.00%   0 FR HA
287        2280   7765171          0  0.00%  0.00%  0.00%   0 TCP Timer
288        3928     18283        214  0.00%  0.00%  0.00%   0 TCP Protocols
289           0      7747          0  0.00%  0.00%  0.00%   0 HTTP CORE
290           0         1          0  0.00%  0.00%  0.00%   0 HSRP HA
291           0         1          0  0.00%  0.00%  0.00%   0 IDS Timer
292           0         1          0  0.00%  0.00%  0.00%   0 Inspect Timer
293           0         6          0  0.00%  0.00%  0.00%   0 MRIB RP Proxy
294           0         2          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
295         436    434861          1  0.00%  0.00%  0.00%   0 IPC LC Message H
296           0         2          0  0.00%  0.00%  0.00%   0 XDR RP Ping Back
297         324     38757          8  0.00%  0.00%  0.00%   0 XDR RP backgroun
298           0         1          0  0.00%  0.00%  0.00%   0 XDR RP Test Back
299           0         1          0  0.00%  0.00%  0.00%   0 RETRY_REPOPULATE
300           0         3          0  0.00%  0.00%  0.00%   0 IPv6 ACL RP Proc
301           0         1          0  0.00%  0.00%  0.00%   0 LSD HA Proc
302        1452    232340          6  0.00%  0.00%  0.00%   0 QoS stats proces
303           0         1          0  0.00%  0.00%  0.00%   0 SLB CF process
304           0         1          0  0.00%  0.00%  0.00%   0 VRRP HA
305           0         1          0  0.00%  0.00%  0.00%   0 MFI Comm RP Proc
306           0         1          0  0.00%  0.00%  0.00%   0 LDP HA
307           0         2          0  0.00%  0.00%  0.00%   0 MPLS VPN HA Clie
308           0         1          0  0.00%  0.00%  0.00%   0 RSVP HA Services
309           0         2          0  0.00%  0.00%  0.00%   0 TSPTUN HA
310           0         1          0  0.00%  0.00%  0.00%   0 ac_atm_state_eve
311           0         1          0  0.00%  0.00%  0.00%   0 ATM HA AC
312           0         2          0  0.00%  0.00%  0.00%   0 BD MACSEC HA
313           0         1          0  0.00%  0.00%  0.00%   0 CEM HA AC
314           0         1          0  0.00%  0.00%  0.00%   0 XC RIB MGR
315           0         1          0  0.00%  0.00%  0.00%   0 CMFI VPN HA Proc
316           0         1          0  0.00%  0.00%  0.00%   0 AAA HA
317           0         2          0  0.00%  0.00%  0.00%   0 ATIP_UDP_TSK
318           0         2          0  0.00%  0.00%  0.00%   0 PPP NBF
319           0         1          0  0.00%  0.00%  0.00%   0 Cv6 RP Process
320           0         2          0  0.00%  0.00%  0.00%   0 XDR FOF process
321           0         4          0  0.00%  0.00%  0.00%   0 mfib-const-rp Pr
322        3468   3319689          1  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
323           0         6          0  0.00%  0.00%  0.00%   0 ADJ background
324           0         1          0  0.00%  0.00%  0.00%   0 HQF MSFC Event P
325           0         2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
326           0         2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
327           0         1          0  0.00%  0.00%  0.00%   0 COPS
328           0         1          0  0.00%  0.00%  0.00%   0 802.1x Critical
329           0         1          0  0.00%  0.00%  0.00%   0 MAB Framework
330        9576   2547247          3  0.00%  0.00%  0.00%   0 L3 Manager
331           0         4          0  0.00%  0.00%  0.00%   0 L3 Manager Commo
332        1564   3254460          0  0.00%  0.00%  0.00%   0 FM core
333           0         1          0  0.00%  0.00%  0.00%   0 GLBP HA
334           0         1          0  0.00%  0.00%  0.00%   0 Probe Input
335           0         1          0  0.00%  0.00%  0.00%   0 IMA HA
336           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
337           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
338           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
339           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
340           0         1          0  0.00%  0.00%  0.00%   0 CFIB RP process
341         408        16      25500  0.00%  0.00%  0.00%   0 Collection proce
342           0         5          0  0.00%  0.00%  0.00%   0 Const Rate Limit
343     1930880   1161918       1661  0.00%  0.08%  0.07%   0 HIDDEN VLAN Proc
344           0         1          0  0.00%  0.00%  0.00%   0 FR XDR manager
345           0         1          0  0.00%  0.00%  0.00%   0 CWAN LTL manager
346           0         1          0  0.00%  0.00%  0.00%   0 CWAN-RP SCP Proc
347           0         4          0  0.00%  0.00%  0.00%   0 CWAN-RP SCP Inpu
348           0         1          0  0.00%  0.00%  0.00%   0 DHCP Snooping HA
349           0         3          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
350           0         6          0  0.00%  0.00%  0.00%   0 IPHC RP Process
351           4         2       2000  0.00%  0.00%  0.00%   0 L2TRACE SERVER
352           0         1          0  0.00%  0.00%  0.00%   0 MLSM-CC Process
353           0         2          0  0.00%  0.00%  0.00%   0 CWPA QoS
354           0         2          0  0.00%  0.00%  0.00%   0 Const TCAM Mgr R
355           0         2          0  0.00%  0.00%  0.00%   0 MWAM_CONSOLE Tim
356           0         1          0  0.00%  0.00%  0.00%   0 Container Proces
357          28    567346          0  0.00%  0.00%  0.00%   0 IP SIP Process
358           0         2          0  0.00%  0.00%  0.00%   0 IP Inband Sessio
359           0         1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
360           0         1          0  0.00%  0.00%  0.00%   0 Crypto HW Proc
361           0         2          0  0.00%  0.00%  0.00%   0 LFDp Input Proc
362           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
363           0         2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
364           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
365           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
366         432         4     108000  0.00%  0.00%  0.00%   0 BGP Event
367           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
368           0         1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
369           0         3          0  0.00%  0.00%  0.00%   0 MPLS Auto Mesh P
370           0         2          0  0.00%  0.00%  0.00%   0 Crypto Support
371           0        13          0  0.00%  0.00%  0.00%   0 crypto engine pr
372           0         1          0  0.00%  0.00%  0.00%   0 encrypt proc
373           0         7          0  0.00%  0.00%  0.00%   0 Crypto CA
374           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
375           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
376           0         1          0  0.00%  0.00%  0.00%   0  Laminar Icc Eve
377           0         2          0  0.00%  0.00%  0.00%   0 SLB Main CPU pro
378           0         4          0  0.00%  0.00%  0.00%   0 Crypto ACL
379           0         1          0  0.00%  0.00%  0.00%   0 Crypto INT
380           0         3          0  0.00%  0.00%  0.00%   0 Crypto IKMP
381         140    116183          1  0.00%  0.00%  0.00%   0 IPSEC key engine
382           0         1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
383           0         1          0  0.00%  0.00%  0.00%   0 Key Proc
384           0         2          0  0.00%  0.00%  0.00%   0 Lawful Intercept
385           0         2          0  0.00%  0.00%  0.00%   0 LI messaging
386           0         1          0  0.00%  0.00%  0.00%   0 LI C6K
387           0         1          0  0.00%  0.00%  0.00%   0 LI C6K PROV
388           0         1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
389           0         1          0  0.00%  0.00%  0.00%   0 DATA Collector
390           0         2          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
391           0        14          0  0.00%  0.00%  0.00%   0 EEM ED Resource
392           0        27          0  0.00%  0.00%  0.00%   0 EEM ED Track
393           0         1          0  0.00%  0.00%  0.00%   0 L3MM Process
394           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
395           0         6          0  0.00%  0.00%  0.00%   0 RPC aapi_rp
396           0        37          0  0.00%  0.00%  0.00%   0 RPC capi_rp
397           0         2          0  0.00%  0.00%  0.00%   0 RPC chapi_rp
398           0         9          0  0.00%  0.00%  0.00%   0 RPC dot1x_aaa_rp
399           0         2          0  0.00%  0.00%  0.00%   0 RPC ether_oam_sp
400           0         2          0  0.00%  0.00%  0.00%   0 RPC epld_sp2rp
401           0         2          0  0.00%  0.00%  0.00%   0 RPC gvrp_sp2rp
402           0         2          0  0.00%  0.00%  0.00%   0 RPC idbman_sp2mp
403           0         1          0  0.00%  0.00%  0.00%   0 LC Registry Expo
404         272    285779          0  0.00%  0.00%  0.00%   0 RPC online_diag_
405           0         2          0  0.00%  0.00%  0.00%   0 RPC online_wan_d
406           0         2          0  0.00%  0.00%  0.00%   0 RPC pagp_switch_
407           0        10          0  0.00%  0.00%  0.00%   0 RPC pm_switch_sp
408           0         2          0  0.00%  0.00%  0.00%   0 RPC psecure_rp
409           0         2          0  0.00%  0.00%  0.00%   0 RPC pt_switch_sp
410           0         9          0  0.00%  0.00%  0.00%   0 RPC qnq_switch_s
411           0         2          0  0.00%  0.00%  0.00%   0 RPC rf_cli_sp2rp
412           0         1          0  0.00%  0.00%  0.00%   0 SONET Traps
413           0       222          0  0.00%  0.00%  0.00%   0 TCP Listener
414           0         2          0  0.00%  0.00%  0.00%   0 VTPMIB EDIT BUFF
415           0         3          0  0.00%  0.00%  0.00%   0 RPC snmp_notify
416           0         2          0  0.00%  0.00%  0.00%   0 RPC snmp_stackli
417           0         2          0  0.00%  0.00%  0.00%   0 RPC span_switch_
418           0         2          0  0.00%  0.00%  0.00%   0 RPC stp_sp2mp_ap
420           0         2          0  0.00%  0.00%  0.00%   0 Module enable-di
421          28        41        682  0.00%  0.00%  0.00%   0 RPC c6k_power_rp
422           0        55          0  0.00%  0.00%  0.00%   0 RPC c6k_rp_envir
423           0         1          0  0.00%  0.00%  0.00%   0 CONST AFL
424           0         2          0  0.00%  0.00%  0.00%   0 RPC cwan_ltl_sp2
425          28    385475          0  0.00%  0.00%  0.00%   0 RP Error Detecti
426           0         2          0  0.00%  0.00%  0.00%   0 RPC error_detect
427           0         1          0  0.00%  0.00%  0.00%   0 HW Capacity ICC
428           0         2          0  0.00%  0.00%  0.00%   0 RPC itasca_rp
429           0         1          0  0.00%  0.00%  0.00%   0 RP L2 Applicatio
430           0         3          0  0.00%  0.00%  0.00%   0 LACP-MP Process
431           0        12          0  0.00%  0.00%  0.00%   0 Online Diag EEM
432           0         3          0  0.00%  0.00%  0.00%   0 PAgP-MP Process
433           0         2          0  0.00%  0.00%  0.00%   0 RPC pclc_g2_agsm
434           0         2          0  0.00%  0.00%  0.00%   0 RPC pclc_g2_fw_r
435           4        21        190  0.00%  0.00%  0.00%   0 Logger ICC Proce
436           0         2          0  0.00%  0.00%  0.00%   0 RPC pf_issu_sp2r
437           0         2          0  0.00%  0.00%  0.00%   0 RPC pikachu_rp
438       48852   2183453         22  0.00%  0.00%  0.00%   0 PDU DISPATCHER
439          12       159         75  0.00%  0.00%  0.00%   0 RPC pm-mp
440         124   1110423          0  0.00%  0.00%  0.00%   0 PM Callback
441      236436   6912760         34  0.00%  0.01%  0.00%   0 Port manager per
442         128    464624          0  0.00%  0.00%  0.00%   0 Max CPU utilizat
443           0         6          0  0.00%  0.00%  0.00%   0 RPC lcc_sp
444           0         8          0  0.00%  0.00%  0.00%   0 RPC fabman_sp
445           0       647          0  0.00%  0.00%  0.00%   0 rp to lc clock u
446          32     38727          0  0.00%  0.00%  0.00%   0 SPA ENTITY Proce
447      394116   2381019        165  0.00%  0.04%  0.03%   0 SNMP ENGINE
448           0         2          0  0.00%  0.00%  0.00%   0 SPAN Capture
449           0         3          0  0.00%  0.00%  0.00%   0 EC-Card-Cfg
450           0         2          0  0.00%  0.00%  0.00%   0 RPC sw_backup_in
451           0        36          0  0.00%  0.00%  0.00%   0 RPC sw_vlan_rp
452           0         4          0  0.00%  0.00%  0.00%   0 RPC udld_rp
453           0        16          0  0.00%  0.00%  0.00%   0 RPC vtp_const_ap
454           0         2          0  0.00%  0.00%  0.00%   0 RPC rep_sp2rp_ap
455           0         2          0  0.00%  0.00%  0.00%   0 RPC dot1ad_sp2mp
456           0         2          0  0.00%  0.00%  0.00%   0 Rommon upgrade p
457           0         2          0  0.00%  0.00%  0.00%   0 EEM ED CLI
458           0         1          0  0.00%  0.00%  0.00%   0 CWAN OIR IPC Rea
459           0         1          0  0.00%  0.00%  0.00%   0 PF Clock Process
460           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
461           0         3          0  0.00%  0.00%  0.00%   0 EM ED GOLD
462           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
463           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
464           0         3          0  0.00%  0.00%  0.00%   0 EEM ED None
465           0         3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
466           0         5          0  0.00%  0.00%  0.00%   0 EEM ED RF
467           0         3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
468           4     58194          0  0.00%  0.00%  0.00%   0 EEM ED Timer
469           4         2       2000  0.00%  0.00%  0.00%   0 EEM ED Test
470           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Config
471           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Env
472           0         2          0  0.00%  0.00%  0.00%   0 Call Home proces
473           0         1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
474           0         1          0  0.00%  0.00%  0.00%   0 IP SLA AutoEther
475           8       852          9  0.00%  0.00%  0.00%   0 DRMI Config Disp
476          72    109920          0  0.00%  0.00%  0.00%   0 Syslog
477           0         4          0  0.00%  0.00%  0.00%   0 CWAN Bridge task
478           0         2          0  0.00%  0.00%  0.00%   0 QM MRM Process o
479           0        16          0  0.00%  0.00%  0.00%   0 QM Process on RP
480           0         2          0  0.00%  0.00%  0.00%   0 QM Reply Process
481           0         2          0  0.00%  0.00%  0.00%   0 QM Timer ACL Pro
482          24    185889          0  0.00%  0.00%  0.00%   0 DHCP Snooping Sw
483          12     38730          0  0.00%  0.00%  0.00%   0 Call Home Timer
484           0         2          0  0.00%  0.00%  0.00%   0 CONST PC POLICYM
485           0         1          0  0.00%  0.00%  0.00%   0 Online Diag CNS
486           0         1          0  0.00%  0.00%  0.00%   0 Online Diag CNS
487           4     38731          0  0.00%  0.00%  0.00%   0 VACL Logger
488           0         6          0  0.00%  0.00%  0.00%   0 REP RP Proc
489           0         2          0  0.00%  0.00%  0.00%   0 SIP10G QM Proces
490         108    114369          0  0.00%  0.00%  0.00%   0 IP SLA MPLSLM Pr
491           0         1          0  0.00%  0.00%  0.00%   0 IP SNMPV6
492           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
493           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
494         608    308720          1  0.07%  0.00%  0.00%   1 Virtual Exec
TC2_7606_BGPGW-B#sh ip cef switching statistics
       Reason                          Drop       Punt  Punt2Host
RP LES No route                         653          0         18
RP LES Packet destined for us             0    3908700          0
RP LES No adjacency                  363286          0          0
RP LES Incomplete adjacency            5160          0          0
RP LES Unresolved route                  56          0          0
RP LES Bad checksum                     816          0          0
RP LES TTL expired                        0          0    2891780
RP LES Routed to Null0               324034          0     192074
RP LES Neighbor resolution req       422871        109          0
RP LES Total                        1116876    3908809    3083872
All    Total                        1116876    3908809    3083872
The output says 34% of the time cpu was working on interrupt level; about 20% of the time cpu was working on the traffic need to be processed switched. It also says the bgp scanner uses lot cpu at that time; do you have aggressive bgp scan-time configured for bgp peers? If you want fast convergence, consider next hop tracking feature is better than tunning bgp scan-timer.
Here are the documentation of troubleshotting high cpu due to BGP scanner
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00809d16f0.shtml
and BGP NHT feature
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/gt_bnht.html#wp1052843
HTH,
Lei Tian
paolo bevilacqua
You have posted the same question in another thread.
Please do not open duplicates.
Thanks for the notice Paolo!
Arunachala Prabu, please use https://supportforums.cisco.com/message/3162147#3162147 for your high cpu troubleshooting.
Lei Tian
