Cisco 8194G Issue when create WAN-1 PPPOE Dialer 1 profile and Integrated Cellular 0 Interface like WAN-2
plussier1
Before i add the Dialer 1 configuration for WAN-1 PPPOE internet access the Cellolar 0 interface working well.
When I add the Dialer 1 Interface Config and I plug it to the DSL modem, now the primary internet WAN-1 (PPPOE) is working but
look like that something conflict with the interface cellular 0 because now, WAN-2 doesn't work even if the WAN-1 interface Is down.
Please see the Part of the Configuration bellow.
I think they have conflict between Dialer-Group ?
How can I resolve that ?
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
controller Cellular 0
 lte modem link-recovery rssi onset-threshold -110
 lte modem link-recovery monitor-timer 20
 lte modem link-recovery wait-timer 10
 lte modem link-recovery debounce-count 6
interface Cellular0
 ip address negotiated
 ip nat outside
 ip virtual-reassembly in
 encapsulation slip
 dialer in-band
 dialer string lte
 dialer-group 1
 async mode interactive
 crypto map xxxxxxx
interface Dialer1
 description WAN-1 BELL ADSL Logical Interface
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 dialer-group 1
 ppp authentication pap callin
 ppp pap sent-username xxxxx@bellnet.ca password 0 xxxxxx
 ppp ipcp dns request
 ppp ipcp route default
 ppp ipcp address accept
 no cdp enable
 crypto map xxxxxxx
dialer-list 1 protocol ip permit
Thank You !
post the full config if possible. What is your dialer interface bound to ? What interesting traffic do you have defined in the crypto map ?
Please see the attached configuration file.
At the moment this router is in operation on WAN-1 and everything is working.
Short Story, At the office with first configuration everything was working on cellular 0 interface and tested.
On Site We add the Dialer-1 interface configuration on the router for the WAN-1 PPPOE ADSL Internet access.
When the configuration was finish and wan-1 connected on ADSL Modem the router switch from Backup WAN-2 to Primary WAN-1 without issues.
Now the issues is when the WAN-1 (PPPOE) adsl connexion goes down, the Backup WAN-2 integrated LTE cellular 0 interface doesn't work anymore.
I did the test on site with a laptop plogged to the Router to generate trafic on Internet and when I unplug the WAN-1 connexion, WAN-2 doesn't work, cellular o interface doesn't come up, but as soon I plugged back the WAN-1 everything working again.
I saw that I use Dialer-Group1 on Both cellular 0 and Dialer 1 interface.
Is there a way that cause the conflict that now the cellular 0 doesn't come up anymore ?
Let me know.
Thank You !
the config looks good as far as I can tell. The only thing I am worried about are the permanent static routes which are not tracked. Can you try to remove those ?
no ip route 195.46.39.39 255.255.255.255 Dialer1 permanent
no ip route 208.76.50.50 255.255.255.255 Cellular0 permanent
no ip route 216.146.35.35 255.255.255.255 Dialer1 permanent
Hi Georg,
I remove the 3 permanent route but nothing change.
I need for sure the 2 Permanent route
to force the IPSLA to pass by the Dialer 1 interface to check the connexion status.
Do you have an other idea why the cellular 0 interface don't want to go up anymore ?
Thank You !
