Cisco 819G Cellular no IP address
Hello!
I am setting up my Cisco C819G+7-K9 router with SIM card with the following settings:
chat-script TELE2 "" "ATDT*99*1#" TIMEOUT 10 "OK"
interface Cellular0
 ip address negotiated
 encapsulation slip
 dialer in-band
 dialer string TELE2
 dialer-group 1
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer-list 1 protocol ip permit
line 3
 exec-timeout 0 0
 script dialer TELE2
 modem InOut
 no exec
 transport input all
There is no connection, no IP address. The output of sh ip interface br:
Interface                  IP-Address      OK? Method Status                Protocol
Cellular0                  unassigned      YES manual up                    up
show cellular 0 all
Hardware Information
Modem Firmware Version = T1_0_3_2AP R361 CNSZ
Modem Firmware built = 04/15/11
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = X.X.X
International Mobile Equipment Identity (IMEI) = X.X.X
Integrated Circuit Card ID (ICCID) = X.X.X
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Factory Serial Number (FSN) = CC3108503231011
Modem Status = Online
Current Modem Temperature = 31 deg C, State = Normal
PRI SKU ID = 9900198, SKU Rev. = 1.2
Profile Information
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = internet.tele2.ru
Authentication = CHAP
Username: mts
Password: mts
Profile 2 = INACTIVE
PDP Type = PPP
Username: tele
Password: tele
  * - Default profile
Configured default profile for active SIM 0 is profile 1.
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
        Inactivity Reason = Normal inactivate state
Profile 2, Packet Session Status = INACTIVE
Hello! Yes, I have made some settings in controller cellular 0 section:
controller Cellular 0
gsm gps mode standalone
But I cant made any setting with profile or something like this. Here are all setting that I can do in my cisco 819:
nag-cisco-router(config)#controller cellular 0
nag-cisco-router(config-controller)#?
Controller configuration commands:
default Set a command to its defaults
description Controller specific description
exit Exit from controller configuration mode
gsm GSM type carrier
help Description of the interactive help system
no Negate a command or set its defaults
nag-cisco-router(config-controller)#gs
nag-cisco-router(config-controller)#gsm ?
event cellular snmp event persistence
failovertimer Failover timeout value in mins
gps GPS configuration
interface Cellular interface
modem Modem logging configuration
radio Controller's radio
sim Subscriber Identity Module
sms SMS configuration
nag-cisco-router(config-controller)#gsm in
nag-cisco-router(config-controller)#gsm interface ?
<0-1> interface number
nag-cisco-router(config-controller)#gsm interface 0 ?
<48-80> Interface id length in bits: 64 bits for xxxx:xxxx:xxxx:xxxx
nag-cisco-router(config-controller)#gsm si
nag-cisco-router(config-controller)#gsm sim ?
authenticate CHV1 authentication
max-retry Maximum SIM switchovers
primary Controller's primary SIM
profile SIM Profile number
nag-cisco-router(config-controller)#gsm sm
nag-cisco-router(config-controller)#gsm sms ?
archive SMS archive configuration
nag-cisco-router(config-controller)#gsm rad
nag-cisco-router(config-controller)#gsm radio ?
off Power down radio
nag-cisco-router(config-controller)#gsm radio ^Z
% Incomplete command.
Do you know, what I need actually to setup in this section?
I made everything working! The problem was in chat-script:
chat-script TELE2 "" "AT!SCACT=1" TIMEOUT 60 "OK"
