Cisco 819 Celluar ip is different from whatismyip.com
owen2
HI ALL,
implement cisco 819 4G router on remote office and VPN back to HQ
After all Nat and access-list si done, the remote side is able to access the internet.
When implementing IPsec VPN, the IP shown on cellular  Interface  (10.234.79.18) is different on whatismyip.com ( 183.90.37.234)
try to set both IP as a peer.
none works form the case.
Does this mean i not able to setup Ipsec VPN?
config as below:
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip domain name Winston.local
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
chat-script gsm "" "ATDT*98*2#" TIMEOUT 60 "CONNECT"
liid C819HG-4G-G-K9 sn FGL193423MB
controller Cellular 0
ip ssh time-out 90
ip ssh authentication-retries 2
crypto isakmp policy 1
es 256
authentication pre-share
group 14
crypto isakmp key Pass12 address X.X.X.X
crypto ipsec transform-set VPN esp-3des esp-sha512-hmac
mode tunnel
crypto map VPN 1 ipt
set peer X.X.X.X
set transform-set VPN
match address VPN-FG
interface Cellular0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-and
dialer string lte
dialer watch-group 1
async mode interactive
crypto map VPN
routing dynamic
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
ce 2000000
interface Vlan1
ip address 10.20.1.254 255.255.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip access-lisnded VPN-FG
permit ip 10.20.0.0 0.0.255.255 10.10.0.0 0.0.255.255
dialer watch-list 1 ip 5.6.7.8 0.0.0.0
dialer watch-list 1 delay connect 1
dialer-list 1 protocol ip permit
access-list 100 permit ip 10.20.0.0 0.0.255.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
exec-timeouodem enable
stopbits 1
line aux 0
stopbits 1
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
script dialer lte
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
login
transport input all
no scheduler max-task-time
scheduler allocate 20000 1000
ntp update-calendar
end
on the HQ side, you need to configure a dynamic map, in order to deal with the dynamic/changing IP address on the 819. It is actually very common to do that, and fairly simple. Post the configuration of the HQ router so we can fill in the bits and pieces...
Hello @Georg Pauwen
Not sure i understand your statement regards a dynamic map - Can you elaborate
This OP seems to indicate ipsec with nat is the problem and if it is it would be most probably due to the tunnel source header of the packet being change with the post natted tunnel source header - which is usually down to ipsec and nat not being compatible- So to over come this NAT -Traversal is used which basically encapsulates the ipsec in it own non encrypted header to allow communication.
Kind Regards
Paul
Hello Paul,
as I understand it, NAT is working, but the IPSec VPN is not, due to the cellular interface having a dynamic IP address...
--> implement cisco 819 4G router on remote office and VPN back to HQ
--> After all Nat and access-list si done, the remote side is able to access the internet.
--> try to set both IP as a peer.
--> none works form the case.
Either way, better ask OP...
Hello
just to confirm
GRE VPN - NAT works
IPSEC/GRE VPN no NAT doesn’t work
Kind Regards
Paul
