CISCO 819G Cellular0 not responding
vinoth.sampath
Here I facing the issue on the cellular connection. When the router rebooted the link got connected after that automatically getting down with in a 5 seconds. Here I share the log on below, Kindly assist
Chat script  :  chat-script gsm "" "ATDT*99#" TIMEOUT 60 CONNECT
*Nov 20 09:28:30: %CELLWAN-2-SIM_FAILURE: [Cellular0]: SIM read failed for slot 0
*Nov 20 09:28:30: %CISCO800-2-MODEM_UP: Cellular0 modem is now UP.
*Nov 20 09:28:30: %CISCO800-6-SIM_STATUS: SIM in slot 0 is not present
*Nov 20 09:28:31: %CISCO800-2-MODEM_DOWN: Cellular0 modem is now DOWN.
*Nov 20 09:28:36: %CISCO800-6-SIM_ACTIVATION: SIM in slot 1 is being activated. Please wait for modem to come UP.
*Nov 20 09:28:44.027: CHAT3: Chat script gsm finished, status = Carrier dropped
*Nov 20 09:28:44.027: Ce0 DDR: disconnecting call
*Nov 20 09:28:49: %CISCO800-2-MODEM_UP: Cellular0 modem is now UP.
*Nov 20 09:28:59.027: Ce0 DDR: re-enable timeout
*Nov 20 09:28:59.027: DDR: Dialer Watch: watch-group = 1
*Nov 20 09:28:59.027: DDR: network 5.6.7.8/0.0.0.0 DOWN,
*Nov 20 09:28:59.027: DDR: primary DOWN
*Nov 20 09:28:59.027: Ce0 DDR: Attempting to dial multimode
*Nov 20 09:28:59.027: CHAT3: Attempting async line dialer script
*Nov 20 09:28:59.027: CHAT3: Dialing using Modem script: gsm & System script: none
*Nov 20 09:28:59.027: CHAT3: process started
*Nov 20 09:28:59.027: CHAT3: Asserting DTR
*Nov 20 09:28:59.027: CHAT3: Chat script gsm started
*Nov 20 09:28:59.031: CHAT3: Chat script gsm finished, status = Success
% Cellular modem line 0/0/0 is in use status 0x20090440.
*Nov 20 09:29:01: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
*Nov 20 09:29:01.071: Ce0 DDR: Dialer statechange to up
*Nov 20 09:29:01.071: Ce0 DDR: Dialer Watch: resetting call in progress
*Nov 20 09:29:01.071: Ce0 DDR: Dialer call has been placed
*Nov 20 09:29:01.779: Ce0 DDR: dialer protocol up
*Nov 20 09:29:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to up
*Nov 20 09:29:39: %CELLWAN-2-SEND_TIMEOUT: Cellular0 not responding
*Nov 20 09:30:05: %CELLWAN-2-HEART_BEAT_TIMEOUT: No heart beat signal from Cellular0
*Nov 20 09:30:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to down
*Nov 20 09:30:16: %CELLWAN-2-SEND_TIMEOUT: Cellular0 not responding
*Nov 20 09:30:31: %LINK-5-CHANGED: Interface Cellular0, changed state to reset
*Nov 20 09:30:36: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
*Nov 20 09:30:39: %CELLWAN-2-SEND_TIMEOUT: Cellular0 not responding
*Nov 20 09:30:46.363: Ce0 DDR: re-enable timeout
*Nov 20 09:30:46.363: DDR: Dialer Watch: watch-group = 1
*Nov 20 09:30:46.363: DDR: network 5.6.7.8/0.0.0.0 DOWN,
*Nov 20 09:30:46.363: DDR: primary DOWN
*Nov 20 09:30:46.363: Ce0 DDR: Dialer Watch: resetting call in progress
*Nov 20 09:30:46.363: Ce0 DDR: Dialer Watch: Check reconnection needed
*Nov 20 09:30:46.363: DDR: Dialer Watch: Dial Reason: Secondary of group 1 AVAILABLE
*Nov 20 09:30:46.363: DDR: Dialer Watch: watch-group = 1,
*Nov 20 09:30:46.363: DDR: dialing secondary by dialer string gsm on Ce0
*Nov 20 09:30:46.363: DDR: Dialer Watch: Stale dialer watch group 1 found on Ce0
*Nov 20 09:30:46.363: Ce0 DDR: Attempting to dial gsm
*Nov 20 09:30:46.363: CHAT3: Attempting async line dialer script
*Nov 20 09:30:46.363: CHAT3: Dialing using Modem script: gsm & System script: none
*Nov 20 09:30:46.363: CHAT3: process started
*Nov 20 09:30:46.363: CHAT3: Asserting DTR
*Nov 20 09:30:55.263: Ce0 DDR: disconnecting call
post the running config of your 819 router...
Wizard4777
configure a watch-list...like this:
conf t
int cell 1
dialer watch-group 200
exit
dialer watch-list 200 ip 5.6.7.8 0.0.0.0
dialer watch-list 200 delay route-check initial 60
dialer watch-list 200 delay connect 1
dialer watch-list 200 delay disconnect 1
