Cisco 819 Wan-Fail Over using DNS lookup
plussier1
I there a way to configure the Cisco 819 to Switch between primary WAN-1 interface GigabitEthernet 0 and Backup WAN-2 on cellular 0 interface ?
On this router I use EIGRP Tunnel and Ip-Sec tunnel too.
I tried IP-SLA but doesn't work at 100% at the moment.
track 1 ip sla 1 reachability
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet0
timeout 6000
frequency 10
ip sla schedule 1 life forever start-time now
ip route 0.0.0.0 0.0.0.0 192.168.37.1 track 1
ip route 0.0.0.0 0.0.0.0 Cellular0 5
Exemple WAN-1 Up
Track 1
IP SLA 1 reachability
Reachability is Up
4 changes, last change 00:00:18
Latest operation return code: OK
Latest RTT (millisecs) 23
Tracked by:
Static IP Routing 0
Exemple Wan-1 Still Up but no Internet Access
*Jan 13 04:22:11.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:22:16.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:22:31.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:22:36.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:22:51.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:22:56.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:23:11.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:23:16.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:23:31.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:23:36.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:23:51.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:23:56.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:24:11.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:24:16.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:24:31.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:24:36.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:24:51.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:24:56.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:25:11.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:25:16.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:25:31.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:25:36.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:25:51.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
*Jan 13 04:25:56.707: %TRACK-6-STATE: 1 ip sla 1 reachability Down -> Up
*Jan 13 04:26:11.707: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
etc.......
It's look like that the icmp-echo 8.8.8.8 source-interface GigabitEthernet0 pass also by the interface cellular 0, that why Goes UP-DOWN non stop
What is the way to correct that ?
Here is the Route-Map config on the router
ip nat inside source route-map NAT-WAN1 interface GigabitEthernet0 overload
ip nat inside source route-map NAT-WAN2 interface Cellular0 overload
route-map NAT-WAN2 permit 10
match ip address NAT
match interface Cellular0
route-map NAT-WAN1 permit 10
match interface GigabitEthernet0
ip access-list extended NAT
deny ip 172.16.5.0 0.0.0.255 172.16.1.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.50.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.51.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.52.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.53.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.55.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.56.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.57.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.58.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.59.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.60.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.62.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.63.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.81.0 0.0.0.255
deny ip 192.168.54.0 0.0.0.255 192.168.82.0 0.0.0.255
permit ip 172.16.5.0 0.0.0.255 any
permit ip 172.18.5.0 0.0.0.255 any
permit ip 192.168.37.0 0.0.0.255 any
permit ip 192.168.54.0 0.0.0.255 any
Thank You !
7 Replies 7
post the full config. Are you excluding the NAT traffic from the traffic that goes over the tunnel ?
Please see the attached File. This is the full config of my Router.
All Tunnel is Working, the issues is with IP SLA to ping DNS 8.8.8.8 to enbale WAN Failover between Primary ISP WAN-1 and backup ISP WAN-2.
Let me know !
Thank You !
Have a good day !
thanks for the config. My first thought is that the tunnel delays on the tunnels using the cellular interface as the source should be higher than the delays configured on the interfaces using the GigabitEthernet as the source. Try to change the delays as below:
interface Tunnel21
 delay 100
interface Tunnel22
 delay 150
interface Tunnel23
 delay 200
interface Tunnel24
 delay 250
I did all the modification that you post but unfortunately Still does the same thing. When to Router pass to the Backup ISP on WAN-2 the IP SLA State goes Up and Down non Stop.
I did some other test and I think that I find how to correct the issues, but I’m not sure if it's a good way to do it works.
1) First I remove the permit ip 192.168.37.0 0.0.0.255 any from the ip access-list extended NAT
2) Second I created a permanent Route for the DNS 216.146.35.35 That I have chosen to use instead of 8.8.8.8
ip route 216.146.35.35 255.255.255.255 dhcp permanent
Now it's working but the only thing Is that the DNS 216.146.35.35 is not reachable from the backup interface WAN-2, but I did not use this address like DNS on Computer and other device on the network. I always use 8.8.8.8
I have an other question about IP SLA command
ip sla 1
icmp-echo 216.146.35.35 source-interface GigabitEthernet0
timeout 6000
frequency 10
How many ping the SP SLA command send before considering a DOWN State ?
If only one ping have a Time Out of more then 6000ms, is the IP SLA will goes on DOWN State ?
or they analyze more that one ping ?
example
1- icmp-echo 216.146.35.35 source-interface GigabitEthernet0 Timeout 2000ms OK
10Sec. delay
2-  icmp-echo 216.146.35.35 source-interface GigabitEthernet0 Timeout 8000ms Bad
10Sec. delay
3-  icmp-echo 216.146.35.35 source-interface GigabitEthernet0 Timeout 2000ms OK
Is in this case because only one ping get more that 6000ms is the track 1 ip sla 1 reachability will goes Down ?
If the answer is Yes,
Is there a way to analyse more than one ping before the track 1 ip sla 1 reachability will goes Down ?
Thank you again for your help.
Patrick
Hello Patrick,
I took a look at your original configuration, and I wonder if implementing the following makes a difference. Basically, local ICMP traffic (which would be the traffic generated by the SLA) gets forced out the primary interface:
ip local policy route-map PRIMARY_TRACK
route-map PRIMARY_TRACK permit 10
match ip address 115
set interface GigabitEthernet0
access-list 115 permit icmp any host 8.8.8.8
I tried to add the command to the original Config, but unfortunately Still does the same thing. When to Router pass to the Backup ISP on WAN-2 the IP SLA State goes Up and Down non Stop.
Thank You !
Hello
Ip sla flaps could be due to your sla frequency being to long for the tracking delay- Can you try adding a tracking delay higher then the sla frequency
track 1
delay 30
On a side note -I can see you your primary default route is incorrect - it should be referring to DHCP not the next hop ip.
no ip route 0.0.0.0 0.0.0.0 192.168.37.1 track 1
ip route 0.0.0.0 0.0.0.0 dhcp track 1
res
Paul
Kind Regards
Paul
