Cisco 819 - chat script OK but int cellular0 do not get ip address
acleri
We configure a cisco 819 as follow:
chat-script hspa "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
interface Cellular0
ip address negotiated
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string hspa
dialer-group 1
async mode interactive
line 3
script dialer hspa
modem InOut
no exec
rxspeed 21600000
txspeed 5760000
the following output show that the chat-script is correctly working
yourname#start-chat hspa 3
yourname#
*Dec  4 17:07:02.019: CHAT3: Matched chat script hspa to string hspa
*Dec  4 17:07:02.019: CHAT3: Asserting DTR
*Dec  4 17:07:02.019: CHAT3: Chat script hspa started
*Dec  4 17:07:02.019: CHAT3: Sending string: AT!SCACT=1,1
*Dec  4 17:07:02.019: CHAT3: Expecting string: OK
*Dec  4 17:07:02.019: CHAT3: Completed match for expect: OK
*Dec  4 17:07:02.019: CHAT3: Chat script hspa finished, status = Success
yourname#sh cellular 0 connection
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = ACTIVE
        IP address = 10.147.5.124
        Primary DNS address = 212.98.37.131
        Secondary DNS address = 194.230.55.97
        Negotiated QOS Parameters:
        Precedence = Normal Priority, Delay = Class 3
        Reliability = Unack GTP, LLC, Ack RLC, Protected data
        Peak = 256 kB/sec, Mean = 50000 kB/hr
        Traffic Class = Interactive
        Uplink Max = 11.5Mbps, Guaranteed = Subscribed
        Downlink Max = 42Mbps, Guaranteed = Subscribed
        Max SDU size = 1500 bytes
        SDU error ratio = 1E-4, BER = 1E-5
but on the cellular0 interface we do not get any ip address....
Any suggestion or ideas?
thank you!
yourname#sh ip int c0
Cellular0 is up, line protocol is up
  Internet address will be assigned dynamically by the network
  Broadcast address is 255.255.255.255
yourname#sh ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 16:14 by prod_rel_team
ROM: System Bootstrap, Version 15.1(4r)M, RELEASE SOFTWARE (fc1)
yourname uptime is 19 minutes
System image file is "flash:c800-universalk9-mz.SPA.152-4.M4.bin"
Cisco C819HG+7-K9 (revision 3.0) with 492620K/31667K bytes of memory.
Processor board ID FCZ1743C24B
4 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial(sync/async) interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 Cellular interface
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash (Read/Write)
mradova01
Do you mind posting your current Run Configuration?
hi misha,
sorry not updating this thread.
the 3g modem configuration was correct, the interface c0 came up after doing a ping so we configured an sla.
Can I ask you for what IOS are you running this on? I am currently experiencing the same issue with IOS
Version 15.2(4)M4. I am trying to determine whether it is the IOS that's preventing me from using similar configurations that other people posted, which work for them, but not for me.
Yes, you need to initiate the traffic for this to work. I have done a lot of POC on this and have a blueprint config if someone needs it.
Also, I ended up writing an EEM script to initiate the traffic as soon as router comes up and modem dials out.
Have a look at this for the EEM script write up. Please change the timers as needed.
https://techzone.cisco.com/t5/Cellular-Module/Yet-Another-Cellular-Modem-Recovery-Script/ta-p/287802
