Cisco 819-4G supported UMTS frequencies
sebastian.lemke
I am just reading through the data sheet of the 819-4G routers (http://www.cisco.com/en/US/prod/collateral/routers/ps10906/ps380/ps11615/data_sheet_c78-678459.html). There are several models for different regions.
The one I'm interested in is the C819G-4G-G-K9, which is the one to get for Europe.
However there is also a hardened version C819HG-4G-G-K9 for "stationary and mobile environments where space,  heat dissipation, exposure to extreme temperatures, harsher  environments, and low power consumption are critical factors".
I would suppose, that the hardened and non-hardened versions are equal concerning supported LTE and UMTS frequencies. But when I look at the table 6, I see a difference:
C819HG-4G-G-K9     900/1900/2100 MHz UMTS/HSPA bands
C819G-4G-G-K9     900/2100 MHz UMTS/HSPA bands
Is it just some sort of typo, or is the non-hardened version really not capable to use the 1900 MHz band?
sebastian.lemke
@Cisco guys: I suppose, the support forum is not the best place to ask such questions. Who should I contact?
sebastian.lemke
I found another reference which states, that the supported frequencies are exactly the same for both models (the same Sierra Wireless MC7710 modem is used)
http://www.cisco.com/en/US/docs/routers/access/800/819/hardware/install/guide/pview.html#wp1106999
800 MHz (band 20)/900 MHz (band 8)/1800 MHz (band 3)/2100 MHz (band 1)/2600 MHz (band 7) for LTE
900/2100 MHz for UMTS/ HSPA+/HSPA
900/1800/1900 MHz for GSM/EDGE/GPRS
