Cisco 7609 with Sup720 and MSFC3 card --- Per packet load sharing command
sgopikrishnan
I have checked in 2 cisco 7609 routers i did not find the "ip load sharing per-packet" command itself on physical interface or logincal interface also.
IOS tried SRA and SRC releases:-
example:-
DD(config)# int mul 11
DD(config-if)#ip load-sharing
DD(config-if)#ip load-sharing ?
per-destination Deterministic distribution
I am not able disable the CEF in this platform also and "no ip route-cache" command is also not there.
The below link says the command is integrated on cisco SRA release
http://www.cisco.com/en/US/docs/ios/ipswitch/command/reference/isw_i1.html#wp1012465
anybody has seen the same issue or is it a hardware limitation.
--> I think it is a hardware limitation.
Any comments
GK
9 Replies 9
Giuseppe Larosa
Hello Gopikrishnan,
as already explained in another thread multilink PPP performs per-packet load-balancing on its own so the command you are looking is not needed it is already happening.
and CEF is needed in a multilayer switch
compare with
sh ppp multilink
sh int ser x/y
sh int ser x/z
you should see load balancing in action
Hope to help
Giuseppe
Hello Gopikrishnan ,
have a look at RFC1717 that defines MLPPP
http://www.faqs.org/rfcs/rfc1717.html
"Once multilink has been successfully negotiated, the sending system
is free to send PDUs encapsulated and/or fragmented with the
multilink header."
Hope to help
Giuseppe
my requirement is per packet load balancing between 2 multilinks(each link has 20 E1) and per packet option is not available only on Cisco 7609 router.
Everything is working fine on 7206(per packet and per destination options available on physical and multilink interface
Why this is not happening on 7609 platform?
I am finding the same in 6509 platform.
Are these 2 plaform designed only for fast switching 6509 and 7609 platforms
per-packet load-sharing?
disable CEF ??
These things are very much not kosher in networking, it is a good thing that have been eliminated from these L3 switches.
Thanks for response,
My requirement is per packet load balancing between 2 multilinks(each link has 20 E1) and per packet option is not available only on Cisco 7609 and 6509 router with Sup720 and MSFC3 card.
>>By default / RFC on Single multilink it is per packet and when i have 2 multilinks in these platform i am not able perform this per packet using the commands ?
is it a hardware limitation ?
or with any hardware upgradation(like sup or msfc) solve my issue on 7609 routers ???
any cisco links related to this.
kindly help me out.
GK
Per-packet load sharing cause out-of-order packets, and it should never be done.
If you need to aggreagte many many Eq1 lines, get inverse muxes to E3 then try to MLPPPon the E3s.
Hello Gopikrishnan,
please read the RFC that defines multilink PPP as I tried to explain twice
you don't need per-packet load -sharing on a multilink bundle PPP multilink does its own per packet load balancing.
even in a C7206 you may be able to give the command but it is not that command that makes the ppp multilink to load balances per-packet on the member links it is built-in in the feature.
And don't try to disable CEF on C7600 or C6509 is needed to work ( I hope you cannot disable it)
Hope to help
Giuseppe
Thanks for the help Giuseppe
>I have 2 bundled Multilinks on 7609. By RFC in a single bundled multilinks it is per packet.
>now i am trying load sharing with 2 multilink bundles on per packet.
>in 7206 after giving per packet option only it started to load share between 2 bundles.
R7609|---- Mul 1(bundled 20 E1 links)
|---- Mul 2(bundled 20 E1 links)
>> when a session goes from 7609 i want to make use of both bundles.
GK
