Help: Cisco SOHO 97. PPP Configuration
Manuel Nin
Hi there!
I have a Cisco SOHO 97.
Here is my scenario:
LAN Network is: 10.0.0.0/24
Default route: 0.0.0.0
I need help to configure the DIALER1 port to connect to my provider:
To connect to my provider the username is: cotel
The password is: cotel.
I want the LAN users can be able to surf on the internet. (As normally)
Thanks.
Manuel
kbhatnag
Hi Manuel
Please try PPPoE configuratoin:
interface GigabitEthernetx/y
no ip address
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer0
mtu 1492
ip address negotiated or IP address x.x.x.x  x.x.x.x
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxx
ppp chap password xxxxxxx
ppp pap sent-username xxxxxxx password xxxxxxx
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit x.x.x.x y.y.y.y(wildcard mask)
ip route 0.0.0.0 0.0.0.0 Dialer0
I configured my router as you described.
I can ping the router from my LAN but it doesn't have internet. (I can't ping 8.8.8.8)
Now i tried to access the router via telnet but the router says:
Password required, but none set
How can I fix it? And... maybe you forget somes details because the configuration doesn't work.
to configure telnet, yuou need ot configure the line vty
line vty 0 4
login
password
end
make sure you have enable password configured as well.
