08-17-2011 05:34 AM - edited 03-04-2019 01:18 PM
I need to set up a Bridged router with a external ip address so I can manage it.
The Cisco 800 does the ADSL Sync and we have a firewall behind with a WAN address but we have 5 usable ip addresses on the WAN side, can anyone tell me how I can configure it so I can get to the cisco contactable from the internet and the firewall behind? Here is the config
no ip routing
no ip cef
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
no snmp trap link-status
no atm ilmi-keepalive
dsl operating-mode adsl2+
interface ATM0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
no ip route-cache
atm route-bridged ip
pvc 0/101
encapsulation aal5snap
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan1
ip address *additional WAN* *WAN subnet*
ip nat inside
no ip route-cache
bridge-group 1
interface BVI1
no ip address
no ip redirects
ip nat outside
ip route 0.0.0.0 0.0.0.0 *WAN Gateway*
bridge 1 route ip
08-19-2011 02:31 AM
Does no one know? Is it not possible?
08-19-2011 07:46 AM
Hello Techmasterblue,
if the device is used as a bridge allows for an easy setup but it becomes difficult to manage.
your configuration is a mix between a bridged and a routed solution
to use NAT you would need a routed solution there is no sense in attempting to configure NAT that is an IP translation on an interface that does not process IP packets like your BVI1.
so you should move the public IP address to BVI1 and you should use a private IP address on the Vlan interface that can use a NAT pool carved from the public IP addresses
to be noted with your current configuration you should be able to access it but NAT shouldn't work this is what I see at first glance
Hope to help
Giuseppe
